| LinkBack | Thread Tools | Search this Thread |
| | #16 | ||
| BHPian Join Date: Jul 2011 Location: Gurgaon
Thanked: 35 Times
| Quote:
On your second question, that is the first thing I checked. When I pulled up at the MSS after an hour long drive, and raced for a while,the radiator fan was on. But the indicator is still showing 1/3 rd. Regarding Delhi / Gurgaon winters, this is actually a milder one as compared to a few past ones. While the car needs a little time to warm up, I have never seen this before. And I am quite particular about observing the performance indicators. In fact, it always used to be exactly at the half point -- and it has been 8 years with my beloved Wagon R now. Quote:
Note from the Team-BHP Support Team: Please use the "edit" button if posting within 30 minutes of the first post, instead of creating another back-to-back post. Also use "Multi Quote" option for quoting Multiple posts. Last edited by Rudra Sen : 10th January 2012 at 11:48. | ||
| | #17 | |
| Senior - BHPian Join Date: Feb 2006 Location: MAA
Thanked: 147 Times
| Quote:
Just to mention here - in the Marutis which had hard gauges(not the new gen LCD type) , like your Wagon-r , the temperature would generally be at 40-45% of full range viz. the needle would be a shade below half. | |
| | (1)
| | #18 | |
Thanked: 35 Times
| Quote:
| | #19 |
| Senior - BHPian | After driving for more than half an hour the coolant should be hot. Even if the gauge is not rising, please open the bonnet and check if the radiator is warm or hot. If it is warm, and with engine running the fan is also on, then definitely the thermostat is defective and should be replaced. If the radiator is hot, then get the gauge/sensor checked, it may be sticking beyond a point. Please note that an engine is designed to run at a fairly high temperature. A cold engine will consume more fuel, and combustion acids would accumulate faster in the engine oil. Modern radiator is semi pressurized and coupled with proper coolant should maintain a temperature of around 90 degree plus. Any thing less and it will be less efficient. |
| | #20 |
| BHPian Join Date: Oct 2011 Location: Noida/Coimbator
Thanked: 95 Times
| Mostly CTS failure. usually there are 2 sensors. Once for the ECM Fan control ( in your case this seems to work properly) The other one is for the gauge. The sensor could be covered in dirt or sludge making the reading less or the resistance could have increased due to bad wiring. so actually your CTS sensor reads half while your gauge sensor reasd much less. |
Similar Threads | ||||
| Over heating ikon | govigov | Technical Stuff | 10 | 29th July 2010 15:25 |
| Opel Corsa Sail 1.4 Engine heating problem. Please Help! | stevie | Technical Stuff | 15 | 19th January 2010 23:59 |
| Engine Over Heating | gopal.putrevu | Technical Stuff | 16 | 5th November 2009 07:25 |
| Ford Fusion - Engine Heating Problem | vij4all | Technical Stuff | 45 | 5th October 2008 15:41 |
