Old 14th December 2011, 13:54   #1
Default Gear Cable Head worn out Fiat Adventure D
Dear folks, I have a problem,, I picked up used Fiat Palio Adventure D, just getting the car ready, noticed that the gear cable head which is near the battery, I suppose the one that provides lift, is worn, the washer is gone and the head keeps popping out. Now I have asked for a new set of cables from a friend in Mumbai, but it will take some time, I was wondering if there is any way to fix it? BTW am in Chennai and sourcing Fiat Palio parts here especially for the Adventure does look like a problem.
Senz is offline   Reply With Quote
Old 14th December 2011, 18:02   #2
libranof1987's Avatar
Thanked: 3,091 Times
Default Re: Gear Cable Head worn out Fiat Adventure D
Does you car need a gear cable replacement?
I'm facing the exact same issue with my Corsa. The R-1-3-5 do not slot as confidently as 2-4 do; it turned out to be a rather playful gear-cable.
Apparently, the gear cable develops play during the course of it's life and when the whole assembly was played around with during a recent clutch overhaul, the damn thing showcased it's mischief.
The gear cable CAN be adjusted to a certain extent; but only up to a certain extent. In most cases, it has to be replaced. Try going to A.S.S. for it; a friendly SA might try to do the best he can.
In my case, replacement is in order. The one for Corsa costs 8k. And this, after a 9k clutch replacement.
libranof1987 is offline   Reply With Quote
Old 14th December 2011, 21:58   #3
Well, the service adviser at the A.S.S here in ECR, is not very helpful. I did have the clutch replaced too, locally and then this cropped up. I need a temporary solution till I get them cables.
Old 14th December 2011, 23:58   #4
Ahan! We are sailing in the same boat.
Temp. fix - getting it adjusted which itself is doubtful.
When I slot the R-1-3-5th gear, I have to often slot it 3-4 times to get the correct position. At times, esp. for R, there's a grrrr sound because of improper slotting.
I'd suggest you wait it out; it'll be terrible to have the clutch screwed because of this.
Old 15th December 2011, 09:52   #5
Thanked: 110 Times
You can try Gautam auto or SM auto in GP road.
Vijay
vijaycool is offline   Reply With Quote
Old 19th December 2011, 16:47   #6
Thank you Vijay, I managed to source the parts from a friend in Mumbai, unused old cables. Now am focusing on getting the car into shape, and post my experiences soon
Embarking on an Adventure: My pre-owned Fiat Adventure Samar117 Test-Drives & Initial Ownership Reports 44 28th December 2017 21:26
Can a gear-lock cause the gear cable to loosen up? libranof1987 Technical Stuff 0 22nd December 2011 21:29
Sony Unilink cable (bus audio cable) issue philipreji In-Car Entertainment 1 3rd January 2009 16:32
Indigo Tyres worn out in the corners!? HSV Technical Stuff 9 9th October 2007 17:17
Suspension worn out? ravradha Technical Stuff 2 27th December 2006 10:49
