Old 8th February 2013, 10:50   #121
Gansan's Avatar
Thanked: 914 Times
Default Re: How often should we change gear oil?
Originally Posted by jinojohnt View Post
Alto (800 cc) manual recommends Gear-Oil change at 20,000 km.
It is 2 years or 20,000 KM. At MSM they changed the gear oil for my car during the 24 month service, though the odo was only at 10,000 KM.
Old 8th February 2013, 11:09   #122
deehunk's Avatar
Thanked: 1,015 Times
My trusted mechanic in Castrol pit stop in Total Mall, Sarjapur road says once in 25-30k kms interval is ideal. But there is no way otherwise to check whether the oil has been changed or not at *** without lifting up the vehicle.
deehunk is offline   Reply With Quote
Old 8th February 2013, 11:22   #123
Thanked: 113 Times
Default Re: ARTICLE: Synthetic oil vs Mineral oil
Originally Posted by Crazy4.Cars View Post
Total brand too, there is no 75W90 sold in the market. I am not finding even one brand in the market selling 75W90 which is OEM specification.
Yeah but Total brand I got is GL-4 80-w90 and within spec for my Gypsy.
--R
Ragul is offline   Reply With Quote
Old 8th February 2013, 11:28   #124
Thanked: 113 Times
Always have all the oils changed in front of you. If you dont have the rapport and response from service station for that, then change your service station.
When changing differential oil for example I closely oversaw the oil draining, how long to let it drip the last drops, and even measured and poured it for the mechanic into his custom container.
--R
Old 8th February 2013, 11:34   #125
deehunk's Avatar
I agree, thats the only reason I stick to this place for anything other than basic service because they do the work in front of us. Both Abdul and Kishan are good and know them now for 3 years.
Old 25th February 2013, 20:33   #126
Thanked: 35 Times
Can any one recommend a good gear oil? APIGL - 4 SAE 75w/90. For Hyundai Accent petrol.
sinhead is offline   Reply With Quote
Old 1st March 2013, 22:13   #127
Thanked: 43 Times
Unfortunately you do not get 75W90 in the market, only A.S.S get it from shell in 20 litres barrels.
We must write an email to shell to start selling 75W90 in 1 litre packings in the open market too.
Crazy4.Cars is offline   (1) Thanks Reply With Quote
Old 1st March 2013, 23:48   #128
Thanked: 35 Times
Will write an email to them.
Old 1st December 2013, 19:03   #129
heysac's Avatar
Thanked: 13 Times
I used Shell Spirax 80W90 in my Swift K-Series even though 75W90 was recommended since it was not available. It seems 75W90 is only sold in bigger packs. Googling I found that HP, Servo have it but not sure of the package size. I have written to Fuchs regarding pack sizes. GSCaltex sells in bigg packs and I asked them to consider selling smaller packs since there is a vaccum in the market.
Looking at the article below, it seems 80W90 will work fine for us who don't live in the hills: http://gasgasrider.org/html/gear_oil_evaluation.html
heysac is offline   (1) Thanks Reply With Quote
Old 1st December 2013, 19:07   #130
bluevolt's Avatar
Thanked: 2,351 Times
For Honda City, the manual transmission oil change interval is 60,000 KMs. For Maruti WagonR, it is 20,000 KMs.
bluevolt is offline   Reply With Quote
Old 1st December 2013, 20:49   #131
Thanked: 14,604 Times
Are you sure of the interval for the WagonR? I was expecting it be above 60,000 kms. Any reason for such a short interval?
Anurag
a4anurag is online now   Reply With Quote
Old 1st December 2013, 21:17   #132
bluevolt's Avatar
Anurag
Yes it is indeed 20,000 kms - mentioned in the manual.
Old 1st December 2013, 22:41   #133
heysac's Avatar
Thanked: 13 Times
Good resource for learning about Gear Oils: http://www.substech.com/dokuwiki/doku.php?id=gear_oils
heysac is offline   Reply With Quote
Old 1st December 2013, 23:53   #134
auto_enthusiast's Avatar
Thanked: 363 Times
Can anyone update the Gear oil change interval for the Figo TDCi?
auto_enthusiast is offline   Reply With Quote
Old 2nd December 2013, 09:15   #135
Gansan's Avatar
Thanked: 914 Times
^^ It is always XX Kms or YY months, whichever is earlier. Just like engine oil. If you check your manual, it will be mentioned there.
How often should I check my tyre pressures? rajesh1868 Tyre & Alloy wheel Section 73 10th August 2015 19:13
How often should the transmission oil be changed? supertinu Technical Stuff 17 29th November 2013 12:33
Do we need to change the Halogen headlights often ? mithun Technical Stuff 8 11th December 2006 19:39
