Old 8th September 2007, 00:26   #46
esteem_lover's Avatar
Thanked: 451 Times
Originally Posted by rr_zen View Post
@e_l: Do you engage the parking brake with that 'kkkrrk' sound everytime ? I hold the release button even while engaging it so that my teeth are safe.
On the contrary, I have always loved to hear the krrrk sound, it is very reassuring. I will try holding the release button next time.
Old 8th September 2007, 01:36   #47
Thanked: 43 Times
I use them everytime I park the car. I even use them at traffic lights.
abhijitvp is online now   Reply With Quote
Old 8th September 2007, 02:10   #48
skandyhere's Avatar
Thanked: 89 Times
i use it only when the engine is still running at traffic lights. when i wait for long, and have the engine off, it suffices to have the 1st gear engaged.
of course, it's a parking brake. and i use it when parking too - inclined or not.
skandyhere is offline   Reply With Quote
Old 8th September 2007, 02:36   #49
Mav
Mav's Avatar
I also use it every time I stop the car .... either on signals or parking
Mav is offline   Reply With Quote
Old 8th September 2007, 03:11   #50
V-16's Avatar
Thanked: 862 Times
everytime i park before leaving the car and at lights on slopes.
V-16 is offline   Reply With Quote
Old 8th September 2007, 03:20   #51
payam's Avatar
i also use it everytime i park the car and when i stop it.
payam is offline   Reply With Quote
Old 8th September 2007, 04:15   #52
Thanked: 21 Times
Default always
i always use the handbrake whenever i'm stopped, even at signals, and like rr_zen i press the release button even while engaging so that the teeth don't wear out ..
revvhed is offline   Reply With Quote
Old 8th September 2007, 05:45   #53
i have always used the hand brake at every parking.
there are times when the parking attendant would request me not to engage the hand brake and leave the car in neutral those are the times i look for another parking lot.
doctorkats is offline   Reply With Quote
Old 8th September 2007, 06:39   #54
Thanked: 253 Times
Default confused
Originally Posted by supremeBaleno View Post
(reverse gear on declines and 1st gear on inclines).
Could you please explain why this needs to be the case.
Old 8th September 2007, 06:56   #55
Thanked: 253 Times
Default which hills are these?
Originally Posted by bhogalrajnish View Post
I have mostly driven in the hills .
In trafic jams when you need to move the car by 1/2 a feet every time going uphill at aroung 45 degree of more.
Which hills do you drive in my friend? 45 degree and more gradients??
When you are not reasonably sure of a figure, it is best to describe qualitatively rather than quantitatively.
Old 8th September 2007, 09:05   #56
devarshi84's Avatar
Thanked: 119 Times
I use it every time my car is not moving.
devarshi84 is offline   Reply With Quote
Old 8th September 2007, 10:25   #57
gd1418's Avatar
Thanked: 656 Times
Have you heard of counter-lock? If not here is the explanation: On a decline the vehicle is set to move forward and engaging a forward moving gera enhances the risk of a roll down. Vice-versa for an incline.
This has been the centuries old thumb-rule ever since something moving on 4 wheels was invented. Also on a decline or an incline you park very close to the kerb and turn the front wheels to the left & right respectively.
Old 8th September 2007, 10:51   #58
hydrashok's Avatar
I always use the hand-brake whenever I park, and whenever the car has to be stopped for more than a few minutes.
Old 8th September 2007, 11:15   #59
Thanked: 24 Times
Yes, I use the hand break everytime I park the car, first I pull the hand break and then put the car into second gear, have always wondered, what would happen if I park in a no-parking zone and my car is toed away, in that case, will the breaks go for a toss?
musicmanaman is offline   Reply With Quote
Old 8th September 2007, 11:27   #60
Thanked: 245 Times
Use the same concept as Gd described for inclines and declines. Use handbrake during traffic stops too, keep the gear in neutral then.
Blaring Music + Bad Driving = Does it go hand in hand!!! SamtheLeo Street Experiences 77 20th December 2014 20:41
Is a second hand Honda Unicorn worth buying for a year's use? rider60 Motorbikes 18 19th July 2014 23:30
Wise decision-First hand car or second hand car Surprise Hatchbacks 51 4th October 2009 20:04
help me choose for 60% highway use 40% city use nawabnabeel SUVs, MUVs & 4x4s 43 7th April 2009 17:48
Do you know whether your brake light is ON even when you are not braking? headers Motorbikes 31 12th July 2008 14:23
