Old 20th March 2006, 16:25   #16
supremeBaleno's Avatar
Thanked: 1,705 Times
Originally Posted by speedsatya
how do you show off using the hand brake ????
i use both the gear and the hand brake when parking
I think he is mentioning doing the Handbrake turn.
Old 20th March 2006, 16:29   #17
n_aditya's Avatar
Thanked: 2,779 Times
i think he meant using it to do handbrake turns....
btw i use the parking brake while parking only....
Old 20th March 2006, 16:31   #18
n_aditya's Avatar
u beat me to the post by 4 mins... damn... i need to improve my multi-tasking skills....
Old 20th March 2006, 16:31   #19
ksethuram's Avatar
Absolutely. The wise combination is both handbrakes and putting the car in gear.
I personally never use the handbrake (unless parked on an incline).
Thanks, I will also start using both from now on.
How to do a hand brake turn? How is it different from a normal turn with little brakes?
ksethuram is offline   Reply With Quote
Old 20th March 2006, 16:36   #20
n_aditya's Avatar
hey sethu... dunno how u can manage this on ur new swift... can damage the handbrake assembly and ur tires....
anyway here goes... speed up and just yank the parking brake and swerve... u will achieve a nice slide.... take care to see that you have no bystanders and start this activity with low speed so you dont wreck ur car too....
have fun
Old 20th March 2006, 16:45   #21
Also use it to help pull-off from traffic stops in inclines without rolling backwards
jvedanand is offline   Reply With Quote
Old 20th March 2006, 16:56   #22
~~VinZ~~'s Avatar
Thanked: 7 Times
my hand automatically goes to the hand break wen i stop somewhere... in signal.. waiting for someone... parking ... etc...
u should be used to it wen u park the car mainly.. dunno who's goanna come and lean on the car rite? .. i've seen it in ma parking lot in office ...
this is how i go in parking ...
- break and stop
- Down gears to neutral..
- hand break..
- turn off ignition and then off...
- make sure the gear and hand break again and come out...
~~VinZ~~ is offline   Reply With Quote
Old 20th March 2006, 17:05   #23
hianooo's Avatar
Alllways !! with that "trrrrrrrr" sound !!
cheers
aNu
hianooo is offline   Reply With Quote
Old 20th March 2006, 17:14   #24
Use it everytime I park the car and the gears in neutral.
5u3zEr0 is offline   Reply With Quote
Old 20th March 2006, 17:17   #25
tsk1979's Avatar
Thanked: 16,420 Times
I use it while making U turns
heh heh just kidding
Its a habit to always use the hand brake while parking. I also put the car in gear and twist the wheel towards or away from curb when parking on a steep slope
Old 20th March 2006, 20:21   #26
Thanked: 61 Times
Smile Use them when going uphill .
I have mostly driven in the hills .
In trafic jams when you need to move the car by 1/2 a feet every time going uphill at aroung 45 degree of more.
Well i used to do it when I was learning to drive !!never wanted to break my tail lamps and head lamps of the guy behind me .
It can come in handy if you have never drivenin the hills . I have seen many people use the handbrake while starting the car uphill .
bhogalrajnish is offline   Reply With Quote
Old 20th March 2006, 23:01   #27
I use the hand brake quite often but forget to release it when starting the vehicle again :( What should I do?
rameshspassion is offline   Reply With Quote
Old 20th March 2006, 23:58   #28
SLK
SLK's Avatar
Thanked: 190 Times
So ... let me get this!
You park with Handbrake and in a low gear... the incline is so much that a LOW gear slips/ handbrake fails!
You really think a curb would stop the car?
Or even worse!... in such intense pressure your steering lock will also give way (if gear/ handbrake can!)... and tyres will be straight again and your car will race.
In Indian streets if you are to park parallel to the curb .... and turn your tyres fully.... someone’s going to hit them hard. (seen this happen so many times)
SLK is offline   Reply With Quote
Old 21st March 2006, 00:00   #29
50paise's Avatar
i use it everytime i stop the car
50paise is offline   Reply With Quote
Old 21st March 2006, 14:06   #30
Happens to lots of people. One option is to use the hand brake judiciously instead of using them always.
While parking on level surfaces, just ensure that you put the car in gear. Use handbrakes only on inclines / declines along with putting the car in the relevant gear (reverse gear on declines and 1st gear on inclines).
Blaring Music + Bad Driving = Does it go hand in hand!!! SamtheLeo Street Experiences 77 20th December 2014 20:41
Is a second hand Honda Unicorn worth buying for a year's use? rider60 Motorbikes 18 19th July 2014 23:30
Wise decision-First hand car or second hand car Surprise Hatchbacks 51 4th October 2009 20:04
help me choose for 60% highway use 40% city use nawabnabeel SUVs, MUVs & 4x4s 43 7th April 2009 17:48
Do you know whether your brake light is ON even when you are not braking? headers Motorbikes 31 12th July 2008 14:23
