| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| For the 1st time since last three or four fills I have started noting the FE of my car. Till now I always use to walk in and ask for 15 liters of diesel. That used to fill up the tank as afterwards the car's fuel gauge needle used to show FULL. Now since last 3 times I asked them to fill up till auto-cut. The first time I was mentally prepared to fill more than 15liters. However to my astonishment I have filled 10.098 lters, 11.038 and 13.29 liters respectively on these three occassions. On each of these 3 occassions the car had more or less run the same kms. Now I noticed two things,
Also, a more thoughtful matter is that if my observation is correct then the way we measure FE is also not very perfect as we now have a coefficient of fuel-foam factor in the equation. Think about it! |
| | #2 (permalink) | |
| BHPian | Quote:
In Madras, I almost always use only 1 petrol station (BP) and sometimes 2 others (both IOC). First tankful at odo reading 46 Latest tankful at odo reading 56416 Distance between tankfuls: 56370 km Fuel filled between these tankfuls: 5044.89 litres Overall FE: 11.17 kpl (which is what I quote everywhere) A/C is always on. My driving over this distance has been 90% city and 10% highway. I shift up at 15-30-45-60 for 2-3-4-5. I never switch off the engine or A/C at traffic lights or while waiting for someone in the car. Perfect? No. Consistent? I think so. What do others think?
__________________ 2003 March Tata Indica V2 LSi 89K km 1997 February Bajaj KB125 RTZ 48K km Last edited by hrag : 22nd March 2006 at 18:39. | |
| | #3 (permalink) |
| BHPian | See posts.. 309 to 319 here (What is your Actual Fuel Efficiency?) I still say.. Auto cuts.. are never consistent... whether same pump or not.
__________________ Č╠╣€€Я$ $£Қ |
| | #4 (permalink) |
| @hrag: Yes... you are right mostly. Except for one small fly in the ointment. That foam-factor I talked about. If the foam created is more, either because the height of the fuel pipe from the top level of the fuel in the car's tank, the speed at which the fuel is coming out from the piep, or for some other environmental factors the fuel filled may not exactly be what it should have been. Take this example. After the last tankful suppose I consumed 14 liters of fuel. Now when the second time I fill the tank the foam created causes the auto-cut to jump in at 13 liters... I get a feeling that I consumed only 13 liters for the distance travelled whereas the actual should have been 14 liters. This will also make me feel that my car is more FE than it actually is. And the cycle would continue. |
| | #5 (permalink) |
| BHPian Join Date: Oct 2005 Location: bangalore
| Auto cut-off is only a safety device to avoid spillage. At times just the fumes of the fuel may activate the trigger to shut down the flow to avoid spillage. You can always shake the vehicle a little and continue from where the fuel flow stopped. I don't think it has anything to do with your FE calculations, unless I have misunderstood your problem. For diesel vehicles no matter how much you shake the vehicle there is still a possibility of few air pockets. For perfect calculation, I suggest you fill your tank doing all these antics. Drive the car for atleast 2 Kms after your initial topup. You will be surprised to see it taking in another couple of litres. Now note down this reading. After having run the vehicle till your next fill, repeat the same process and note down the reading at your second topup. Its cumbersome alright but you can't get better perfection than this. My vehicle has a capacity of 60 litres. I run the car for about 300 kms each time and topup with about 30-35 litres every time. This gives me a fairly accurate picture of my cars condition. I have afuel chart, which gives me the entire history of the vehicle since it was purchased ( 3 years back) |
| | #6 (permalink) |
| BHPian | Auto cut off is only a safety device. I have this experience during one of my week end trips in a hired Tempo traveller.. Auto cut off kicked in at 5 liters on an empty tank, at a reliance station.. Reason, Filler in that van is located very far from the tank, teh driver told, it happens because some times the fuel comes up as the pipes can not swallow the fuel at the rate it is being pumped into by the nozzle. This could well be the case in cars too
__________________ _____________________ Stand on your head, upside down.. The world does not look any different, but you sure will look different! |
| | #8 (permalink) |
| Whoa! So already we have a new approach to calculating FE (as SOCCER wrote) and a corroboration to the fact that the auto-cut does not necessarily helps us to calculate the correct FE. @Soccer: The auto-cut is indeed used by most of us to calculate the FE of our cars. On a top-up to top-up basis. Basically after the top-up we drive some 200-300 kms and then again get a top-up. This way we assume that the liters that went in on the second attempt is the amount of fuel the car consumed for the kms travelled. Only that now I am finding out that when the auto-cut cuts in probably the tank could have easily taken in another couple of liters. Let it come guys... keep the ideas flowing ![]() |
| | #9 (permalink) |
| Senior - BHPian Join Date: Oct 2005 Location: Currently at Chennai. Originally from Blore.
| sometimes the auto cut off does not work.... on 2 separate occasions I had my tank overflow resulting in wastage of precious fuel.... the attendant sheepishly said sorry.... i made a scene and didnt pay for a litre.... i make it a point to always step outside my car and oversee the activity... if i was sitting comfortaly inside i would have been cheated... ![]() |
| | #10 (permalink) |
| BHPian Join Date: Jun 2005 Location: B'lore
| Another problem with the auto cut off is the fuel station guys using it to rig the meters. When the fuel pump cuts off automatically and when the guy starts the pump again you will notice the meter reading jump by about 3/4 of a ltr or sometimes even a ltr. |
| | #11 (permalink) | ||
| BHPian Join Date: Oct 2005 Location: Bangalore
| Quote:
| | #13 (permalink) | |
| Quote:
All of a sudden I am really worried... guys... its worrisome, considering that this is how we have been measuring the FE till now. We always believed that the best way to measure FE is on an auto-cut to auto-cut basis. In light of these problems it is obvious that auto-cut may actually be a very optimistic way of measuring the car's FE. Whaddya guys say now? | |
| | #14 (permalink) |
| Senior - BHPian | Zappo, I don't know about you but I've always asked the attendant to fill to the brim; this is to compensate the effects of faulty rigs, air locks in the pipe etc. How much of petrol goes in after the auto cutoff also depends on the vehicle - I know that in my Ikon, 5 to 7 litres ALWAYS go in after the auto cutoff, in the Fiesta 3 to 4 is what I've seen. In the light of the above (filling to the brim irrespective of auto cutoff), I have not faced any problem in accurately determining FE.....thats my experience
__________________ Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4 |
| Thread Tools | |
Similar Threads | ||||
| Best Maruti Service Stations in Kolkata ?? | abhisheksircar | Shifting gears | 5 | 19th December 2007 11:36 |
| Private Service Stations in Bangalore | pmbabu | Modifications & Accessories | 5 | 18th September 2007 13:40 |
| JMD Skoda Service - The best among Skoda Service Stations ? | normally_crazy | Indian Car Dealerships | 7 | 18th August 2007 10:14 |
| Looking for good Service stations in New Delhi | vebmetal | The Indian Car Scene!! | 1 | 31st August 2006 00:44 |
| Bajaj Auto is going for fuel injection | RoaringEngine | Motorbikes | 8 | 22nd May 2006 19:59 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
