Old 4th April 2006, 18:01   #16
Zappo's Avatar
Thanked: 2,080 Times
One thing that I can now see is that this is a widespread problem. Well.... and I am sure it comes from all cars. Even my new Indica makes this noise from the rear tires. And this has been there since the very beginning. Somehow I never thought it serious enough to worry about it. As I realized though is that the sound is more pronunced / I realize the sound only when I am passing by a flyover or a divider or a wall. Anything that reflects the sound back at me.
I have never been able to figure out why it always comes only from the rear! Also, what exactly makes this sound. One tentative reason I feel is the mud flap. It actually flaps due to the draught of air that rushes backward and hence makes that tic-tic/ cluck-cluck/click-click noice. If you take a small semi-rigid rubber piece and try to fan it I think it will also make almost the same noise.
Zappo is offline   Reply With Quote
Old 4th April 2006, 19:35   #17
v.tec's Avatar
Thanked: 16 Times
ok people..solved...there was a huge..and i mean huge screw stuck in the tyre...which was causing the noise..the screw was as big as around 2 cm in radius...the noise is gone now....
thanks a lot guys...:-)
v.tec is offline   Reply With Quote
Weird squealing/hissing noise from the back srinath_mys Technical Stuff 4 24th May 2010 20:38
Humming noise from rear left in '98 Cielo GLX after tyre change VSG12777 Technical Stuff 18 13th April 2009 10:31
Swift : weird noise during gear change manjubp Technical Stuff 10 6th February 2008 21:11
