Old 15th December 2011, 12:21   #16
Swanand Inamdar's Avatar
Thanked: 573 Times
Default Re: Volker Jack - New introduction in Bangalore.
Novel concept for sure. 5k? Well, yes slightly on the higher side, but then, looking at the ease of use, the amount maybe justified.
Same questions that have arisen though. What if the rubber develops a puncture? Do we take it to the local puncture wallah and say - bhaiyya, alongwith the tyre, please work on the puncture of the jack as well .
Swanand Inamdar is offline   Reply With Quote
Old 15th December 2011, 12:27   #17
Thanked: 526 Times
May be a dump question..!! Will this put any pressure on the exhaust system of the car? Why can't the same technique be used to inflate tyres?
poloman is offline   Reply With Quote
Old 15th December 2011, 12:30   #18
Thanked: 35 Times
I think the electric jack on sale here in classifieds is a better option than this inflatable one. A little risky for the investment since it should be protected from sharp object, etc.
zaks is offline   Reply With Quote
Old 15th December 2011, 12:44   #19
esteem_lover's Avatar
Thanked: 445 Times
Originally Posted by libranof1987 View Post
That apart, how is the exhaust removed?
A very useful question. Who will do this and how ?
Originally Posted by mayankjha1806 View Post
PS: In the picture its not just lifting the one wheel which needs to be changed but lifting both wheels, wouldn't this is risky when doing it on an incline. The existing jack only lifts one wheel and there are three wheels to hold ground, in this case there are only two.
Forget an incline, like n_aditya said, suppose you drool at the contraption and talk to your friend and it over inflates and topples the car or at least makes it dangerous to toppling ?
Originally Posted by DWind View Post
This still does not make the most difficult part of changing tyre, easy. For me the most difficult part of the tyre change is screwing and unscrewing the bolts (have to stand on the wheel spanner) and lifting the fully inflated tyre and placing it on the wheel to fit the screws (pity the people who drive SUV and suffer a puncture)
That is a very valid query. Now, Mr.Volker will have to think of some robot for you which will cost 10 times the cost of your car. Ready ?
Old 19th December 2011, 16:49   #20
BuRnT RuBbEr's Avatar
Thanked: 11 Times
screw-unscrew can be made simpler: either keep an extension pipe with the spanner that yields the correct torque for the screw, or buy a cordless bosch driver that has the required torque. these can however cause thread damage, especially when being used with alloy wheels.
second issue: you could design and build a trolley jack. put the tyre on the trolley and use the jack mechanism to lift it up. place in position with help of 360 wheels mounted on the trolley. i think the mechanically creative folks will get the idea. a related picture below...
http://static1.bonluxat.com/cmsense/...olley_d0ni.jpg
BuRnT RuBbEr is offline   Reply With Quote
Old 19th December 2011, 23:33   #21
himavanth_m's Avatar
Thanked: 266 Times
The composition of Exhaust gasses is different as compared to Air or N2. This is the main reason not to use exhaust gasses to inflate tires.
Another reason is that the exhaust gasses are generally heated. It is not good to inflate tires using heated gasses. Once the gas cools down, the tire pressure automatically drops causing problems.
himavanth_m is offline   Reply With Quote
Old 20th December 2011, 07:41   #22
NPV
NPV's Avatar
Thanked: 4,771 Times
Originally Posted by SirAlec View Post
I would not personally use this or recommend this. With me safe keeping is an issue. As i am bit rough or careless on things, same reason i don't use iphone.
A small puncture will mess up the thingy. I am sure they have made it sturdy but you will never know. I would stick to my mini hydraulic jack. It has a 2 ton capacity with its own plastic case. A very handy and must have.
@SirAlec - Please do share the brand/make & price of the mini hydraulic jack you have and from where you bought it (would help if you know where I can get it in Bangalore).
NPV is offline   Reply With Quote
Old 20th December 2011, 14:46   #23
DRC
DRC's Avatar
Thanked: 42 Times
I think it could be dangerous as by design it looks it may get wobbly.
I still prefer bottle jack, or a screw jack,
For those who want to make it easier (women, elderly etc...) there is a electric option in the screw jack. I remember having seen it in Madhu's some time ago.
DRC is offline   Reply With Quote
Old 20th December 2011, 21:48   #24
Thanked: 658 Times
Its a chinese make. But pretty durable. I have been using it for a long time and also used it to jack up bigger rated vehicles like sumos and safari.
It was bought in Ahmedabad for 1600/-.
Old 23rd December 2011, 20:07   #25
RGK
RGK's Avatar
Thanked: 206 Times
As Rudhra said, it was around 15 years back. One salesman at that time came to me and showcased the product. He said, it is very helpful for lady drivers who find difficult to lift the vehicle.
Hydraulic jack is better and durable than this.
RGK is offline   Reply With Quote
Old 23rd December 2011, 20:41   #26
autocrat's Avatar
Thanked: 537 Times
If anyone buys this, one needs to ensure their exhaust system is leakproof
Underchassis examination of my car recently revealed that the muffler can is rusted. I don't think its a good idea to use this air pillow to lift my car.
Also, if there is a sudden deflation when loaded, car may suffer some damage.
I prefer a metal jack even if it means some inconvenience.
autocrat is offline   Reply With Quote
Old 24th December 2011, 06:53   #27
shankar.balan's Avatar
Thanked: 5,326 Times
Does anyone remember the Rapid Jack of the 1980's?
This concept seems very similar to that.
Unfortunately that Rapid Jack never did very well - it used to cost some 500 Bucks or something at that time and that was a heck of a lot of money around then.
Old 24th December 2011, 09:08   #28
mayankk's Avatar
Thanked: 3,489 Times
This seems much better.
1.5 Ton Electric Automatic Car Vehicle Scissor Jack | eBay
mayankk is offline   Reply With Quote
Old 24th December 2011, 10:42   #29
viggienomad's Avatar
Thanked: 28 Times
Seems the cost for this type of hydraulic jack also gone up. This list of various hydraulic (& electric) jacks at Naaptol.com shows prices in the range of Rs.5,000 to Rs.6,000. Car Jack - Compare n Buy Car Jacks at Low Price Online in India
Hydralic bottle jacks seems to be cheapest. Any disadvantages in using bottle jacks? Can it topple easily?
Not very confident about Electric jack. Being unknown brand & electrical, the motor can go out easily.
viggienomad is offline   Reply With Quote
Old 24th December 2011, 16:03   #30
oxyzen's Avatar
Thanked: 265 Times
Few questions.
- Does the exhaust have enough back pressure to inflate the bag and thereby lift the car?
- How do you ensure proper sealing with the exhaust.
- What if my exhaust has a leak.
oxyzen is offline   Reply With Quote
Electric Jack gd1418 Modifications & Accessories 26 3rd September 2016 12:13
Buying a new Jack libranof1987 Modifications & Accessories 24 9th April 2014 14:53
Wanted Pit Jack jyobeb Shifting gears 0 21st July 2006 08:45
Hello !! Introduction & RE-Introduction highwayblaze Introduce yourself 6 17th February 2006 18:17
