Old 2nd August 2009, 01:06   #16
Originally Posted by Wind View Post
I just happened to notice it last month while going over 80 km/hr in my Spark. Was planning to ask the service center folks to have a look at it in August when it is due for service. Is this the problem only for the first lot of sparks? ( I bought mine in August, 2007)
One other issue is that it is really difficult sometimes to put into reverse gear.
Anyone else is having the same issue?
IMHO This thread can be renamed to problems with Chevrolet Spark.
-- Wind
I haven't noticed such a problem with my Spark. I bought it in January and, thankfully, the accelerator hasn't come alive .
saptashaw is offline   Reply With Quote
Old 13th August 2009, 11:20   #17
IndrojitSircar's Avatar
Thanked: 116 Times
Originally Posted by curios View Post
I am new to driving and have had a Chevy Spark for a month now. Initially when I pressed the accelerator pedal the car lunged forward in fits and starts. Now even after coming to terms with it and managing it better, it still tends to act that way.
What's more worrying is that from time to time while driving the pedal comes up a bit as if it was stuck somewhere.
Also if I release the pedal the car immediately slows down.
Is this normal? Please suggest what I should do?
I had a similar problem and i realised that it was the foot mat going and getting stuk under the pedels.Just move it back for the time being and later you could change the foot mats and get new ones which are a bit shorter as in the length is less than the current ones you have so that it does not get under the pedals.
Originally Posted by VeluM View Post
One thing I've noticed about the Spark's accelerator. When one is cruising (any speed) and neither accelerating or decelerating, the pedal tends to flutter a bit. It's an odd feeling if one is not used to it. Feels like the pedal is alive! Is this just mine or is it common to all Sparks (or any other cars)?
In my experience the car tends to jerk in 1st gear, when I press the accelerator (car's already rolling, clutch not depressed) to gain a little speed or maintain speed. Happened in my old Wagon R too, but I don't know why. Any thoughts?
Same thing in my friends spark which i drive regularly (2-3 times a week) i guess its got to be something with the design.
Old 12th October 2009, 09:59   #18
Latheesh's Avatar
Thanked: 3,326 Times
Yes my Sparky has the same problem Accelerator pedal moves without any pressure and it can be felt on yout foot. After checking I suspect the floor mat, pedal rod touches the mat. Am planning to cut that area in the mat
Latheesh is offline   Reply With Quote
Old 29th December 2011, 10:36   #19
Default Spark accelerator pedal acting odd
Already searched on the forum, and found few mentions of this behavior in spark ownership threads, but no conclusion as to whether its a feature of the spark or a bug , hence a new thread.
Purchased a Spark LT for my wife yesterday. Coming from diesel cars, i knew a few changes in driving habits will be needed.
But one thing that i noticed was that any gear change (1->2, 2->3, 3->4) if done with a simultaneous "release accelerator pedal and press clutch" operation is resulting in a 200-300 rise in the RPM. Tried this a few times to confirm, and it was happening on every shift.
So tried the following approach:
1. Leave the accelerator pedal.
2. Wait for 1-2 seconds.
3. Press clutch and change gears.
And voila! The RPM meter now behaved correctly, that is if the foot is off the accelerator, and clutch is pressed the RPM should drop once the clutch engages. The gear changes were now smoother with no over-revs.
Reached home and had a look under the dashboard. The accelerator in the spark is wire controlled. (wire connecting the pedal to the throttle body). i felt the slack of the wire was more than it should be.
Popped the hood and checked near the throttle body. The slack is such that i can lift the wire around 2-3 cms up.
This made logical sense as to why the accelerator is feeling "stuck" on releasing. The slack in the wire is not allowing the throttle body to go to minimum as soon as the pedal is released, resulting in a lag of 2-3 seconds before the rev begin to drop.
I wanted to ask if my diagnosis is correct? Is this a feature on all sparks or an issue on my spark. Is there any adjustment screw on this wire that can be adjusted at home. I am hesitant in going to the technically challenged service centres, and would like to do a D.I.Y if possible.
Would request the experts on this forum to help me out on this.
PS: checked my mom's MPFI maruti 800 for the slackness on the throttle cable and found it to be less than what is there on the spark.
trance_nut is online now   Reply With Quote
Old 29th December 2011, 10:45   #20
Rudra Sen's Avatar
Thanked: 4,295 Times
Default Re: Spark accelerator pedal acting odd
Mods note: Thread merged. trance_nut, you can continue with your question/discussion here.
Old 29th December 2011, 18:06   #21
Thanked: 1,059 Times
Originally Posted by trance_nut View Post
....But one thing that i noticed was that any gear change (1->2, 2->3, 3->4) if done with a simultaneous "release accelerator pedal and press clutch" operation is resulting in a 200-300 rise in the RPM. Tried this a few times to confirm, and it was happening on every shift.....
This used to happen on my car too at every shift when it was new. Showed it to the SVC and as usual they said that its not a problem and you have to release the accelerator pedal fully... Somehow during the 1st Assurance check up at 1000kms, the issue was fixed. I am guessing they have reduced the slack of the wire as mentioned by you! Apologies as i am not sure what was done but the issue was present and resolved on my car.
abhinav.s is offline   Reply With Quote
Old 29th December 2011, 18:50   #22
StrangeWizard's Avatar
Thanked: 229 Times
Originally Posted by SAHIR.KITTUR View Post
My brother has a spark & is of the first lot ( first in town ). Since then I tell everybody the same problem ( the pedal seems to vibrate ) nobody beleives it, Yes dear freind you are right, The Pedal in spark is alive.
I have a november 2007 spark which i bought used in may 2011. Even my car's accelerator pedal flutters quite a bit. And yes, even my car jerks a lot in the 1st gear.
StrangeWizard is offline   Reply With Quote
Accelerator (pedal travel ) meter Sudarshan 4x4 Technical 29 10th August 2011 16:31
Accelerator Pedal of a Jeep Parm 4x4 Technical 6 20th August 2010 03:37
swift diesel accelerator pedal issue RJ555 Technical Stuff 5 23rd November 2009 14:47
Santro: Return spring for Accelerator and brake pedal? ajith Modifications & Accessories 18 2nd April 2008 20:20
Vibration on accelerator pedal while using the horn kaushik_s Technical Stuff 2 8th September 2007 13:59
