Old 18th December 2011, 22:21   #1
Thanked: 317 Times
Default Chemical composition of different fluids
Just a curiosity thingy what are the different fluids used in the car made of, what are the desirable physical and chemical properties etc.
For example washer fluid, transmission oil (how is it different from engine oil) brake fluid ...
vina is offline   (1) Thanks Reply With Quote
Old 18th December 2011, 23:08   #2
dot
dot's Avatar
Thanked: 714 Times
Default Re: Chemical composition of different fluids
Windshield washer fluid: Mostly propylene glycols + additives
Radiator fluid: Mostly low molecular weight ethylene glycols + green dye
Engine Oil for petrol (fully synthetic): Glycols (max%), ashless dispersants (max 4-6%), detergents (max 4-6%), anti-corrosion agents, viscosity modifiers, color and other additives.
Engine oil for diesel: similar composition with higher percentages of dispersants and detergents.
Brake fluids: Again mostly glycol based.
Transmission fluids: Mostly glycols of different molecular weights and rheology based and other additives.
dot is offline   (3) Thanks Reply With Quote
DIY: Flush / Bleed the clutch & brake fluids SunnyBoi DIY - Do it yourself 35 16th July 2016 07:32
The BW Egret: 49999 MT Medium Range Oil & Chemical Tanker pedrolourenco Commercial Vehicles 37 15th June 2016 02:21
Chemical Toilet! which one? where? SirAlec Shifting gears 8 19th April 2011 12:01
Different Speaker Brands = Different sound for same/similar music ? normally_crazy In-Car Entertainment 10 29th August 2006 12:05
