Old 16th May 2012, 09:16   #46
deetjohn's Avatar
Thanked: 8,008 Times
Default Re: Radiator Fins Bent - any solution?
Like i said its the AC condenser fins which are bent, the radiator fins would be alright as its behind the AC condenser.
I had somehow missed this post. Yes Sankar, you're right. It is indeed the AC condenser. In the Swift, the radiator sit smug behind the condenser and both are of same length and breadth, but different width. I feel so stupid.
We picked up a used A-star recently. The bending is far worse in that.
So the condenser is in the firing line protecting the radiator. But that is not very comforting, is it? MSIL will do well to give a factory fitted mesh behind the grille.
deetjohn is offline   Reply With Quote
Old 16th May 2012, 10:30   #47
Sankar's Avatar
Thanked: 4,654 Times
In the case of my car i have no on else to blame but me for causing the bent condenser fins. I accidently sprayed high pressure water from the Bosch Aquatak on to the condenser fins a moment before i realised what i was doing. By that time some fins were bent.
Old 22nd May 2012, 03:08   #48
Raccoon's Avatar
Thanked: 105 Times
I think Raccoon was referring to the grille on the bumper. A mesh behind the grille will help against flying stones. Time to get in touch with josepeter I guess.
Though, the cost that you mentioned for the intercooler is comforting. Any idea how much is the radiator? And will the aftermarket parts from MASS be as good as the factory fitted ones?
I am not much worried about the damage currently. But just wondering what extent of bending can be tolerated, if I don't install a mesh. I do quite a bit of highway runs.
I was of course referring to the grille. Shame that Maruti has provided such a widely spaced grille! At least on the Esteem its not so widely spaced. And I don't see any damage that could have been caused by flying debris from the front on my car at least. Whatever damage I have written about earlier has surely been caused by something else. Most likely #!&*#@ mechanics.
I'm not too confident about after-market parts quality from MASS. I'v observed in more than one occasions that its not at par to what has been fixed at the factory. But what is a much bigger concern is how shabbily the MASS mechanics may do the job of replacing it.
Raccoon is online now   Reply With Quote
Old 23rd October 2016, 09:52   #49
Use this for straightening the fins.
But i've never heard of a case where bent fins were the culprit for overheating.
Attachment 905936
A good way to make this tool would be to buy a hair comb with teeth spacing matching the fins. Cut the end tines off and you have a combing tool for your radiator fins as well as for the home AC.
Mind you, the radiator needs a larger comb thean the home AC.
Hope this helps.
Astrobufff is offline   Reply With Quote
Car Rust - Any Solution? druva Technical Stuff 20 5th March 2018 07:50
Carbon Deposits - Any commercial solution ? absynthguzzler Technical Stuff 20 12th February 2012 05:02
Dogs tear off TYVEX car cover. Any peaceful solution ? lambuhere1 Street Experiences 16 25th August 2009 09:05
Hyundai Dealer Not providing any solution to my problem sumit_jain_usa The Indian Car Scene 11 9th June 2009 15:08
Any Solution To Versa's Bad Lights?? vigsom Modifications & Accessories 5 1st March 2006 17:55
