Old 2nd January 2012, 12:31   #16
vikram_d's Avatar
Thanked: 940 Times
Default Re: One for the Gurus: Dzire diesel - Zero compression on all four cylinders
Originally Posted by VeyronSuperSprt View Post
There are certain situations that will lead to there being no compression on all your cylinders. They are:
1. If you have a cracked head,
2. If you have a blown head gasket,
3. You have a warped head,
4. You have a cracked block between each cylinder.
However, there would have been symptoms such as uneven idling, missing on occasion etc which may not have been noticed by the driver. My driver has the same problem, he does not notice things going wrong, he only points out after they have gone wrong.
Getting all this checked today. Head and block being sent to the "lathe" for checking.
Old 6th January 2012, 12:36   #17
theMAG's Avatar
Thanked: 1,572 Times
What's the update on this? Rather curious to know.
Old 6th January 2012, 18:20   #18
Thanked: 41 Times
Me too, waiting for final diagnosis, Quite curious to know the reason, Early report welcome.
nawalsingal is offline   Reply With Quote
Old 6th January 2012, 18:35   #19
vikram_d's Avatar
Thanked: 940 Times
Sorry guys for not having updated this thread. I was busy with my other car. The Maruti engineers came and did a thorough inspection of the block. They think the culprits are weak piston rings, but they cannot be sure. Anyways, since the car was under extended warranty they are replacing the complete engine block (bottom half) free of cost. I will have to bear only the expenses for some stuff like gaskets and oil seals, which is absolutely ok with me.
So I guess all's well that ends well. :-)
vikram_d is offline   (1) Thanks Reply With Quote
Old 6th January 2012, 20:41   #20
F150's Avatar
Thanked: 685 Times
what would be the cost of engine block (bottom half) if it was not under extended warranty ?
Expenses for some stuff like gaskets and oil seals - Would this be covered under insurance ?
F150 is offline   Reply With Quote
Old 6th January 2012, 21:30   #21
amit_mechengg's Avatar
Thanked: 1,556 Times
they shouldnt charge you for oil seals and gaskets. and remember they cost a lot.
Old 7th January 2012, 13:44   #22
vikram_d's Avatar
Thanked: 940 Times
I will end up paying about 3 - 4k from my pocket. After Maruti has been so gracious to give a new block without any argument, I don't think it is worth fighting over such a small amount.
Old 7th January 2012, 15:37   #23
autocrat's Avatar
Thanked: 538 Times
Frankly, there is nothing gracious about this, as the block should not be failing at 54k km . Dont accept to pay for the gasket and seals.
From my POV, they could not make a correct diagnosis. "Zero compression" can happen in all cylinders if the block has a horizontal crack running across, head gasket is blown at multiple places, or all pistons have blown or all valves are out of their seating position.
Such failures happen when the engine is running, but I cant believe it can happen on an engine thats shut down.
The only possibility that I can think of is that the block was hot, and if the car was washed with cold water (engine bay), the block might crack due to thermal shock. (for this too, i think its possible only when theres a casting defect in the block)
In any case, you should refuse to pay anything for this.
autocrat is offline   Reply With Quote
Old 7th March 2012, 18:52   #24
F150's Avatar
Thanked: 685 Times
what is the final update ?
Could you please update us ?
Old 7th March 2012, 19:27   #25
vikram_d's Avatar
Thanked: 940 Times
The final update on this is as follows
The A.S.S replaced the complete bottom half and left the engine for running in. After sometime one of the mechanics noted that the car was not running and it had stopped. So the engine was opened up once again and guess what? They found broken cam shafts, even though these were fine when they had bolted on the engine.
The net effect of all this chaos is that the car now has a complete new engine with no costs involved for me. Anyways since Maruti/Suzuki has done a great job without my even having to say a word, I have decided to put the incident behind me and get on with it.
The only drawback of this episode has been that since the engine is a new one, all engine service schedules have gone haywire and all oil changes are starting afresh. While they were at it I told them to replace the clutch also for which I paid. Car is back doing it's regular duties and feels excellent to drive.
So basically for me it is a case of all's well that ends well.
Old 7th March 2012, 21:18   #26
autocrat's Avatar
Thanked: 538 Times
Glad to know that you were not charged for this . Problem might have been camshaft bearings? Any post-mortem report?
Last edited by mobike008 : 8th March 2012 at 12:39. Reason: Please dont quote full post for a single line reply
Old 7th March 2012, 21:49   #27
F150's Avatar
Thanked: 685 Times
Awesome settlement I must say. You got a brand new engine, but the cause of failure is yet to be ascertained ?
Old 7th March 2012, 22:06   #28
Thanked: 2,403 Times
Any pictures?
Sutripta
Old 8th March 2012, 07:21   #29
vikram_d's Avatar
Thanked: 940 Times
Any pictures?
Sutripta
Sadly no pictures. I forgot my phone at home that day, but I was there when they opened the head and saw the broken cams.
Old 8th March 2012, 11:23   #30
im_srini's Avatar
Thanked: 398 Times
Exclamation Re: One for the Gurus: Dzire diesel - Zero compression on all four cylinders
The A.S.S replaced the complete bottom half and left the engine for running in. After sometime one of the mechanics noted that the car was not running and it had stopped. So the engine was opened up once again and guess what ? They found broken cam shafts, even though these were fine when they had bolted on the engine.
Two other cases of broken camshafts in DDiS diesels...
A) Dzire diesel with punctured sump (has pics of a broken cam) (Swift Dzrie Vdi Rightful Insurance claim denied - Beware of Royal Sundaram CHEATERS !)
B) To-be-delivered Swift diesel (Both cams broken on brand new Swift DDiS!)
im_srini is offline   Reply With Quote
Mission Leh! Four people, one scorpio and one helluva road trip! (Delhi-Leh Sep 2011) speed crusader Travelogues 15 11th July 2012 19:50
From 8 cylinders to 800cc and beyond : A Pune newbie Pragmites Introduce yourself 13 21st July 2009 21:46
Replica Veyron starting under $25K with 24 cylinders!!!! AyAn! The International Automotive Scene 8 29th March 2009 01:36
Swift Dzire Petrol Vs. Swift Dzire Diesel reveal_da_zeal The Indian Car Scene 2 4th April 2008 21:52
2 valves per cylinders devsus Motorbikes 4 17th April 2006 16:59
