Old 9th May 2012, 16:06   #1
Default Esteem tyre touching the mud flap
I have a 2004 Esteem. I have been using 185/60/14 tires for my esteem, and was running really well, until recently. Off late, when i do sharp turns, or when there is a bumpy road, the tyre touches the inner body or the mud flaps. This happens only in the front. I have had these profile tires since 3-4 yrs, but i am facing this issue from over 6 months now.
I do wheel balancing and alignment every 4000 - 5000kms regularly. I even changed my lower arm as well, but of no use.
kari is offline   Reply With Quote
Old 9th May 2012, 18:08   #2
Jaggu's Avatar
Thanked: 8,692 Times
Default Re: Esteem tyre touching the mud flap
Time to get the suspension checked, the parts are aging especially the springs and might be sagging while compared to when you put the wider tyres? Do rule out a displaced wheel well trim or mud flaps first.
Jaggu is offline   (1) Thanks Reply With Quote
Old 10th May 2012, 09:37   #3
SS-Traveller's Avatar
Thanked: 11,630 Times
Check the following and replace as necessary:
1. Check to see if the wheel arch core and mudflaps are fitted & aligned properly;
2. Replace the rubber kit of the front struts;
3. Change front coil springs if they appear to be more shortened than new original springs in an uncompressed state - or you might want to try out these (Coil Spring Adjusters : VFM Fix for the Honda Civic's (lousy) soft rear suspension?).
Old 10th May 2012, 10:06   #4
v&v
v&v's Avatar
Thanked: 1,099 Times
i had the similar problem in my Baleno. it was diagnosed to damaged struts and also the spacers too were worn out.
v&v is offline   Reply With Quote
Old 10th May 2012, 12:21   #5
speedsatya's Avatar
Thanked: 712 Times
In addition to all these , also check the stabiliser bar rubber bushes . They last around 15 K kms .
speedsatya is offline   Reply With Quote
Static Electricity Discharge / Shock when touching front door ramkya1 Technical Stuff 158 17th March 2017 13:38
Esteem - Tyres touching after upgrade joeblack Tyre & Alloy wheel Section 23 16th October 2013 17:48
Toyota Innova 2.5 EDIT - Now touching a Lakh kms raj_5004 Long-Term Ownership Reviews 90 17th August 2013 19:47
Touching the Heart of India abbey4u Travelogues 4 15th July 2008 21:41
Touching Ferrari DINO story! Stratos The International Automotive Scene 7 28th May 2004 11:27
