Old 20th April 2006, 11:28   #16
The car has now spent 10 days with Bosch service, RS Motorcrafts..
After checking the coolant sensor & wiring (which was suspected earlier), they today inform me that the ECU needs to be changed indeed.. And I have to go back to Sundaram as Bosch cannot give me a ECU with a warranty
nitinbhag is offline   Reply With Quote
Old 2nd June 2006, 17:35   #17
Here is closure on this subject.
After 2+ months wait for it arrive from Italy, the ECU got changed, car is back on the road. Total expense 12K+.
FIAT: You just lost a fan :(
Old 2nd June 2006, 18:34   #18
extreme_torque's Avatar
Thanked: 1,487 Times
hey nitin, good to hear that your car is alright, the whole ECU thingie for 12K + isnt a major expense but 2 months wait is. I hope that improves with the new FIAT-TATA merger.
extreme_torque is offline   Reply With Quote
Old 2nd June 2006, 21:44   #19
wolfinstein's Avatar
If the ECU IC is placed on a Heat Sink- I think it may be possible that after a 5-6 years of service the Thermal paste might dry up..! So you can indeed buy a good quality thermal paste and re-coat the IC..! There can also be a possibilty of adding a Mini- Fan to cool the heat sink provided that there is space inside the ECU Box.
This may help to cool the ECU unit ( with Fan faster- With Thermal paste- Also not as fast though)...!
wolfinstein is offline   Reply With Quote
Old 2nd June 2006, 22:27   #20
ECM
ECM's Avatar
Thanked: 9 Times
Excellent suggestion fm you dear wolfinstein and this is in practice a real case in many electronic appliances. V.good practical solution you provided.That paste hardly cost 15 odd bucks.
ECM is offline   Reply With Quote
Old 21st June 2006, 16:14   #21
OK.. Here we go again...
A week after the ECU change, the car started stalling with exactly the same symptoms. Starts fine, drive off, after 8-10KM it starts jerking and then the engine dies. After that it doesnt start. After 30 min, it starts like there is no problem at all.
Car goes back to Sundaram. They start changing all sensors one by one and testing it. Final verdict - its a fuel pump gone bad. Changed the pump. Took it on a 35KM test drive. Works fine.
Got the car back yday and it seems to be running fine. I have made more visits to the garage in the past 3 months than in 5 years of owning the car :(
Apparently, Sundaram have seen ECU and fuel pump issues in other Palio/Petra/Sienna as well. They had 3 cars for fuel pump replacements last weekend !!
@Wolf - I am going to open the old ECU and check for the heat sink paste..
Old 21st June 2006, 17:12   #22
Thanked: 1,640 Times
PM Khaadu with your results - I'm not sure if he has sorted out his Palio issues. Lamborghini seems to have some issues as well, but am not sure if this is related.
Congrats on getting your baby back, by the way.
Steeroid is offline   Reply With Quote
Old 21st June 2006, 19:33   #23
khaadu75's Avatar
Thanked: 11 Times
Steeroid , U are right .. I still havnt figured out wats wrong with my Palio !! Infact tomorrow morning I have my mech finally coming over ... shud have it figured out by tomorrow afternoon -- though the strange thing is that the cars battery also died out completely while it had been parked for 10 odd days !!! And the battery is only 6 months old ... I'm confused as to why that happened ... ???
khaadu75 is offline   Reply With Quote
Old 17th August 2006, 22:19   #24
parimal_vb's Avatar
Thanks for your experience sharing. My GTX has same problem, and as soon as told the garage person in Pune. And replied saying we will check the fuel pump pls get vehicle at garage. will update once confirmed lets see! Thanks......
parimal_vb is offline   Reply With Quote
Old 23rd August 2010, 00:21   #25
Hi nitin ... i realize its been a while since you faced this issue ... Im facing a similar issue .. only there is no jerking, the car does not stop on its own, this happens when its stopped for a while and then I try to restart it.
please see http://www.team-bhp.com/forum/techni...n-problem.html (Fiat Siena, very stubborn problem.)
Was it a ECU problem in combination with the fuel pump or just the fuel pump?
Would love your inputs. Thanks!
spacefugitive is offline   Reply With Quote
ECU Flashing for white smoke problem in Innova ? jalsa777 Technical Stuff 14 29th March 2012 11:30
Scorpio vlx mhawk problem with ECU. desi_wananchi Technical Stuff 4 7th September 2009 08:30
Fiat Siena1.6 for sale nitinbhag Shifting gears 2 15th January 2008 13:30
Siena1.6 - Strange problem nitinbhag Technical Stuff 28 26th October 2007 08:32
