Old 12th September 2007, 07:48   #106
muralisk's Avatar
I use it when ever I park the car, irrespective of the terrain.
muralisk is offline   Reply With Quote
Old 12th September 2007, 08:49   #107
Thanked: 253 Times
I don't know, but I would expect the cops are not within their jurisdiction to cause ANY damage to your car while towing it away.?
And what do they do with rear wheel drive cars?
anupmathur is online now   Reply With Quote
Old 13th September 2007, 18:09   #108
deepaktpatil's Avatar
Thanked: 93 Times
I use handbrake all the time when parking my vehicle apart from putting it in gear. Also at signals during afternoons when sun is blazing, I would like to keep the AC going so putting it in neutral and applying the handbrake relieves me from stepping on the clutch and brake.
Also in cases where starting on a upward slope and there is a possibility of car moving back for the fraction of the second while moving my foot from brake to lever, I apply handbrake.
deepaktpatil is offline   Reply With Quote
Old 23rd June 2015, 19:44   #109
Thanked: 117 Times
Default Re: Volkswagen Polo 1.2L GT TSI : Official Review
I have a question, i have seen drivers use hand brake extensively during those adrenalin filled powertrips. The driver's main intent of using the hand brake is to make the car come to a stop while gliding sideways (sometimes even backwards). My understanding is hand brakes are recommended to be used only when the vehicle is stationary. Is it alright to hand brakes in this manner ?
Mods: Couldn't find a better thread to post this question. If inappropriate, request this to be moved.
super.cars is offline   Reply With Quote
Old 23rd June 2015, 22:34   #110
MSC
MSC's Avatar
Thanked: 106 Times
Default Re: Hand Brake - Do you use it everytime ?
Definitely.
The handbrake is an inseparable part of driving. Yes, it may not be of much use in plains and big cities but in hilly areas like in Shimla or in Manali using a handbrake is a necessity owing to repeated stops in treacherous terrain.
MSC is offline   Reply With Quote
Old 24th June 2015, 01:22   #111
Turbo_Torq's Avatar
Thanked: 67 Times
Apart from the aforementioned relief, it also aids in reducing unnecessary clutch wear.
By 'powertrips' if you mean drifting then yes, the hand brake is used to initiate a drift although not much preferred.
It is a much simpler mechanism since it usually consists of a lever connected directly to the brakes using a cable. The stopping force created by this manual mechanism is far less compared to hydraulic or pneumatic-controlled ones hence they are to be used only in case of the latter's failure or in emergencies.
Turbo_Torq is offline   Reply With Quote
Old 24th June 2015, 10:07   #112
Thanked: 117 Times
Thanks for confirming heavy usage of handbrake while in motion is not preferred. I actually borrowed the term after i watched this video,
Blaring Music + Bad Driving = Does it go hand in hand!!! SamtheLeo Street Experiences 77 20th December 2014 20:41
Is a second hand Honda Unicorn worth buying for a year's use? rider60 Motorbikes 18 19th July 2014 23:30
Wise decision-First hand car or second hand car Surprise Hatchbacks 51 4th October 2009 20:04
help me choose for 60% highway use 40% city use nawabnabeel SUVs, MUVs & 4x4s 43 7th April 2009 17:48
Do you know whether your brake light is ON even when you are not braking? headers Motorbikes 31 12th July 2008 14:23
