Old 31st March 2006, 19:29   #1
cooldude1988765's Avatar
Thanked: 106 Times
Talking Esteem D to CRDi
We have an esteem diesel and the engine is almost dead. Well i got a crazy idea of changin the TUD5 to the CRDi engine from accent.
If i could fet the engine and other parts required can I go ahead with this project ???
How much will it cost And most importantly will the Crdi engine will fit in the esteem bay ??? What other modifications should be done considering that the engine does fit into the car???
Has anyone ever done this before ???
Need help as soon as possible!!!
THANKS IN ADVANCE .................
cooldude1988765 is offline   Reply With Quote
Old 31st March 2006, 19:33   #2
jkdas's Avatar
Thanked: 1,389 Times
is it worth? gonna be a tough mod or we would have seen many esteem crdis. and i guess crdi engines should be costly
Old 31st March 2006, 19:48   #3
Thanked: 106 Times
I have my friend's accident car in mind engine is undamaged (lorry hit the rear) but the car is totally smashed
Old 31st March 2006, 20:03   #4
jkdas's Avatar
i think that insanedevil was gonna do teh same transplant; but not to an esteem. pm him na
Old 31st March 2006, 20:26   #5
Thanked: 106 Times
Thanks Jkdas I just pmed him
Old 31st March 2006, 20:32   #6
Thanked: 1,503 Times
Sounds wicked, cooldude..........all the best! Dont forget to add Pete's box to it too.
Steeroid is offline   Reply With Quote
Old 31st March 2006, 22:43   #7
v1p3r's Avatar
Thanked: 26 Times
You will need new custom engine mounts. You will have to mate the flywheel of the CRDi to the gearbox of the Esteem, or get a CRDi box itself. You may want to go with the Accent box, since I'm not sure if the Esteem one can handle the torque. Better front suspension would be necessary. I'm not sure who can do this in HYD, but there are enough people in BLR to do the job (Psycho, Scan, Dom etc).
If you get a good install, put Pete's stuff on. You will be killing Esteems and also getting close to 17kmpl with decent driving!
ps. you will need to worry about turbo and intercooler mounting too.
Old 31st March 2006, 23:24   #8
kb100's Avatar
Yes... Its a messy affair (have you seen the two engine bays!!) but once done you WILL rock!
Oh Yes!!... get it PETE-ED ...
kb100 is offline   Reply With Quote
Old 31st March 2006, 23:54   #9
Thanked: 106 Times
Hey v1p3r how much will the whole install cost ??? Any idea
Old 1st April 2006, 14:31   #10
garvit2002's Avatar
if possible it can be done but it will surely cost you very much and and i think you will have niggling small problems everyday
garvit2002 is offline   Reply With Quote
Old 3rd April 2006, 19:40   #11
CaliforniaKnight's Avatar
Thanked: 35 Times
If the project is succesful, it will definitely rock. Feel the car be driven in 1 single gear the whole day long....knowing the torque you get in the Accent CRDI engine and the esteems ultra light chassis...you will need to stiffen a lot of components and of course don't forget the BRAKES.
CaliforniaKnight is offline   Reply With Quote
Old 4th April 2006, 01:25   #12
Psycho's Avatar
Thanked: 95 Times
Personallyt i feel that it is going to be a very tight fit but is a good idea to try...
Old 4th April 2006, 07:55   #13
Thanked: 106 Times
So the main question is If the project is successful will i be able to use it everyday?
The TUD 5 engine has covered a lot of distance in these 3 years and if revved above 2k rpm the exaust sounds like a padmini !!!!!
Finally no one mentioned what the cost would be like.
Old 21st April 2006, 13:19   #14
Thanked: 12 Times
Lightbulb
Howmuch will teh crdi engine cost..
zulfikar is offline   Reply With Quote
Old 21st April 2006, 14:14   #15
jkdas's Avatar
Looking at 1lac plus I guess. Just a guess as teh engine should be hard to find
Esteem fuel pump(mpfi) in esteem-carb tank techn0l0gist Technical Stuff 0 13th June 2009 22:03
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
Zen, Gypsy and Esteem to get CRDi engines soon GTO The Indian Car Scene 6 24th May 2004 18:30
