Old 27th February 2012, 09:02   #1
Default Zen Automatic : Safety mechanism
I recently bought a used zen automatic (2002 - MPFI). I need to know if there is supposed to be a safety mechanism that prevents from shifting gear lever (from 'P' to 'D' or 'R') without depressing the brake. Currently I am able to change without depressing the brake. Did Zen autos have this safety feature ?
Satish
satish.rpr is offline   Reply With Quote
Old 27th February 2012, 13:29   #2
Thanked: 103,537 Times
Default Re: Zen Automatic : Safety mechanism
Nope, the Zen has a vintage 3-speed Automatic that isn't equipped with that precautionary safety feature. You can change gears without pressing the brake pedal, though the button on the gear lever needs to be pressed when moving from P -> D.
Information source : Dippy (ex-owner of the Zen AT)
GTO is offline   (2) Thanks Reply With Quote
Old 27th February 2012, 15:48   #3
supremeBaleno's Avatar
Thanked: 1,709 Times
@GTO, if the button on the gear-lever needs to be pressed to effect a gear change, does it not mean that accidental gear shifts are avoided ? Which is what I believe is the query of the OP.
In our A-Star-AT, there is no such button on the gear-lever. But to move from P, brake needs to be depressed and also key needs to be in on position.
If key is not in, then for emergencies, one can shift gear position by depressing the small shift-lock button.
Old 28th February 2012, 14:23   #4
Forcing the brake pedal to be pressed is a much safer way. Reason:
- Only the driver can move the gear lever (as only he will be in a position to press the brake pedal).
- Say, you are on an incline. If the gear lever is unintentionally moved from P -> N, the car will not move (as the brake pedal remains pressed).
Whether it's forced or not, I consider it a best practice to engage the brake pedal before shifting positions on an Automatic.
GTO is offline   (1) Thanks Reply With Quote
Old 28th February 2012, 15:39   #5
ghostrider's Avatar
Thanked: 307 Times
+1 to this. Pressing the brake pedal on an AT is just a smart habit to inculcate. It adds a measure of control when you're on an incline and prevents someone in another seat accidentally (or deliberately) shifting the gear when they shouldn't.
Also... spoke to a friend who had an AT Zen back in the day, and he confirmed the brake pedal didn't need to be pressed when moving the gear selector.
ghostrider is offline   Reply With Quote
Old 28th February 2012, 15:45   #6
noopster's Avatar
Thanked: 9,597 Times
In my Vento AT you just need to lightly keep your foot on the brake to shift between gears. No need to depress fully or even hard. The safety button on the gear lever is for shifting between P and R, P and D and D to S. Moving from any gear to N is seamless.
I like this arrangement and think it's an extremely well-thought out one.
noopster is online now   Reply With Quote
Old 29th February 2012, 12:11   #7
Thanks guys. I think having the safety mechanism of depressing the brake fully is necessary to prevent accidental launch. I think we have this feature even in the gear less two wheelers.
Old 29th February 2012, 15:56   #8
Trueintrepid's Avatar
Thanked: 27 Times
Congrats on the buy! Just wondering what kind of price this AT cost you? I have looking out for a used Zen AT for some time now. It's hard to find a good one in Bombay.
Trueintrepid is offline   Reply With Quote
Old 9th March 2012, 15:23   #9
hmm.. I did buy this car from Bombay. I stay in Bangalore. I bought this car for my dad. I got it for 85K. I am sure you would be able to find one for less than a lac in Bombay.
Old 19th March 2012, 12:13   #10
shiju.dba's Avatar
Thanked: 12 Times
Hi Satish, its a deal for 85 K. Even I am trying to find an automatic car within that budget. Maximum around 2 lakhs. I am from New Delhi.
shiju.dba is offline   Reply With Quote
Electric locking & window mechanism. Boon or bane for Safety? rahul4321 Road Safety 62 29th August 2015 10:15
Automatic window closer mechanism vasoo Modifications & Accessories 24 10th June 2015 16:54
How effective is the auto-cut mechanism of the fuel service stations? Zappo Technical Stuff 35 27th March 2009 14:34
replaced palio starter mechanism bottle Technical Stuff 27 27th June 2007 20:59
Hydraulic Bonnet Opening Mechanism.How do i install nikibusa Modifications & Accessories 7 26th April 2007 13:40
