Old 2nd January 2012, 20:32   #1
sharmaruns's Avatar
Unhappy Starting issue with my Ritz Vxi 2010
I am having an strange issue with my Ritz Vxi (20k), some times when i try to start it just crank for 1 second & then engine stops & repeats the same behavior until i press the race paddle along with turning the key . it happens even when i just came back to home after 10-15 km drive & try to start it within a minute.
25 % of time i have to press the race paddle along with turning the key to start the car. Can somebody suggest me the reason for this ??
sharmaruns is offline   Reply With Quote
Old 3rd January 2012, 22:35   #2
Thanked: 660 Times
Default Re: Starting issue with my Ritz Vxi 2010
Some sensor are definitely not working. Hook it up with a diagnostic tool at any service centre and get the error codes.
Hope you service your car timely, and all the vital consumables are in ship shape.
Old 3rd January 2012, 22:44   #3
Thanked: 14,602 Times
Could this be a problem with the fuel supply that is necessary during start-up may be not be happening in your causing it to switch and be normal when accelerator pedal is depressed slightly making way for fuel in the line or like Sir Alec has pointed out there could be problem with sensors.
Go to the dealer and get the OBD scanguage connected and clear out the errors and find out what it shows. Get it done soon.
how is the engine running otherwise? Jerks noticed or is it smooth?
Old 4th January 2012, 19:31   #4
white-rabbit's Avatar
Thanked: 35 Times
Try an ECU hard reset.it may help.
white-rabbit is offline   Reply With Quote
Old 4th January 2012, 19:38   #5
vikram_d's Avatar
Thanked: 940 Times
Turn the key to ignition mode, but don't start the car. You should be able to hear a faint whine of the fuel pump. Do you hear it? If you do hear it then wait till that sound stops and then try cranking your car without pressing the accelerator pedal.
vikram_d is offline   (2) Thanks Reply With Quote
Old 5th January 2012, 08:49   #6
sharmaruns's Avatar
Hello a4anurag ! The engine is running smooth & i dont feel any jerk till now. I'll catch the Service centre very soon.
Old 5th January 2012, 23:49   #7
dhanushs's Avatar
Thanked: 4,504 Times
Sounds like a fuel supply issue.
Check:
  • Fuel pressure in lines (remove the lines going to the engine, and turn on ignition, there should be enough pressure, and not just flow. )
  • Fuel filter (check for blocks)
  • Fuel pump (check pump pressure, clean if needed)
Technically, you shouldn't be giving any throttle input to start an MPFi engine.
Old 6th January 2012, 00:10   #8
S2!!!'s Avatar
Thanked: 9,280 Times
I too need to try 3-4 times to crank up the engine of my Ritz petrol but that is generally every morning. Is this normal?? And there are times when I too find the need to press the accelerator pedal to start it. (I guess this is bad so il try and take vikram_d's advice.) Will try it and revert back.
S2!!! is offline   Reply With Quote
Old 6th January 2012, 01:08   #9
vigsom's Avatar
Thanked: 604 Times
I think we are expecting the engine to crank on "half cell" (as used to be the case with warm carb engines)
My expeience with mpfi engines has been that you need to crank the engine for 3 secs before you expect it to fire.
and there is no need to ever use the accelerator to start a mpfi engine.
Old 6th January 2012, 21:04   #10
Thanked: 2,395 Times
Isn't the colloquial term 'half self' ?
ECU controlled engines take slightly longer to start because the ECU has to sync itself from the crank/ cam index mark. Not really noticeable until one is very particular.
Sutripta
Old 6th January 2012, 23:50   #11
vigsom's Avatar
Thanked: 604 Times
OT
"half self" it may be in most parts of the country where the starter is called the self starter or self motor
here since the starter motor is called starter, "self" is out and people say, "half cell" , "cell lagta hai kya?"
Old 8th January 2012, 12:38   #12
sharmaruns's Avatar
I tried the same (wait for 3 secs) & it works.
Now i don't have to press the race paddle to turn on the engine. Thanks a lot vigsom.
Old 8th January 2012, 15:35   #13
vigsom's Avatar
Thanked: 604 Times
^^ so happy for you.
sharmaji, peda kab khilaoge?(where are the sweets?)
vigsom is offline   (1) Thanks Reply With Quote
Old 9th January 2012, 12:11   #14
thoma's Avatar
Thanked: 1,112 Times
My friend's Ritz was having this problem of having a bit lengthy cranking, or else the engine would die off, even when hot. This is in complete contrast to the starting of my Chevy Beat (at least till 5k on the odo) where the very slightest of crank will whip up the engine (thanks to the ECU raising the RPM above 1k and then settles down to idle RPM after a good 30-40 sec) even upon a cold start.
Recently, my friend had complained the issue with the service center and they replaced all spark plugs at close to 20k kms on the odo in 1.5 year. As per his words, the issue is solved after the replacement of spark plug!
thoma is offline   Reply With Quote
Strange starting problem in the Swift VXI CANPUSH Technical Stuff 21 28th October 2014 13:23
2010 WagonR Vxi Vs Ritz Lxi EDIT: Its Ritz ! akshay Hatchbacks 24 25th July 2014 12:57
Ritz VXi Issue - Weird Odor on Redlining roadrunner_nv Technical Stuff 33 16th April 2014 13:59
2010 model wagon R Vxi or old model Vxi with discounts? drsnt Hatchbacks 9 20th June 2010 07:40
Safari DICOR LX starting issue, and some more tsk1979 Technical Stuff 19 13th October 2008 16:33
