| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Jun 2005 Location: Bangalore
| ok heres a question thats had me by the b*lls the whole of today.. my friend has a old honda city vtec whose exhaust pipe got neatly chopped of just before the muffler.. by neatly i mean there are no obstructions to the flow, so its become a kind of illegitimate free flow system.. here is my question... is this gonna aid or hamper the performance figures? the way i see it there are 2 possibilities (duh) 1) the performance will improve because it is now a free flow exhaust system so the engine doesn't need to contend with back flow blah blah... 2) the performance will fall because teh engine management system has been configured to work best with the old specs of the car, ie with a fully functioning muffler... but here is the catch.. then main aim of an ECU is to adjust the various parameters of the engine in accordance with changes the engine is forced to contend with(which in this case is the exhaust) so as to keep the engine as efficient as possible... so the ecu shud theoretically adjust the engine parameters and hence make the best possible power/torque etc.. see wot i mean by by the b*lls??
__________________ V-6 ours one Last edited by superunknown : 5th April 2006 at 18:23. |
| | #2 (permalink) |
| BANNED Join Date: Feb 2005 Location: Mumbai
| I think you should ask for your b*lls back. Just cutting off the muffler doesn't make it a "free flow". Do some searching on the site and you'll get enough info on what a free flow really is. And yes, a car without a muffler is a very bad thing. |
| | #5 (permalink) |
| BHPian Join Date: Mar 2005 Location: Minneapolis
| It will be just noise and not a tuned sound, and total loss of low end torque. The -ve terminal of the battery needs to be disconnected for a few minutes or the ECU to be reset which will allow the ECU to start recalibrating again.. but again as I had mentioned earlier ..it will be only be a loud racket nothing close to a tuned sports exhaust.. u need to mod headers also... etc etc |
| | #6 (permalink) |
| Senior - BHPian | Your "free-flow" still has to contend with the catalytic converter, which is a major obstruction to the flow. That alone is worth 5 bhp on the old Vtecs. But once the cat is removed and you have a straight pipe from the valve to the cut-out, it should be interesting. With a well-designed set of headers, you would have minimum back-pressure leading to a centre/side exhaust. Which is basically what some of the drag cars are running.
__________________ I've lost my phone. Please PM me your phone number if I'm on your contact list. |
| | #7 (permalink) |
| ok i see some posts and i have answers..not exaclty wot i was looking for but neway.... boom shiva - "a kind of illegitimate free flow" system is NOT a "free flow" system, but thanks for the advice on reading up tbhp for further info-the thought would have never crossed my mind secondly this happened by mistake to a car ive never seen/driven so no im not trying to be smart and get more performance from a vtec by cutting the exhaust v1p3r, i do understand that the cat will still remain as a source of power loss, but what i wanted to know is if the ecu of the car will be able to adjust for the free-er flowing exhaust gases(NOT FREE FLOW EXHAUST lol!!) as the muffling action( what ive coem to understand is nothing but bouncing back and forth of the gases in the muffler to get harmonic balance with exhaust valve opening) will be eliminated.. chetanand-wont the ecu be able to adjust on-the-fly, cant removing the muffler be compared to say decreasing the outflow of gases(reducing back pressure) in conditions such as idling?.. or do i haev another tbhp bashing coming my way ![]()
__________________ V-6 ours one |
| | #9 (permalink) |
| Senior - BHPian | For the ECU to adjust anything, it would have to be valve-timings. This would affect the whole combustion cycle. And it would also mean that the ECU has to have some sort of a pressure sensure, which I'm not sure exists on the OHC Vtecs.
| | #10 (permalink) | |
| Quote:
| | #11 (permalink) | |
| Quote:
1] ECU knows when the engine is idling, the TPS tells it that your engine is idling. The IAC motor/valve comes into picture and the job of ecu is to keep the engine just breathing and not worry about other params. 2] But when you are speeding at WOT , the ECU again knows what is happening and starts communicating with a different set of sensors and controlling different valves etc and not even bother about AFR 3] similarly at mid range the ECU is doing something else ..worrying about the AFR .. and stuff like that.. So if u have a low backpressure exhaust, there is greater flow of intake charge during exhaust stroke (due to valve overlap)... that means ECU will have to step up and make corrections to mantain AFR , EGR, timing etc etc tect etc .. FYI .. this is just a basic introductory description of what is the difference in backpressure to a ECU at idling and backpressure at different load conditions.. (AFR is just one parameter ..there is a combination of multiple other parameters also in the picture) | |
| | #12 (permalink) | |
| BHPian | Quote:
__________________ I cried coz I had no turbo, till I met a man who had no VTEC!!! | |
| | #13 (permalink) | |
| Senior - BHPian | Quote:
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) | |
| Thread Tools | |
Similar Threads | ||||
| Sidewall cut on Good Year Eagle NCT 5 | sportive_guy30 | Tyre & Alloy wheel Section | 29 | 9th October 2008 19:11 |
| Filters more good than bad?? | JayD | Modifications & Accessories | 1 | 20th October 2007 10:42 |
| exhaust noise from nhc vtec | hellspawn | Technical Stuff | 1 | 3rd March 2006 18:44 |
| Why is the OHC Vtec exhaust muffler different? | jigarmuni | Technical Stuff | 27 | 10th May 2005 10:24 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
