Old 17th May 2017, 14:47   #76
redcruiser's Avatar
Thanked: 197 Times
Default Re: AC vs climate control
Quick question- Will the load on the engine be more at a lower temperature say 18 degrees than at a higher temperature say 21 degrees?
redcruiser is offline   Reply With Quote
Old 17th May 2017, 16:13   #77
vikram_d's Avatar
Thanked: 936 Times
Quick answer - Yes.
vikram_d is online now   (2) Thanks Reply With Quote
Old 8th July 2017, 12:07   #78
King_pin09's Avatar
Thanked: 304 Times
Nope. The load will be the same. The duration up to which the load remains on the engine will be longer.
King_pin09 is offline   (1) Thanks Reply With Quote
Old 10th July 2017, 21:51   #79
Thanked: 57 Times
No, nothing like that. AC compressor acts as a parasitic load on the engine. If it's switched on, it IS switched on. Irrespective of what temperature your cabin is set to. If it's set to anything more than its minimum (for instance, 18˚C here), the amount of hot air getting mixed from the heater core varies.
If you remember the red-blue knob on a manual AC car, you will note that this knob has a distinct mechanical feel to it. This knob controls the amount hot air from heater core. Auto AC's just do this mixing automatically.
Car AC's work completely different from home AC's. In a split AC, when you set the temperature to 24˚C, your AC brings down the temperature from 40˚C on a summer day to 22˚C and switches off the compressor, keeping the blower running. After some time, as the temperature reaches 26˚C approximately, the compressor starts running.
vikred is offline   (2) Thanks Reply With Quote
Old 14th July 2017, 16:25   #80
ksameer1234's Avatar
Thanked: 466 Times
I have had totally contradictory experience with all the small hatchback I have driven. Small ones because it is very easy to notice the drop in power with tiny engines. When I turn on the AC, I can clearly feel the loss in power. Now when the cabin has cooled enough depending on the temperature knob setting, the AC is turned off and blower gradually starts blowing air of increasing temperature till when the thermostat trips again and AC is turned on. Is this not how it happens?
ksameer1234 is offline   (1) Thanks Reply With Quote
Old 14th July 2017, 16:52   #81
AkMar's Avatar
Thanked: 1,221 Times
Yes, this is how it used to work in out M-800. But with newer cars I doubt whether it is the same. Experiences with Swift as well as Xcent suggests that it doesn't work in the same way. Hot air mix is used to control the temperature as posted by vikred. That is why when I am alone, I keep temperature knob at lowest setting and manually switch on & off the AC to control temperature. This way I am sure that the compressor is definitely switched off after sufficient cooling is achieved, instead of it consuming fuel continuously.
Corrections welcome
AkMar is offline   (1) Thanks Reply With Quote
Old 21st July 2017, 12:04   #82
Thanked: 466 Times
After losing sleep thinking about how inefficient it would be to first cool air and then mix with hot air, I thought of going through the Owner's Manual for Tata Zest. Here's what it says:
Manual AC:
When AC is switched ON, engine idlingRPM increases marginally to adjust the AC compressor load.
When desired temperature is achieved AC trips OFF automatically.
For Auto Climate Control:
During ECON AC operation, the system automatically cuts off compressor at a higher temperature than normal AC.
I believe the compressor trips, at least in Zest just like home air conditioners. I suppose the mixing of air would happen in luxury cars where fuel economy is less important than passenger comfort.
I had a Swift owning colleague who would switch off AC manually while keeping knob at coldest setting. I told him that he can just increase the knob to warmer setting and it would have same effect. If things don't work as expected in Swift, I can only imagine him cursing me once he find out I made him lose out on fuel efficiency!!
ksameer1234 is offline   Reply With Quote
After-market climate control system? tsk1979 Modifications & Accessories 52 1st June 2013 20:33
Be a hero and Save the Climate at UN Climate Summit in Copenhagen December 19th serpente Shifting gears 0 27th November 2009 20:49
Climate Control Unit for the Verna CRDi tallkat Modifications & Accessories 12 17th August 2007 11:01
Swift ZXI Climate Control not working at 18C skiddyrow Technical Stuff 10 18th January 2007 14:56
Climate control Baleno VXi ! shuvc Sedans 30 23rd January 2006 15:55
