Old 8th December 2014, 21:33   #16
rajeev k's Avatar
Thanked: 1,750 Times
Default Re: '06 Esteem - Crankshaft bent?
It may not be a bent crank shaft, but the end where the pulley mounts would have damages and perhaps a mangled key-way. The free end can be checked for bend or run out with a dial gauge.
Repairing is possible with cold welding products in situ.
It could also be due to the distortions on the alternator mounting.
A good mechanic could fix it for you.
rajeev k is offline   Reply With Quote
Crankshaft problem rishirich27 Technical Stuff 32 11th December 2017 10:07
Hyundai Santro Xing - Crankshaft & engine repair/ failure-only 26000 Kms & 2 1/2years Murugan Long-Term Ownership Reviews 85 22nd April 2017 06:51
Esteem apron bent Hashim Technical Stuff 40 26th October 2012 20:22
Ford Fiesta 1.4 TDCI Crankshaft pulley (Damper Pulley) Born 2 Be Wild Technical Stuff 12 24th February 2012 17:13
Bent alloys drifter Tyre & Alloy wheel Section 16 22nd September 2004 00:10
