Old 27th March 2006, 22:09   #1
kooldude's Avatar
Default pcd of esteem
guys can anyone tell me what is the pcd of esteem
eg honda has 100 n ikon has 108
kooldude is offline   Reply With Quote
Old 27th March 2006, 22:34   #2
S@~+#0$#'s Avatar
Thanked: 37 Times
The PCD on the esteem is 114.3. Not too many other cars have this PCD except the Zen and the 800.
S@~+#0$# is offline   Reply With Quote
Old 28th March 2006, 00:43   #3
adit1329's Avatar
esteem has 114 pcd.
you would find it difficlut to find alloys if you are upsizing.
preferably go for multipcd alloys
adit1329 is offline   Reply With Quote
Old 28th March 2006, 15:40   #4
Thanked: 96 Times
Wink not rare at all!!!!
Originally Posted by adit1329
esteem has 114 pcd.
That aint true, the 114.3 PCD is as available as the rest and i know that cuz i was shopping for alloys for my car recently!!
Aura, Neo, League, Plati, HR all have wheels with the 114.3 PCD......
Edmund is offline   Reply With Quote
Old 28th March 2006, 16:59   #5
tsreekaranrao's Avatar
Sorry to ask but what is PCD,. I discovered it is something to do with the rims but what does it mean
tsreekaranrao is offline   Reply With Quote
Old 28th March 2006, 17:19   #6
Thanked: 96 Times
What does PCD mean?
PCD stands for (pitch circle diameter), this is the diameter of a circle drawn through the center of your wheel's bolt holes. PCD is measured in millimetres and also indicates the number of studs or bolts the wheel will have. The most common fitment has 4 studs with a PCD of 100mm, hence the fitment 4x100.
4-Stud PCD
5-Stud PCD
Old 28th March 2006, 17:25   #7
adit1329's Avatar
when i looked for my esteem, i found it difficult....
you do get multi pcd in abundance..in limited models
you do not have a vast range to choose from. also single pcd is difficult
Old 28th March 2006, 17:51   #8
What does PCD mean?
4-Stud PCD
5-Stud PCD
Thanks for the explanation edmund
Swift rim PCD !!!!! kpzen Tyre & Alloy wheel Section 6 21st January 2006 14:12
PCD for a Mahindra Classic Salikt Tyre & Alloy wheel Section 6 20th October 2005 20:40
Optra Rims PCD and Offset help! iceman-kimi Modifications & Accessories 22 27th September 2005 20:49
PCD :: Expert advise please.. DRC Tyre & Alloy wheel Section 12 22nd September 2005 17:44
Toyota Qualis, what's its PCD? riffst3r Technical Stuff 1 22nd February 2005 20:50
