Old 23rd June 2011, 08:40   #106
wild child's Avatar
Thanked: 141 Times
Default Re: What is the correct way to park on an incline?
[quote=vina;2402035]
Originally Posted by wild child View Post
What probably happened was that the friction offered by the reverse as not enough to prevent the start of the rolling (was barely enough, but may be something started it) - and once rolling started, friction reduces anyway (sliding friction is much smaller).
Did you try stopping the car and leaving it in the reverse again? - It probably wouldn't have moved.
that said - very bad idea not to engage the handbrake and rely on engine braking alone - you can do the other way round (no gear engaged) but not engaging the parking brake should not be attempted.
nope. i dint want to risk again as i would be away from the vehicle for quite some time . dint want to come back just to see it rolled off somewhere !!
wild child is offline   Reply With Quote
Effect of parking on slope/incline DCEite Technical Stuff 18 19th February 2017 19:54
WagonR complaining on parking lot incline Neeraj Dabake Technical Stuff 17 19th February 2010 20:21
Stopping on a steep incline? jp_in_hyd 4x4 Technical 22 22nd October 2009 17:28
Does engine CC / power matter for steady reverse on incline? patkim Technical Stuff 8 21st December 2008 16:31
