Old 20th January 2016, 19:43   #46
Aston Singh's Avatar
Thanked: 161 Times
Default Re: Issues with my Maruti SX4
Originally Posted by Dr.Naren View Post
I received lower arm of SX4. I had ordered it online. Quality looks good and it is a direct fitment, saved 4.5k
Hey can you let me know the website from where you ordered this? I need to replace both front lower arms of my SX4.
Aston Singh is offline   Reply With Quote
Old 20th January 2016, 21:49   #47
Dr.Naren's Avatar
Thanked: 8,020 Times
http://www.motrpart.in/submodel/77/m...suzuki/sx4/zxi
Check for lower arm. You need to other both right hand and left hand side. I have posted the link of all spare parts available for sx4 in that website
Lower arm is same for ZDI and ZXI. But struts are different for petrol and diesel variants
Dr.Naren is offline   Reply With Quote
Old 20th January 2016, 23:46   #48
Thanked: 462 Times
Hi Aston Singh and Dr. Naren,
Why did the lower arms of your SX4 need to be replaced? I mean, did they bent or they cracked? What sort of damage was done to these?
Rahul Bhalgat is online now   Reply With Quote
Old 20th January 2016, 23:51   #49
Dr.Naren's Avatar
Lower arm was not bent or cracked. Mounting Bush had gone bad leading to kat kat sound on bad roads. Sad part is maruti doesn't provide only bush and should replace entire lower arm. I saved 4.5k by ordering online
Dr.Naren is offline   (2) Thanks Reply With Quote
Old 21st January 2016, 11:57   #50
Thanked: 161 Times
This is exactly the same problem with my car as well. Both bushes have a crack and at slower speeds there's "kat kat" sound on bad roads. Kinda spoils the drive if no music is playing in the car so better to get these replaced, especially at this price point!
Old 29th January 2016, 15:11   #51
Dr.Naren's Avatar
Hello buddy!!
Have you ordered lower arms for your SX4?I have run around 2000 kms after the installation without any complaints
Old 30th January 2016, 00:38   #52
straight6's Avatar
Thanked: 118 Times
Guys, please just fit the lower arms of a swift for this problem. They are 3k for a pair from MGP and they are an exact fit. I just did this and it works perfectly!
The SX4 arms are SGP and 12.6k a pair so you can use the swift arms 4 times if required .
straight6 is offline   (2) Thanks Reply With Quote
Old 30th January 2016, 19:08   #53
Thanked: 161 Times
Hello buddy!!
Hey Naren. I called up my local car garage guy and he said he'll get me the same thing, 2k a piece and charge around 800-900 for labor and replace both front lower arms.
The front kat kat noise is irritating and is more predominant at slow speeds. Once you pick up speed, the noise disappears.
I'm not able to take out time to take the car to his garage but hope to get it done soon. Will keep you posted.
Old 30th January 2016, 20:01   #54
Dr.Naren's Avatar
I find the labour of your local garage pretty high. I was charged only 200 rs in MASS. It should be 400 rs for both sides
Old 31st January 2016, 09:54   #55
Thanked: 161 Times
Oh surprising. I'll have a word with him. Will also check with MASS if they can fir the after-market lower arms.
Old 1st February 2016, 00:13   #56
Thanked: 462 Times
Interesting information straight6. Thanks.
Is the lower arm common for SX4 and Swift? Or it is not common but is interchangeable?
And how did you discover this information?
Old 1st February 2016, 01:07   #57
straight6's Avatar
Thanked: 118 Times
Its identical but most people don't know this. A friend with an automatic SX4 suggested this and when I went to the MGP store even the guy there confirmed this.
The mech confirmed that its identical. I asked him if the gauge was same to make sure it can handle the weight and he said yes. At the most the bush may last 2 years for eg. instead of 4 and it will still be cheaper to get these again.
Old 1st February 2016, 11:09   #58
Dr.Naren's Avatar
I was wondering why lower arms of SX4 cost a bomb compared to other Maruti models. Now it makes sense, thanks to SGP. Swift lower arm might be of same size, but what about strength? Can it handle the extra weight of sx4?(200 kgs plus)
Old 1st February 2016, 12:44   #59
Thanked: 462 Times
Post from straight6 gives me an impression that the lower arm is common between SX4 and Swift. In that case, we need not worry.
In the website that you suggested (motrparts), Swift lower arm is available for around Rs. 1500 and SX4 lower arm is available for around 2000-2200. So, if we are not sure about common part, better to order SX4 lower arm from motrparts. There is not much cost difference.
Old 1st February 2016, 16:00   #60
Dr.Naren's Avatar
Hello team,
I ordered front and rear shock absorbers TRW brand from motrpart. Front set 5200 rs and Rear set 3500 rs. I have read somewhere in forum itself that there was good improvement in handling for vento after TRW shock absorber installment. I will install after I run 1 lakh kms, current odo is 96000 kms
My New SX4: gears issues! agrawalankur Technical Stuff 29 11th August 2015 23:36
Maruti SX4 Delivery issues s3va Indian Car Dealerships 6 28th July 2009 16:51
Took SX4 delivery successfully and known issues/do's & don't sathya_nars Test-Drives & Initial Ownership Reports 1098 27th October 2008 23:17
sx4 delivery issues sathya_nars Indian Car Dealerships 32 25th September 2007 12:59
Suzuki SX4 or NHC type 1 second hand EDIT: SX4 now booked - EDIT 1 -Swift VDi booked GeekSrik Hatchbacks 126 24th June 2007 12:37
