| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Apr 2004 Location: Bangalore
| Typically, the colling fan would shut off once the ignition key is removed. In my palio gtx, the fan stays on for a while even after the ignition key is removed? Is this a problem or a feature? I have not seen such a thing happen in other cars? Wont the battery drain because of this? -Neel |
| | #2 (permalink) |
| Team-BHP Support ![]() | This is normal for most, if not all, Fiat cars. Even my bike runs its fan for a minute or 2 after I switch off the ignition. Its perfectly normal and should not affect your battery at all.
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ |
| | #6 (permalink) |
| BHPian Join Date: Mar 2005 Location: Singapore
| Neel, its perfectly fine. Thats the way its supposed to work. In fact, on cold days, sometimes you can hear the fan start after you switch off the ignition. I asked a Fiat guy when I observed this on my Siena 1.6 and he said that it is designed that way to prevent any hotspots in the engine after switching off. But for that, the coolant pump also has to run?? |
| | #7 (permalink) |
| BHPian | Yes, it is a normal and good for the engine. Only irritation is, it sounds louder than the engine, and many times parking lot guys call you back to tell you that engine is running . It happens to me all the time
__________________ _____________________ Stand on your head, upside down.. The world does not look any different, but you sure will look different! |
| | #8 (permalink) | |
| Team-BHP Support ![]() | Quote:
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ | |
| | #14 (permalink) |
| BHPian Join Date: Dec 2005 Location: Bangalore
| i think palio is the only car to have the feature where the fan starts even when the car is switched off and the car senses that it is hot enough to start running....
__________________ _________________________________________ "Coming second is being first of the losers" -- Ayrton Senna |
| | #15 (permalink) |
| BHPian | The Premier Padmini has this feature as well. I guess the only issue with this feature is: if the associated relay goes bad, the fan continues running thereby draining the battery. netarchie: I didn't understand what you meant. Does your fan never come on sometimes? Last edited by hrag : 6th April 2006 at 20:03. |
| Thread Tools | |
Similar Threads | ||||
| How is the cooling with lack of Rear Ac for Safari LX | Dieselone | Accessory/Parts Reviews | 19 | 29th August 2008 18:20 |
| Palio 1.6 Stile cooling system doubt | vidushak | Technical Stuff | 9 | 25th July 2008 11:01 |
| Poor AC Cooling in Santro | amitpunjani | Technical Stuff | 5 | 4th March 2008 13:20 |
| Indica cooling issue.... | panky12345 | Technical Stuff | 13 | 12th September 2007 17:42 |
| NHC AC Cooling Coil Fins | BMW | Technical Stuff | 0 | 26th October 2006 09:03 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458
