Old 6th February 2013, 11:52   #16
kutlee's Avatar
Thanked: 194 Times
Default Re: Exhaust pipe for Mitshubishi Lancer
best thing, get the exhaust pipe out and get custom fabrication done using stainless steel. You can bend this to stock measurement on mandrel bending machine, tig weld and put back. I have done this and found to be really cost effective and should last for a while!
kutlee is offline   Reply With Quote
Old 6th February 2013, 11:58   #17
Thanked: 3,506 Times
Do the above, and in stainless steel it will be a lasting solution.
If you can't find a local fabricator contact automech or some custom exhaust manufacturer and ask if they can build one for you, in SS or MS (cheaper and rust prone).
Old 10th February 2013, 10:07   #18
Originally Posted by Smokeymist View Post
Hello Chewbecca,
According to me its not mandate that you go with the OEM part from a.s.s for an exhaust pipe for lancer instead consider replacing it outside. More over you will in queue for ages as the parts for lancer is just so scarce for a.s.s.! For all we know they might also sourcing it from third party
I replaced my stock exhaust pipe for my lancer from a workshop in Bangalore and it costed me around 2k for the replacement (abt an year back) and its absolutely fine, i don't notice any difference in notice or in the setup.
Hi Smoky/ Gokul
Can you please inform that particular Workshop name or other Similar workshops in Bangalore from where one can avail non-OEM Exhaust pipes ?
I will not be able to suggest any workshops from Mumbai though !!
Keep Revving,
Gokul.
Hi Smoky/ Gokul
Lightning2 is offline   Reply With Quote
Old 11th February 2013, 05:55   #19
Smokeymist's Avatar
Hello Lightning, I got it done at Shri mahalsa garage at BTM..this is just opposite to commerce@mantri,building's side entrance is BTM second stage. I also heard that carz on outer ring road also does this work but not very sure..
Smokeymist is offline   Reply With Quote
Exhaust pipe gets coated brown after a run. What's wrong ? di1in Modifications & Accessories 10 23rd March 2009 16:26
Leak in Exhaust pipe- Help leadf00t Technical Stuff 12 25th July 2008 11:31
Dark Greyish Smoke bellows from exhaust pipe Rahulk76 Technical Stuff 7 13th March 2006 01:06
2006 GSX R600 What's with that exhaust pipe? spdfreak Superbikes & Imports 10 3rd December 2005 05:08
exhaust pipe sideways bhp Indian Motorsport 6 5th March 2005 00:10
