View Poll Results: If you have faced a DSG mechatronics failure, please vote here(Multiple option poll):
My car is a Laura Petrol 1 5.88%
My car is a Laura Diesel 4 23.53%
My car is a Superb Petrol 5 29.41%
My car is a Superb Diesel 3 17.65%
It is a 6-speed DSG 6 35.29%
It is a 7-speed DSG 11 64.71%
The car is mostly chauffeur-driven 6 35.29%
The car is mostly self-driven 9 52.94%
Most of my drive is in crawling / stop-start traffic 6 35.29%
Most of my drive is in free-flowing traffic 4 23.53%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Old 22nd December 2011, 18:19   #46
Thanked: 955 Times
Default Re: DSG Mechatronics Failures: Are we driving them wrongly?
As for manual transmission, pressing clutch disengages clutch. Clutch wear happens when clutch is slipping. Fully disengaged, there is no cluch plate wear.
Sure, I would expect the DSG to shift to N on it's own if required and the driver should not have to worry about doing it.
But, DSG is a clutch based AT, so it definately has to slip the clutch (during take off, etc), I do not think there is any other way it can work.
With DSG, how can you come to a complete halt or even crawl at 2/3 kmph without (DSG automatically) slipping the clutch for you???
anandpadhye is offline   Reply With Quote
Old 22nd December 2011, 18:21   #47
tsk1979's Avatar
Thanked: 15,641 Times
You cannot.
Yet in a real world traffic jam with crawl speeds, your car has to function. As a user why should I car what is the tech.
I bought an automatic car, and it will be used like an automatic car, like all over the world. You cannot ask a customer to drive an automatic like a manual.
Why is it that only skoda automatics have such high rates of failure?
This driving condition thing is they way of moving attention away from poor engineering or QC
Old 22nd December 2011, 18:39   #48
Thanked: 973 Times
If you are going to drive an automatic like a manual(shift to neutral and D continuosly), why spend more on an automatic, might as well buy a manual.
Automatics have always been driven like this.
Pardon my (and probably VW's) ignorance in assuming that an owner/driver of a DSG equipped car would know the difference between a torque converter automatic and a dual clutch gearbox akin to how one would expect an owner/driver to know if the vehicle is FWD or RWD.
It would have been convenient if they would have incorporated a stop sensor to switch to neutral, but in my humble opinion, I feel it would go against the quick shift and gear pre selection core ideas. I also dont feel its asking too much to shift between neutral and drive for the performance and other plus points it has over a conventional torque converter automatic. But that's just me
Cheers.
gthang is offline   Reply With Quote
Old 22nd December 2011, 18:46   #49
tsk1979's Avatar
Cheers.
Are DSG cars failing all over the world. If they were, your argument would be true. Somehow, they fail in India quite a bit more. Moreover, failure of DSG is happening more in one type of DSG(I think petrol) rather than diesel.
So if your argument is correct, then all DSGs should be seeing high failure rate, not just the petrol ones.
Old 22nd December 2011, 19:01   #50
Thanked: 955 Times
You cannot.
Absolutely.
The buyer of automatic car should not have to care about all this at all. But Skoda is not claiming that one has to care about it. They are not saying that driving conditions or driving styles are the culprit.
As far as the technical reasoning behind the failures, according to me the reason for higher failure rate of DSG (versus regular torque convertor based AT) lies in this fact - DAG is a clutched AT - it slips the clutch whenever it has to and the long term reliability of this technology is a problem (as of now). This does not mean this technology has no future. I am sure this will be resolved in the long run - like most of the engineering challenges are overcome in the world. But it also does not mean that Skoda should use customer cars for testing...
So it depends on what's the purpose of this thread:
Blame it on drivers? - No way.
Vindicate drivers? - Well, who is blaming them anyway?
Discuss reason for DSG failures? - Sure, for that it must be mentioned and understood that DSG different from torque convertors.
Old 22nd December 2011, 20:31   #51
Thanked: 973 Times
I thought this thread already highlighted the fact that DSG failure is a global phenomenon. Also the fact that the different architecture of the 6 vs 7 speed amplifies the failure cause.
Imagine a scenario where a driver who is only used to current generation softroaders with all wheel drive gets into a manual transfercase 4x4, and thinks that it is OK to drive in 4WD mode all the time. Would ensuing failure be considered manufacturing defect? No. It would be attributed to Driver Awareness (lets call it I), or, Driver Ignorance (lets call it Q).
Now, VW obviously used a value too high/low for the I/Q quotient in their calculations. Now, when failures arise, it does not sound nice when VW says that it is due to lack/abundance of I/Q that it happens. Nobody likes to hear that.
Sure, it's easier to carpet bomb Skoda (VW) rather than sniping out the root cause.
Cheers.
Old 22nd December 2011, 21:33   #52
Thanked: 2,071 Times
I believe the failures are in the 'mechatronic' unit, not the clutches.
Sutripta
Sutripta is offline   (2) Thanks Reply With Quote
Old 22nd December 2011, 22:27   #53
Thanked: 973 Times
Sutripta
Are the two components related?
Cheers.
Old 22nd December 2011, 22:30   #54
tsk1979's Avatar
Sutripta
Thanks for the clarification. I do not see a reason for this component to be affected by stop and go traffic. Looks more to be a design flaw.
Old 22nd December 2011, 22:33   #55
Cheers.
You tell me!
Sutripta
Old 23rd December 2011, 09:57   #56
Thanked: 313 Times
I guess by Skoda automatics you mean VW DSG.
By the way, DSG technology is not completely unique to VW, other manufacturers have it too (they don't call it DSG) and they are not facing as many problems to my knowledge.
On your (tsk's) comment on another post - yes DSG is failing all over the world. There were two major recalls in US a few years ago.
On your comment on Mechatronics in stop and go traffic - mechatronics has to work harder (the "Mechatronics" unit does what your and my knee and hand do - disengage the clutch, shift the gears, rengage the clutch) in stop and go traffic. Most likely this is an endurance failure of the components involved.
vina is offline   Reply With Quote
Old 23rd December 2011, 10:06   #57
Thanked: 955 Times
I second that.
It's a durability issue rather than a design one.
And why Skoda has the higher (or highest) rate of DSG failure (compared to VW/Audi, etc)? - because Skoda sells highest numbers of DSG cars in India .
Old 23rd December 2011, 10:40   #58
Thanked: 754 Times
Originally Posted by V-16 View Post
MAybe the DSG unit is not tropicalised but then again, why not. And that does not seem to be the reason because these dsg units are failing on all their cars all over, VW, Audi, Skoda, you name it.
I remember one fact from my days of reverse engineering defense equipment. Tropicalisation is a necessary fact of life for India. There were 2 main areas we noticed:-
1. Rubber & composites grades (not much of palstics used then. But I guess it applies to them also). If your primary application is going to be based in very cold temperatures you need a seperate grade of rubber. You cannot use this grade in a tropical country like ours as @ 35-45 degC it will become very soft & loose its sealing/damping properties. In our defence environment we have the deserts & the Siachen front. Equipment needs to be serviced & many parts changed before moving from one to another. Hell even the British delayed their counterattack at El-Alamien ( during WW2) by a few weeks to render their newly supplied tanks & artillery suitable for desert use.
2. The same applies to the base materials also. A particular grade of steel will snap like a twig in the Nort Euorpe/Siberian winters but carry on merrily in our climate. And the grade suitable for Arctic winters will have strength limit problems here. This is of course at the extreme loading conditions, BUT I AM GIVING THESE EXAMPLES JUST TO ILLUSTRATE THE COMPLEXITIES INVOLVED.
A classic example of such issues is the Space Shuttle failure (on launch) due to rupture of the sealing O-rings in the Solid State Boosters. ( Happened due to exposure to a Storm before launch).
I suspect something like this is happening with all the german brands - refer to complaints re electronics failures, wiring dying due to moisture & coming back to life after the rains stop etc.
Possibly the volumes in India do not justify the minor reworks required to solve these problems. Or they just do not care as they are getting away charging a hefty premium.
sridhar-v is offline   (1) Thanks Reply With Quote
Old 23rd December 2011, 11:52   #59
Swanand Inamdar's Avatar
Thanked: 573 Times
So, all in all Mechatronics have a high chance of failures. Skoda's DSG at that. Why? Because Skoda sells more cars in India, than VW or Audi. Hence, the fact that Skoda DSG's fail.
My question is- If we are driving the DSG's wrong, then whats the proper way to drive it? Am I supposed to shift to N at complete halts, or let the DSG do its thing, while I just press the brake?
Swanand Inamdar is offline   Reply With Quote
Old 23rd December 2011, 14:29   #60
SPIKE ARRESTOR's Avatar
Thanked: 742 Times
Default What is failing?
Hi Guys,
Any idea what is failing? There are reports that "It is failing, it is failing" but what exactly is "It" ? Any pics? Also any inputs on the failure rates (B10, L90 etc) ?
I was a Vehicle Test Engineer with an Indian company. We sell products in many countries including Uganda and Rwanda , if we were unable to simulate a real world usage pattern (ambient, driving cycle) here in India, we made sure it was tested in the country where it is likely to be sold or has market scope. Hence, I do not buy the statement regarding "Indian conditions" !
Spike
SPIKE ARRESTOR is offline   (1) Thanks Reply With Quote
Skoda Superb DSG 7 Speed DQ200 failures- China gets official reaction, why not India? .anshuman The Indian Car Scene 175 12th December 2017 08:39
Skoda Woes And The Ghost Of The Mechatronics!! V-16 Technical Stuff 197 27th July 2016 21:33
Mercedes-Benz: Advanced Diploma in Automotive Mechatronics @ Kerala GTO Technical Stuff 10 1st February 2014 08:43
Black Lightning: My Skoda Superb 1.8 TSI DSG-UPDATE: DSG box replaced! Swanand Inamdar Test-Drives & Initial Ownership Reports 130 10th September 2012 13:01
