Old 16th March 2006, 05:29   #1
Thanked: 7 Times
Default New AC making noise
I have a STD maruti Alto. Just few weeks ago i fitted an AC Sanden Compressor (R134) and Subros fittings. The biggest mistake i made by not fitting it MASS showroom .
I get a grawling sound as soon as i switch on the ac. The mechanic told me that the sound will be gone after some usage. I have driven atleast 1000 km with the AC on but find no difference. The sound is high when the compressor starts working.
When i try to concentrate on the sound the sound comes from the cooling coil side. The noise is distinct n clear inside the vehicle whereas its not noticeable outside the vehicle. One more thing i noticed is that my head light flickers at time when the compressor starts.
I am really confused now. Some please suggest me what i need to check/ probable reason for the noise.
Real_man is offline   Reply With Quote
Old 16th March 2006, 07:08   #2
SLK
SLK's Avatar
Thanked: 190 Times
Possible reason for noise...
1) A/c compressor touching the body.
2) Bad compressor (I can't be sure about this though)
Check the belt and the bolts of the compressor.
Did the mechanic put proper amount of gas??
Also did he put the compressor oil?? (local guys normally don't, MASS always does)
Cooling coil making THAT noise is not normally possible....
Your headlight flickers.. once?.... I guess that’s normal... though its very slight in stock a/cs but its there.
I AGREE!... if you have to get an a/c why not get a Alto with a/c model.
We did the same mistake on one of our 800s... thinking that after market a/c is more effective ... but *** the engine started to pack up at 60k kms!!
SLK is offline   Reply With Quote
Old 22nd March 2006, 05:06   #3
Thanked: 7 Times
Thanks SLK,
The mechanic had added Compressor oil during the installation. Checked the nuts bolts n the Belt again.
The sound to some extent has reduced unlike before without any changes. Now the sound is abit less n occurs only when the AC is started. I sometimes get a squeak sound from the cooling coils side, is the AC filter choked.
Could this be due to new compressor ?
Please let me know how to find if the compressor is defective
What i am planning to do now see different authorized AC mechanic n take their feedback.
Air Con making noise!! Shan2nu Technical Stuff 29 25th September 2015 04:30
So why all the noise making by the Car Manufacturers abt ICE ?? blueraven316 In-Car Entertainment 15 22nd January 2008 13:49
baleno making kr..kr..kr..kr noise gigy Technical Stuff 19 6th July 2007 19:33
Zen MPFI making big kr..kr..kr..kr noise nicejits Technical Stuff 3 22nd June 2007 13:41
Swifts making a noise .. khaadu75 Modifications & Accessories 35 11th June 2007 22:16
