Old 6th March 2012, 02:27   #1
D33-PAC's Avatar
Thanked: 978 Times
Default What part of the engine is this?
I am guessing this is the air intake but I have never seen any air intake of such monstrous proportions.
D33-PAC is offline   Reply With Quote
Old 6th March 2012, 08:38   #2
ecenandu's Avatar
Thanked: 1,791 Times
Default Re: What part of the engine is this?
Yes, I think you are right. Looks like a naturally aspirated engine to me. But where is the throttle body,is it concealed inside those huge air intake(inlet manifold)?
ecenandu is offline   (1) Thanks Reply With Quote
Old 6th March 2012, 08:46   #3
Catalyst_delhi's Avatar
Thanked: 149 Times
That looks like aerodynamic fairing to me. That is just like the aerodynamic fairing in F1 cars.
Catalyst_delhi is offline   (1) Thanks Reply With Quote
Old 6th March 2012, 09:26   #4
ecenandu's Avatar
Yeah, you can call it that way also. An aerodynamic faring which helps the engine to breath better.
ecenandu is offline   (2) Thanks Reply With Quote
Old 6th March 2012, 09:48   #5
jalsa777's Avatar
Thanked: 1,065 Times
This is the airbox assembly. It usually houses the air filter, intake manifold, throttle body/s and runners.
The car will have an engine cover, so this part does not need to aerodynamically efficient, but it takes takes the shape of the required intake manifold and other components.
jalsa777 is offline   (3) Thanks Reply With Quote
Old 6th March 2012, 11:17   #6
D33-PAC's Avatar
Thanked: 978 Times
@ Jalsa777 , What are runners?
@ecenandu, I looked up aerodynamic faring on google, as I don't know what it is. If it is just cosmetic modulations to improve air flow over an automobile, then how does it matter in this case as it will be covered by the body.
Old 6th March 2012, 11:22   #7
jalsa777's Avatar
Runners are basically pipes which flow from the intake manifold (airbox) to the intake ports on the engine head. The length and diameter of the runners decide the velocity and pressure of the air flowing into the the engine and thus affect the power and torque characteristics of the engine.
A slightly technical discussion can be found here. Its a good read though.
You are right about aerodynamic fairing. But as I pointed out in the previous post, in this case it won't have any effect because the engine bay will be covered by the body
jalsa777 is offline   (1) Thanks Reply With Quote
Old 6th March 2012, 11:40   #8
ecenandu's Avatar
Yes, you are correct one cannot call it as a aerodynamic fairing. And the link posted by Jalsa777 is a good read.
ecenandu is offline   Reply With Quote
Polaris Slingshot: Part car, part motorcycle, all excitement ashkamath The International Automotive Scene 0 2nd September 2014 17:12
Paint spots in engine bay of a new car? Part of QC! MK3 Technical Stuff 12 5th April 2011 08:24
Palio Stile MJD -- Technical Info needed on an Engine Part(Changed under warranty) funkykar Technical Stuff 10 20th September 2010 21:11
RTO Formalities for Engine change in Kerala (XDP4.9 engine to the XD3 engine) 4x4addict Modifications & Accessories 16 14th April 2009 21:51
