View Poll Results: Are you upgrading?
Yes- I will go in for the GC Upgrade kit 21 33.87%
No-Current set up suits my needs 41 66.13%
Voters: 62. You may not vote on this poll
Old 8th July 2013, 23:36   #91
akshay4587's Avatar
Thanked: 1,686 Times
Default Re: Official ground clearance upgrade package for Linea/Punto @ Rs. 10,000
Originally Posted by Pedaltothefloor View Post
Can you confirm the parts that were changed as part of the GC upgrade kit? I want to change the suspension of my Punto that came with high GC to the older/lower GC setup but the Fiat Service Center has advised me that only 4 struts + 1 Anti-Roll bar need to be changed. They are confident that the springs on both are the same. Could you please confirm?
I never went for the change,as my car does not scrape with the existing GC.
And GC upgrade screws ups the looks of a Linea.
Old 18th July 2013, 17:51   #92
harryms's Avatar
Thanked: 24 Times
Is better to go for a whole Tyre change when its worn out. 195/ 65 / r15 is the best option, this tyre will only give you better ground clearance without any issue. since this tyres width is same as the stock ones.
harryms is offline   Reply With Quote
Old 19th July 2013, 00:42   #93
akshay4587's Avatar
But the tyre may foul with the wheel well under full load
Old 19th July 2013, 14:34   #94
harryms's Avatar
Thanked: 24 Times
The stock tyres are 195/60/R15, my cars belly scraps when the tyre pressure is less than 32 PSI. its just only a few millimeter difference that makes the impact. I have done 35K KM now and if i can make a 1 cm in ground clearance that is enough for preventing the car's belly being scrapped, this upsize tyre will give 1 cm to the ground clearance.
If the 195/65/R15 foul when we have full load then the stock one (195/60/R15) will also foul when its full load.
Do you have any unpleasant experience with the 195/65/R15 tyre when the car is fully loaded. Kindly share your experience with us. Real experience can only make things refined.
thanks
Old 30th July 2013, 14:30   #95
Thanked: 604 Times
Can anybody please confirm if the pre-2012 models had an anti roll bar? The reason I ask this is because the anti roll bar is the same in old and new models, as per Fiat service center. So, my guess is that the older cars did not have any anti-roll bar at all.
Pedaltothefloor is offline   Reply With Quote
Old 3rd December 2015, 13:10   #96
Thanked: 15 Times
I got the height kit installed yesterday on my 95K, 6 year old Linea MJD.
The difference is very visible. The height increase and the stiffer suspension setup makes quite a difference. The overall feel of the car does change.
I needed the suspension change since it was nearing 100K and I am planning a trip to south india this month.
I do feel that a few parts were un-necessarily changed, but then the SA at Jay-Vijay is a pretty decent guy and I decided to trust him. Would love your inputs on the attached bill.
Official ground clearance upgrade package for Linea/Punto @ Rs. 10,000-linea_suspensionheightkit_dec2015.jpg
Ferrari1976 is offline   (1) Thanks Reply With Quote
Old 21st December 2015, 15:18   #97
Hi
I have a broken suspension on my 1.4 Fire Linea and considering the GC kit. The SA at Jay Vijay quoted that all parts (strut pads, link rod, bushes et al) had to be changed (the GC kit itself costs 13k which includes 4 shock absorbers and 2 coils). How was your experience, is there a way I can speak to you about this, I am in Pune as well.
kkarimyusuf is offline   Reply With Quote
Old 25th December 2015, 20:37   #98
Thanked: 15 Times
Originally Posted by kkarimyusuf View Post
Hi
Sorry for the late reply. My experience is excellent!! I am currently on a drive to Sakleshpur and it has been wonderful not to worry about the speed breakers even with a full car!! The raised height does look weird but serves the purpose very well.
We can continue the discussion on this forum so that it will be useful for others as well.
Ferrari1976 is offline   (2) Thanks Reply With Quote
Old 30th January 2016, 00:49   #99
Hrishi_111's Avatar
Thanked: 70 Times
Great to hear that !
Did you face any issues with ride quality after the kit was installed?
One of my colleague would like to get it installed on his pre-worshiped Linea and is in the process of approaching Jay-Vijay. However he is skeptical about ride quality post modifications.
Hrishi_111 is offline   Reply With Quote
Old 30th January 2016, 06:03   #100
GrammarNazi's Avatar
Thanked: 1,670 Times
I've installed the GC kit in my Linea since a year or so.
I personally don't find any significant difference in the ride quality or even handling.
Before installing the kit, I had added aluminum studds at the rear (cost just ~1.5k). That worked quite ok too actually. But it was a temporary fix IMO.
GrammarNazi is offline   (1) Thanks Reply With Quote
Old 30th January 2016, 08:45   #101
drdeepudev's Avatar
Thanked: 54 Times
Hi, I've installed the GC update kit on my 2009 Linea MJD around 3 months back. Post update, I would say I'm relieved. Speed breakers and potholes have become less scary. Regarding the ride quality, there is no marked difference. If I'm using the right term, I think it has become bit 'stiff'.
Since for me, GC was an issue earlier, I went for it and I would definitely recommend this.
drdeepudev is offline   (2) Thanks Reply With Quote
Old 1st February 2016, 12:40   #102
Thanked: 15 Times
Absolutely no issues, except that the suspensions now are a bit stiff, which is a good thing on our roads. Linea in those days had very very soft suspensions, resulting in "pitching" on braking. That has now completely been eliminated.
I also felt a small reduction in the turning radius after the suspension upgrade.
My only suggestion will be to check on what parts are really required to be changed for this upgrade. I believe Jay-Vijay changes a few parts which are not required to bump up the price.
Old 22nd June 2018, 18:02   #103
ak916's Avatar
Thanked: 146 Times
Reviving a very old thread
My pre-2012 is scrapping a little more than it used to. It has done 68k kms. I am thinking of increased GC kit. I was wondering if I should also change the tyres to 205/60/16 instead of 205/55/16. Anyone who has done this?
ak916 is offline   Reply With Quote
Optimum ground clearance of a Car? & how it is measured... skamb Technical Stuff 84 17th May 2017 22:36
Raising a Tata Marina's Ground Clearance vivek.singh.73 Modifications & Accessories 27 8th September 2013 21:43
Fiat Linea Ground Clearance Issue S.I.N.G.H Technical Stuff 55 28th October 2011 23:56
