Old 22nd December 2011, 09:38   #16
Rajith's Avatar
Thanked: 407 Times
Default Re: Accent CRDi - Piston Sleeve Crushed like EggShell
Originally Posted by DarkLordOfSith View Post
UPDATE :
Lakshmi Hyundai called.
They said, they would be replacing the parts and that Kusalava Hyundai would be sending the parts.
I have a couple of questions :
1. They said, they would be replacing only 1 piston. Is that adviceable ?
Shouldn't all the pistons have same amounts of wear and tear ? Would this change compression ratios ?
2. Should I be paying for the service/labour charges ? Or should I be fighting for them as well ?
In cases like mine, should I be paying anything, anything at all ? Like for Engine Oil, Oil Seals etc ?
Changing 1 piston and sleeve should be fine.But one has to find out the real cause of the failuer.It can be a wrong dia sleeve or failed piston bore of the block is widened.If the reason is the second one, then replacement of the block has to be considered, just changing the sleeve wont serve the purpose. As you have brought all spares from Hyundai, chances of getting one sleeve wrong is remote...
Idealy you shouldnt be paying any thing and you should request hyundai to give a stand by..
Rajith is offline   Reply With Quote
Lancer DIESEL/ Accent DLS/Accent CRDI ForeRunner Sedans 28 20th June 2011 18:19
modifying hyundai accent like the wrc accent kausu Modifications & Accessories 11 26th March 2006 14:20
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
