| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) |
| Newbie Join Date: Dec 2007 Location: Bangalore
| Reg. the M800 Hand Brake heating up: ------------------------------------ I was told by the service engineer that its normal. Reg. the Break Fluid topping up for Getz, asked by sidharth_j: ---------------------------------------------------------- Are you planning a DIY for topping up break fluid? What if there is a break fluid leak? Will you be able to detect it? I had break fluid leaking issue with my M800 and I got it topped up at a MASS. |
| | #17 (permalink) |
| BHPian | Thanks for that indication ram, it can certainly be because of that. The exhaust has been replaced an year ago(some 3000km ago) and probably the mech has fixed it too close to the body . I will get it checked and if clamping etc.,. is not feasible then the insulation material you suggested should be the way to go. |
| | #18 (permalink) |
| BHPian | there may be problem in exhaust pipe it may be in contact with that area and makes it hot. try to fix it. i think it is not a handbrake problem as if the car is driven with handbrake pulled the tyres are heated up not car body.
__________________ harry |
| | #19 (permalink) |
| BHPian Join Date: Nov 2006 Location: Singapore
| I have the same 'problem' as well.. the area near the hand brake hinge becomes warm after some driving. But I am sure that the brake lever is not engaged. Thanks Ram for clarifying that. Let me see if the insulation can be done. That will help the air conditioner |
| | #20 (permalink) |
| BHPian Join Date: May 2006 Location: Bangalore
| That's right. If it's a Maruti 800 that you own, and if it was manufactured between 2003/4 and 2005 (or beyond), you would notice the 'hot' handbrake. The service advisor had said that the catalytic convertor was positioned beneath the handbrake lever, when this was brought to his notice. |
| | #21 (permalink) |
| BHPian | This raises another question in my mind.Say some one ignores this and keeps driving .After some time, due to regular heating and cooling back, is it not possible that the underbody loses it resistance and becomes susceptible to corrosion /rusting in long run? If one can feel heat on this side of metal ,then surely other side should be much hot ,no? |
| | #23 (permalink) | |
| BHPian | Quote:
Doing some research i figured out that the linkage is directly connected to the rear drums and when u press the brakes through the brake pedal the rear brake liners rub against the drum and thus some of the heat is transmitted through the linkage to the lever. Has been happening in my car since 9 nd half years and there is nothing to worry about
__________________ Its not the age,Its the mileage | |
| | #24 (permalink) |
| BHPian Join Date: Nov 2006 Location: kolkata
| This problem could also be due to a faulty ignition( the place where the car keys go in) I have problem with my Zen, where the light shows up sometimes, all I have to do is, turn the key anticlock wise (back) a little and the light disappers. |
| | #25 (permalink) |
| BHPian Join Date: Apr 2006 Location: chennai
| If the car is fitted with a catlytic convertor , then fuel impurities might also heat the cat up. Try filling gas at some other station and check . Cats block harmful gases and incase the fuel is adultarated then most probably ,the unburnt residue takes a longer time to burn and get out of the cat. Best thing would be changing fuel and then looking for any catlytic convertor damages |
| | #26 (permalink) | |
| BHPian | Quote:
In that case , probably convection of exhaust heat can be a cause rather than adulterated fuel. | |
| | #27 (permalink) |
| BHPian | this raises another question in me,if we look at the grey market for car-spares, a cheap muffler for an 800 can be obtained for as much as Rs.500 where as a new one costs something more than rs.1500 (just a guess didnot check exact prices). So, other than quality of metal and finishing , functionally are these after market mufflers too inferior than MGP ones?? Specifically do they have Cat-converters also? What kind problems can arise by using non-MGP mufflers(or silencer as they popularly call it). Last edited by deetee : 17th January 2008 at 15:40. |
| | #28 (permalink) | |
| Quote:
I didnt say the buring takes place in the cat , what i meant was the unburnt particles might be blocked inside the cat and when the vehicle is in operation the cat gets hotter because the unburnt particles will also start burning in the cat. I tried testing my car with kerosene and also with diesel mixed petrol . I was on the verge of burning my car . | |
| | #29 (permalink) | |
| BHPian | Quote:
AFAIK, catcon has to deal with conversion of CO,Hydrocarbons and nitro compound(NO gases). These , even unburnt in engine , will be in gaseous state and don't burn as such(not ignitable).CatCon uses some chemical reactions to convert them to harmless compounds . So, there are no 'burning' particles leaving from engine into catcon; actually there will be no particles in exhaust you see- only hot,very hot gases. Well, that heat itself gets transfered by convection to components around catcon.May be thats what i felt as heat around handbrake hinge. btw, brother are you a pc/console gaming freak- 'mana' in your name suggests it. Mana means that magic potion you drink to regain stamina to cast spells. | |
| | #30 (permalink) |
| Howstuffworks "How do I know if my catalytic converter has failed?" . How can I tell if my catalytic converter is... — Yahoo! Autos may be the link can put things in a better perspective . The only types of games that I know are played in dark...lol |
| Thread Tools | |
Similar Threads | ||||
| Alternator problem in M800 | Jeep | Technical Stuff | 14 | 18th January 2008 16:16 |
| Low rev problem in M800 (Carb Model - 1996) | Jeep | Technical Stuff | 2 | 29th November 2007 16:44 |
| AC problem in M800 | humyum | Technical Stuff | 6 | 20th August 2007 18:27 |
| M800 -Wheel Problem | sumeethaldankar | Technical Stuff | 8 | 26th June 2007 18:52 |
| m800 vs ikon (what comp can a M800 be?) | manaa45 | Street Experiences | 13 | 31st March 2005 11:06 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
