Old 18th March 2012, 17:06   #16
Neil.Bhujbal's Avatar
Thanked: 59 Times
Default Re: Basics of Intake Length vs Torque-HP
Originally Posted by Tejas Ingle View Post
Hey Neil! Looks like you are playing with the Variable geometry intake. Thanks for bringing up this thread. Will stay tuned. See if you can find out a way to play with these lengths.
Hey, Just related the variable intake manifold theory with fixed length one & put up a simple explanation
Neil.Bhujbal is offline   Reply With Quote
Old 18th March 2012, 22:51   #17
Top gear's Avatar
@Sutripta It would be great if you mention the books related to these, i am very much intd in knowing the author names (pdf, download links any >)
Will be searchign for this tread daily from now
Bread and butter for the tuners. Maybe moving it to the Modifications section would elicit more responses.
In a nutshell, correct. (except for reflection starting from throttle plate. Any discontinuity will generate a reflection. The reflection from the open end is likely to be stronger.) And better to start with the exhaust than inlet.
Thank God we are not getting into two strokes.
Plenty of books on the subject.
Sutripta
Top gear is offline   Reply With Quote
Old 19th March 2012, 21:31   #18
Thanked: 2,407 Times
For starters
Sutripta
Altering pedal length (clutch, brake, accelerator) for comfort MaNishi Modifications & Accessories 5 26th November 2013 20:13
file length problem Akshay1234 Gadgets, Computers & Software 3 12th June 2009 16:07
Headphones length Gagan.js Gadgets, Computers & Software 11 13th May 2009 22:57
Diffrence between an ordinary cold air intake and a ram air intake?? Vys De BlUR Technical Stuff 24 1st April 2008 12:59
