Old 7th November 2016, 12:43   #61
Default Re: Swift Dzire ( old model)Headlight beam adjustment
Originally Posted by Jaggu View Post
By any chance has the bulb been fitted ulta? Check on this before anything else. As far as bean adjustment goes, there are two small start screw heads at the back, they can be turned around. Hurdle is in a swift accessing them is a big paid due to the space constrains.
There will be 3 positioning pins that are kinda at 3 corners of triangle on the bulb base. The taller side of this triangle should be on top 12 clock position, whereas the other 2 should be at about 5 and 7. It will have corresponding slots on the headlight and bulb will slide into this smoothly. This is one thing you can check.
Thanks a ton , Mr Jaggu !!!
You were right .
I messed up the position of the bulbs.
Refitted the bulbs on my own , once again. Now the bulbs seem to be linear and slotted in precisely.
Will check the beam pattern tonight and get back to you.
However i strongly feel , the issue would ve resolved by now.
Thanks once again for taking the time to reply !.
hbk4 is offline   (1) Thanks Reply With Quote
Old 9th November 2016, 03:51   #62
You were right .
Issue solved.
Now my dzire has a very bright n long beam in high and very wide and clear beam in low.
Indeed the bulb was fitted ulta , initially..
Thanks a ton , once again for finding the patience to reply and help me out.
Thanks.
Cheers !!
hbk4 is offline   Reply With Quote
Old 23rd September 2017, 10:45   #63
Epic's Avatar
Thanked: 297 Times
Default re: How to adjust headlight beams
Reviving a pretty old thread.
I guess most of the discussion of headlight adjustments focus on the height (up/down) of the beam which is pretty simple to do. However, I wanted to know, how does one verify that the horizontal beam (width) is focused correctly?
I have been trying to understand this through various videos and threads online but still not clear with procedure.
Epic is offline   Reply With Quote
Esteem - Rear view mirror, door beams available cheaper? Raccoon Modifications & Accessories 5 15th October 2008 16:22
How to adjust the graphic equalizer revvedup In-Car Entertainment 21 15th November 2006 23:56
How Do They Adjust Milage In New Engines? ramkya1 Technical Stuff 2 21st September 2006 20:05
