Old 23rd February 2012, 13:38   #1
Thanked: 1,225 Times
Default Difference between Polo R Cup's 1.6 TDI and Vento/Rapid's 1.6 TDI
One obvious difference is that the Vento/Rapid's engine comes mated to a 5-speed gearbox (vs.) The Polo R cup's engine is mated to a 6-speed box
Itís also public knowledge that the Polo R cup uses a PiperCross Replacement Air filter as standard (in the regular air intake box), but that shouldnít affect power/torque too much.
But does anyone know if there are actual differences in engines b/w Polo R Cup's 1.6 TDI vs. Vento/Rapid's 1.6 TDI? (fuel rail / injectors, turbocharger, etc.)
From specs:
both engines are 1598cc, direct injection, common-rail, turbocharged & intercooled diesels
both engines have the same bore/stroke of 79.5/80.5mm
both engines use the same DOHC, 4 cylinders, 4 valves per cylinder setup
both engines use the same compression ratio of 16.5:1
both engines churn out identical torque figures of 25.5kgm @ 1500~2500rpm
The only noticeable difference I see on paper is:
The Vento/Rapid's 1.6 TDI engine is rated 105bhp @ 4400rpm (vs.) The Polo R cup's engine is rated 129bhp @ 4400rpm
Sources:
Skoda Rapid review, test drive - Review - Autocar India
VW Polo vs Polo R Cup car - Feature - Autocar India
I suspect the Polo R cup has vastly different ECU programming affecting various engine performance factors, but I wonder how the Polo R cup makes higher horsepower, but NOT higher torque.
Please share if you have more info.
kryptonite is offline   Reply With Quote
Old 23rd February 2012, 14:58   #2
nitrous's Avatar
Thanked: 285 Times
Default Re: Differences b/w Polo R Cup's 1.6 TDI vs. Vento/Rapid's 1.6 TDI
I've had a peek into the race car's engine bay.
That turbo definitely looked larger than standard.
nitrous is offline   (1) Thanks Reply With Quote
Old 23rd February 2012, 16:56   #3
jalsa777's Avatar
Thanked: 1,065 Times
It does run a stock replacement pipercross filter, but IMHO that would make only a nigligible difference it at all on the performance.
The Cup car runs the same engine as the 1.6 Vento. Absolutely stock.
Just the exhaust muffler has been modified to provide a slightly throaty note.
Only the tuning is different. The engine map was specifically created for the cup car and that is what results in the higher power figures. The map is built for power and engine life has been compromised. The Cup car's engine is only rated to run about 8000 kms AFAIK.
The RPM limit is around 4700 rpm and that I think its same as in the Vento engine. Thus, the torque has to be higher (because Power = Torque x Engine Speed). So, I feel its a mistake by Autocar that they have mentioned same torque figures.
jalsa777 is offline   (4) Thanks Reply With Quote
Old 23rd February 2012, 18:56   #4
Thanks for the response. Autocar does have their data right though.
Check this: Volkswagen Polo Cup India
To quote a snippet from that page: "The Volkswagen Race Polo which will be seen racing for the first time on the Indian tracks at the Polo Cup comes with a 1.6L R4 common rail diesel engine with an output of 130 HP@4400 rpm and torque of 250 Nm@ 1500-2500 rpm"
Old 23rd February 2012, 22:14   #5
Rehaan's Avatar
Thanked: 25,037 Times
Originally Posted by kryptonite View Post
... I wonder how the Polo R cup makes higher horsepower, but NOT higher torque.
Its because whats written on paper is PEAK torque.
After that point is where the differences begin! The Vento's toque curve starts to drop much more rapidly than the Polo R Cup car's.
To add some perspective to this : We can figure out how much torque was produced at 4,400 RPM using this formula (since we know the HP produced) :
HP = TORQUE (in lb-ft) X RPM / 5252
I drew this out on a graph, which makes it easier to understand :
cya
R
Rehaan is offline   (14) Thanks Reply With Quote
Old 24th February 2012, 08:09   #6
Thanks! makes sense.
Do you know if there are changes to any engine components, Or is all of this just accomplished through a re-map?
Old 24th February 2012, 11:48   #7
jalsa777's Avatar
Remap only. No change to any components
jalsa777 is offline   (1) Thanks Reply With Quote
Old 24th February 2012, 18:16   #8
Thanked: 1,077 Times
Default Re: Difference between Polo R Cup's 1.6 TDI and Vento/Rapid's 1.6 TDI
This is another case where only the peak torque has been taken for comparison, and not the torque spread.
The low end torque of the older diesels is similarly underrated. Older generation diesel cars exhibited higher torque at low RPM compared modern engines. So if you took the peak torque, they had poor figures. But drive them at low speed on steep bad roads and you are amazed at the performance.
Aroy is offline   (2) Thanks Reply With Quote
Old 25th February 2012, 00:29   #9
I didn't quite understand. Which context are you referring to? Please do elaborate
Old 25th February 2012, 13:14   #10
dhanushs's Avatar
Thanked: 4,504 Times
I think Aroy was pointing out the fact that, even though the older gen diesels had very low torque figures on paper, the driveability factor was much high, hence the practicality. ie, just having higher torque figures on paper (on a narrow rpm spread) doesn't matter much.
Torque, consistent over a wide rpm range should give better performance and practicality. That is what the remap has made the polo engine into.
In short: The more the area under the torque curve, the better.
dhanushs is offline   (2) Thanks Reply With Quote
Old 25th February 2012, 21:10   #11
Thanks for clarifying dhanushs, and for your previous response Aroy.
Yes, I do comprehensively understand the torque spread portion of the equation; one of the reasons why the Laura 1.8 TSI is that much fun to drive right from the word go - all the way till its redline ;-). I got momentarily confused in the middle about how older diesel tech is related to the Polo R cup's engine
BTW - if any of you are interested in looking at my Rapid's dyno graphs (Stock & +Tuning box maps), feel free to navigate from this index here in my ownership thread: http://www.team-bhp.com/forum/test-d...ml#post2595142
Appreciate the responses again, everyone! Thanks
Old 5th March 2012, 10:23   #12
Thanked: 21 Times
Thumbs up Re: Differences b/w Polo R Cup's 1.6 TDI vs. Vento/Rapid's 1.6 TDI
Representing this graphically, which makes it easier to understand :
Attachment 892953
cya
R
That is a really flat torque curve, even just 300 RPMs short of redline its delivering a lot of torque. I am not sure We'll be able to get all the details of a car designed for races but this kind of torque delivery might be something worth considering in large-ish cars where even a smaller capacity diesel might be enough.
needmorebhp is offline   Reply With Quote
Old 5th March 2012, 12:24   #13
Rehaan's Avatar
The graph in the post above is something that i drew myself.
Here's the actual Vento TDI power graph from the brochure :
Difference between Polo R Cup's 1.6 TDI and Vento/Rapid's 1.6 TDI-vento-tdi-capture.png
cya
R
Rehaan is offline   (1) Thanks Reply With Quote
Old 7th March 2012, 10:01   #14
oxyzen's Avatar
Thanked: 268 Times
As Rehaan has summed it up very nicely, same peak torque & higher peak power means that only top end is improved. Which is ideal since it is meant for racing. Till 3000-3500 RPM may be both the cars feel same. Anyone here has driven both?
The Polo cup with the extra bit of power & 1 extra speed (transmission) is one hell of a car I guess.
8000 Kms. Are you sure. Did you miss a zero by any chance.
The RPM limit cant be 4700. It is well above 5K.
oxyzen is offline   Reply With Quote
Old 7th March 2012, 10:21   #15
jalsa777's Avatar
I haven't driven the Vento, so can't comment on the first point. But the gearing is different and the gears would be more closely packed in (ratio wise) due to the six-speed box, so expect better usage of the available power.
Actually, we have never used anything above 4th gear on the Coimbatore and Chennai circuits.
AFAIK, 8000 kms it is. But I got to know this figure in a very casual discussion which i frankly don't even recall properly. But its in the where abouts for sure.
The RPM limit is 4700. Here's proof:
Name:  Polo R Cup_RPM.jpg
And look at the torque; we don't downshift even at 2000 rpm. The diesel mill just pulls cleanly from even that low an RPM. This gives proof of a pretty flat torque curve.
Vento / Rapid or VW Polo GT TDI Barron What Car? 66 15th March 2017 02:32
VW Vento Cup for 2015! Replaces the Polo Cup S2!!! Indian Motorsport 7 4th August 2015 16:29
