Old 7th April 2006, 06:34   #16
Thanked: 426 Times
It's a normal Fiat feature. Don't worry about it. BUt don't you just love the loud hum of that fan.
amit is offline   Reply With Quote
Old 7th April 2006, 09:38   #17
S@~+#0$#'s Avatar
Thanked: 37 Times
I have seen this feature on my friend's Palio 1.2 as well. This is very good for your engine and in older cars the ignition timing is said to change when you switch of the engine when the fan is running. Anybody knows why?
Also, I have often wondered if I could get this done on my car(esteem), have any of you done this to your car? If so do shed some light.
S@~+#0$# is offline   Reply With Quote
Old 8th April 2006, 00:30   #18
turbo_c's Avatar
Thanked: 7 Times
Originally Posted by hrag
The Premier Padmini has this feature as well.
I know... but:
I thought the PP's fan ran off a belt and was not electrical... can somebody confirm this?
turbo_c is offline   Reply With Quote
Old 8th April 2006, 00:36   #19
turbo_c's Avatar
Thanked: 7 Times
I'm not sure if the Esteem really needs this... My E2 Esteem runs pretty cool on a not too hot day (if I drive with a light foot), and even if I let the engine idle with the car stationary for a long time, the fan runs for just 1 - 2 mins at a stretch with about 5 mins in between... could it be that the Suzuki designers have got it spot on when it comes to efficiency ?
(13 Kmpl city; 15+ Kmpl highway; w/o AC)
- T u r b o C -
Old 8th April 2006, 02:16   #20
Mpower's Avatar
Thanked: 1,687 Times
Originally Posted by nitinbhag
asked a Fiat guy when I observed this on my Siena 1.6 and he said that it is designed that way to prevent any hotspots in the engine after switching off. But for that, the coolant pump also has to run??
Good point Nitin. Coolant pump is driven by the belt. What's the point in cooling the fluid in the radiator if it dosent reach the engine.
Must be some strange Italian Logic.
Old 8th April 2006, 12:50   #21
DRC
DRC's Avatar
Thanked: 48 Times
When you cool the coolant, it circulates itself by convection
DRC is offline   Reply With Quote
Old 8th April 2006, 14:09   #22
merve_extreme's Avatar
Thanked: 12 Times
When the coolant pump stops the coolant does not stop circulating instantly,it takes a few seconds to do so.the fan is the palio stays on for those few seconds(say like 5-7 seconds on the 1.6 and about 10 seconds on the 1.2).alsothe fan behaves like that,only if the ambient temp is very high.normally on my GTX it never stays on during the winter or rainny season only during Autumn and summer.
merve_extreme is offline   Reply With Quote
Old 8th April 2006, 14:44   #23
prabuddhadg's Avatar
Thanked: 46 Times
Most cars nowadays have fans running on belts and fans start only when the heat is sensed, and fans naturally turn off as soon as the ignition is switched off. I guess its a Fiat special of running the fan after switching the ignition off.
prabuddhadg is offline   Reply With Quote
Old 9th April 2006, 15:44   #24
MexXxentric's Avatar
Thanked: 11 Times
Default A different logic
If we switch on the ignition again after the fan stops, the fan restarts.(i've experimented this)
so how is it possible??
So the fan runs even with out circulation of coolant tru engine(rite??)
The fan is controlled by the temperature sensors(in ac condensor coil and radiator cooling coil- they gives cumiliative input to ecu).
the fan and sensor ensures tat there is cool water available in the radiator coil.
and the thermostat lets in the cool water in required quantity to the engine.(adjusts flow) to keep engine temp with in limits.
cooling water circulation to engine is controlled by a thermostat.
so my opinion-
This 10 sec post switch offf running of fan wont help in preventing heat soaking of the engine..
So if u r stopping engine after a tuf ride and if the temp gauge shows more than half mark,give some time for cooling off( with engine runing)
the FIAT logic to have the cooling system independent from ignition control feels fine.
NB- in palio, the engine runs coooler when the AC is switched on.
becoz- the sensors give a cumiliative input to the ecu, which runs the fan in a higher speed, thus yields faster coolling
Drive safe
Sree
MexXxentric is offline   Reply With Quote
Old 19th April 2006, 00:00   #25
nevertouchme's Avatar
Thanked: 57 Times
Talking Yo pal !
Originally Posted by Rtech
This is normal for most, if not all, Fiat cars. Even my bike runs its fan for a minute or 2 after I switch off the ignition. Its perfectly normal and should not affect your battery at all.
Ne body remember the PAL PEUGEOT 309 GLD? Ma cousins car has de same feature. Even when de engine is halted, the fan continues to run for a minute or so... TWIN fans, and sounds like a silent genset
And in my old zen diesel , the moment you switch on the a/c, the fan starts and it's throughout................... when the a/c is off, the fan stops too...
nevertouchme is offline   Reply With Quote
Diesel Cars: Down, down, down! Market share = 34% S2!!! The Indian Car Scene 66 2nd June 2016 16:21
From a City Down Under to a Country Down Under : From a RX100 to a Fatboy... LTAutoMad Introduce yourself 9 22nd July 2014 16:35
Palio 1.2 cooling fan failure and experience with roadside assistance Dr.AD Technical Stuff 10 30th April 2010 18:07
Palio 1.6 Stile cooling system doubt vidushak Technical Stuff 9 25th July 2008 11:01
Fuel Efficiency Down Immediately after 2nd Service :( paish Technical Stuff 6 17th March 2007 15:47
