Old 7th January 2012, 22:57   #16
Thanked: 2,404 Times
Default Re: Ritz VXi Issue - Weird Odor on Redlining
Don't think there is a 'culprit'.
Sutripta
Old 8th January 2012, 12:50   #17
changaez's Avatar
rodent is def not an issue for me... what i have observed that this happens at times when i go on long drives..... but the smell does not come every time i go for a long drive, although it comes only when i go on long drives.
changaez is offline   Reply With Quote
Old 10th January 2012, 20:45   #18
Thanked: 30 Times
@All: This is an update! Referred this issue to the Service Engineer at MyCar. Probably a catcon issue. Will be taking my Ritz for a change of the catcon under warranty.
Shall keep you guys updated on further developments.
roadrunner_nv is offline   Reply With Quote
Old 14th February 2012, 22:09   #19
changaez's Avatar
Any update on this, did you get the catcon replaced ? My service is due in the next months, so waiting for your update
Old 25th February 2012, 09:52   #20
Thanked: 30 Times
Extremely sorry for the late reply...was caught up with lots of work!
Update: Went to the Maruti Service and returned sorely disappointed. The so called service engineer could not smell the fumes due to a blocked nose; so he calls his supervisor who takes another off for another test drive. He returns and says that there is no smell. Then his works manager takes off and this time, I accompany him. Since I know how this smell actually comes up, I rip the car to redline and sure enough, the smell creeps in (a new point to note that the smell is not as strong as before).
This time, the works manager thankfully can smell the fumes so he gets out of the car and inspects the engine bay and tries to smell something there. Nothing in the engine bay; that is when I ask him to come to the rear of the car and smell the exhaust because that is exactly similar to the smell inside. He does that and offers the following pathetic explanation:
Works Manager(WM): "this is because of adulterated fuel. you must be filling in some sub standard fuel"
Me: Not at all, I tank up at Shell exclusively..In fact, I have all the fuel bills from day one.
WM: actually what happens is that sometimes unburnt fuel gets in the catcon and burns there (). this causes the platinum(another shock for me) inside to burn and this causes that smell. this will not happen in regular city driving but only when you drive so fast.
Me: But then, none of the other Ritzs or the other petrol cars have this smell.
WM: they might not be driving fast.
this is all I could do.
They take my car for service, put it on a lift and show me that there are no leakages to the exhaust system.
My car arrives a good three hours late from the service. A good part of this service is that the low end response of the engine seems to be miles better and she rushes past 100 in no time now. The fuel economy seems to have improved. Did not get the time to drive much after that. Shall post an update after my trip to Mumbai next week.
Net Result: Nothing
Old 26th February 2012, 07:04   #21
How many Kms has your car run?
To repeat, I don't think there is anything out of the ordinary.
Sutripta
Old 26th February 2012, 11:37   #22
Thanked: 30 Times
Sutripta
Hi Sutripta, my car has run for approx. 3K kilometers. Not much since I have two more cars in my garage that run most of the time.
Do you have any input on this?
Old 26th February 2012, 13:28   #23
SS-Traveller's Avatar
Thanked: 11,630 Times
...weird odor creeping in whenever I redline...
Common occurrence in lot of catcon equipped petrols. Can happen either when you accelerate sharply, or suddenly get off the gas to brake from high revs.
Originally Posted by VeyronSuperSprt View Post
The smell of the catalytic converter does not come out of the exhaust.
If it didn't, where would it come out of? In any case, it takes very little (less than 0.01 ppm [part per million]) for you to smell it.
Originally Posted by JustCause View Post
...a dead rodent in the exhaust...
...or roadrunner's friends celebrated the previous night by throwing rotten eggs at each other in the car!
Possible... Fouled plugs due to bad fuel reduces burn efficiency, leaving some of the fuel unburnt. Unburnt fuel goes to catcon => H2S.
WM: actually what happens is that sometimes unburnt fuel gets in the catcon and burns there...
When you step on the A-pedal, you dump some extra raw petrol into the cylinders, and not all of it burns; the remainder which is unburnt, ends up giving a burst of hydrogen sulfide when it reaches the catcon, and you smell H2S for a bit. When you let off the A-pedal, the engine overuns, which means raw petrol stays in the intake for a few moments after you let off the pedal (before the ECU can cut off the fuel supply). This could also happen because of an EGR malfunction (unburnt petrol does not get recycled into the inlet for complete burnoff).
EDIT:
...my car has run for approx. 3K kilometers.
Very relevant. New catcons make H2S more efficiently. Old catcons are fouled up over a period of time (generally due to poor fuel quality), and don't produce that smell with very small amounts of unburnt fuel.
SS-Traveller is offline   (2) Thanks Reply With Quote
Old 26th February 2012, 19:35   #24
Answered by
H2S production is normal. You are lucky that MASS did not remove your new catcon and replace it with an old one!
A detailed technical discussion as to why is not really relevant here. H2S will be produced. However, as I have said before, the fact that you can smell H2S inside a moving car needs to be checked.
One unlikely, but also very easy to check out item: check your air filter.
OT. Unlike others, I don't think there is any harm in redlining an engine, but I don't do it for the first tankful. What about you? And why the Ritz over the Swift?
Sutripta
Old 26th February 2012, 20:06   #25
Thanked: 30 Times
Answered by
Sutripta
The air filter is fine and I did not see any defect there.
I started redlining after a careful first 1200 km. The fuel in all my vehicles comes from Shell; even if it costs a bit more, it is still worth it.
I have a Ritz Diesel and am extremely happy with its ergonomics and to be honest, I love the way it looks. While deciding between the swift, dzire and Ritz, the Ritz became the natural choice for the aforementioned reasons.
An update: the smell seems to have lessened/disappeared after the service. Seems like my car was running rich. Will still comment on this once Im back from my Mumbai trip.
Thank you any which way for the analysis.
Old 26th February 2012, 20:59   #26
With usage, (=reduced catcon efficacy), the smell will reduce and then go.
Until and unless there is an explicit fault (except for checking the air cleaner), I don't think service can do anything about A/F ratio. Only thing left then is an occasional misfire.
Sutripta
Old 26th February 2012, 21:07   #27
Thanked: 30 Times
Sutripta
Im am yet to hear any misfire but for sure the engine sounds and performs better after the service. The economy seems to better too. Shall update this thread once Im back from Mumbai
Old 26th February 2012, 22:14   #28
VeyronSuperSprt's Avatar
Thanked: 1,664 Times
Yes, that exactly is the answer - .01ppm can be smelt from the exhaust linkages under the car.
Ironically, the “weird odour” is a sign that your cat is working properly. As mentioned earlier its hydrogen sulfide which does come indirectly from the fuel. The fuel contains organic sulfur compounds ranging from 30 to 100 parts per million, approximately. As the fuel burns, the organic sulfur compounds break down into simpler compounds. If the engine is running lean (more air than fuel), the sulfur is likely to be sulfur dioxide. The catalytic converter can change this into sulfur trioxide, which then reacts with the cat to form sulfates on it. There will gradually be a build up of sulfates. If the engine suddenly starts to run rich (not enough air to burn all the fuel), such as when you brake at a red light, climb a steep hill, or brake hard to slow down, there is unburnt fuel which reaches the cat and reacts with the sulfates. The sulfate reaction with the unburnt fuel starts forming hydrogen sulfide. This is the reason for the bad smell. This happens with new vehicles because the catalyst is working very well. However, as the car and the cat gets older, the efficiency drops and there will be no smell. This smell does not form in all new cars - one reason might be that the vehicle doesn't run lean for much time - no redlining .
VeyronSuperSprt is offline   (1) Thanks Reply With Quote
Old 27th February 2012, 00:56   #29
Thanked: 30 Times
Thank you for the detailed explanation. As I said earlier, the smell seems to have lessened/disappeared. Just came back from a brief + fast drive and the smell was not noticeable.
Your explanation chimes very well with an incident in my memory. A Chevy Beat that I was driving a short while back at Lavasa exhibited similar smell just before we reached the top. Seems like your explanation fits the missing piece in the jigsaw
Thanks again!!
Old 27th February 2012, 09:26   #30
...the smell seems to have lessened/disappeared after the service. Seems like my car was running rich.
The service centres have this quick fix solution of running the pressurized water hose into the exhaust (apparently to flush out carbon / deposits). Tap water is an excellent means to foul up the active catcon surfaces, but it also ensures that no more rotten smell emanates from your car.
Leaking Getz - weird issue - solved risga Technical Stuff 26 23rd October 2014 17:34
2010 WagonR Vxi Vs Ritz Lxi EDIT: Its Ritz ! akshay Hatchbacks 24 25th July 2014 12:57
Starting issue with my Ritz Vxi 2010 sharmaruns Technical Stuff 13 9th January 2012 12:11
Weird issue with Goodyear GT3 Tubeless Tyres XetaGLGRocks Tyre & Alloy wheel Section 22 4th February 2011 21:59
Pungent exhaust odor from my Wagon R johy Technical Stuff 17 24th June 2009 11:55
