Old 12th May 2012, 01:55   #16
khan_sultan's Avatar
Thanked: 3,872 Times
Default Re: Jaguar: Team BHP visits the Castle Bromwich Factory UK
After the tyres, it's time for the XJ's interiors to be taken care of. In go the plush seats:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-21.jpg
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-22.jpg
All dressed up, the XJ will have its first taste of oils & fluids. This is like giving a child the first drop of water...a very important moment in the life of the vehicle. Nannies, errr machines, come and feed the XJ:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-24.jpg
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-25.jpg
Of course there are some parts that are made in China. How can you be at a manufacturing line and not see a "Made in China" tag? The various chrome embellishments that will go into the vehicle:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-23.jpg
khan_sultan is offline   (9) Thanks Reply With Quote
Old 12th May 2012, 01:56   #17
The doors are still not installed. This is done at the end, to allow workers / robots easy access to the car. The XJ is equipped with a Bower Wilkins audio system:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-28.jpg
The smaller, space saver spare:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-30.jpg
The XJ is fully kitted out and ready for final tests. The extensive testing takes place at the VCATS station:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-31.jpg
khan_sultan is offline   (7) Thanks Reply With Quote
Old 12th May 2012, 01:58   #18
Final inspection:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-32.jpg
Then driven away...
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-33.jpg
...to the yard and ready for shipment. Now you know how the XJ is created, right from the aluminium sheets to final assembly:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-35.jpg
khan_sultan is offline   (18) Thanks Reply With Quote
Old 12th May 2012, 02:03   #19
Next on the schedule is a session with Mark White - Chief Technical Specialist for Light Weight Body Structures at Jaguar. We arrive in a large room where a cut out of the XK is parked. This section shows the different materials used in the construction of the body structure. The silver being aluminium, the different shades of green being alloys, and the black being magnesium:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-36.jpg
Mark White is hugely passionate about his subject area. He has worked at Jaguar for all of his professional life and is a self confessed Jaguar & Lotus enthusiast. He's had posters of Jaguar since the childhood days, and wanted to work here only. It is said that if Mark doesn't know the answers to light weight body structures, probably no one else does either:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-37.jpg
Some of the key takeaways from his presentation were:
- The '03 XJ was the first volume-production car to use an all-aluminium monocoque chassis
- There's no difference in quality between new and recycled aluminium
- At the end of the XJ's life, nearly 100% of its aluminium is recyclable
- The XJ body structure weighs 150 kgs lesser than the comparable steel body of competing vehicles
- The XJ body structure weighs approximately the same as that of a Mini
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-39_1.jpg
Here is the presentation that he used. If you are into automotive structures, you might find it useful:
CB Mark White Aluminium Presentation.pdf
The factory still has the markings of RAF. See the drain pipe; the topmost part has RAF stampings, remnants of the days when aircrafts were built here:
PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of the XJ-39.jpg
khan_sultan is offline   (20) Thanks Reply With Quote
Old 21st May 2012, 19:20   #20
Thanked: 103,414 Times
Default Re: PICS : Jaguar's Castle Bromwich (UK) Factory. Detailed report on the making of th
Thread moved from the Assembly Line (The "Assembly Line" Forum section) to the Technical Section. Thanks for sharing!
Old 21st May 2012, 19:49   #21
Neel's Avatar
Thanked: 24 Times
Awesome, pics complement the write up very well.
Was hoping to see more on the engine assembly and variants.
Neel is offline   Reply With Quote
Old 21st May 2012, 20:01   #22
Thanked: 114 Times
Officially my favourite thread on team bhp. Ill keep coming back to go through this thread again and again for quite some time.
most of us have visited an automobile plant at some point , but to gain access to info on the most current and advanced practices in the automobile industry is something
mycarhasablower is offline   (1) Thanks Reply With Quote
Old 21st May 2012, 20:11   #23
Thanked: 41 Times
khan_sultan, awesome thread.
One question on the paint shop. Do they use an electrolytic process to coat aluminum?
What metal/alloy do they use? Not sure if the answer is a trade secret.
"MIG/TIG". So many memoies came back. Last I read about that was in college.
rtandon is offline   Reply With Quote
Old 21st May 2012, 20:23   #24
Thanks guys. I enjoyed writing this one and enjoyed every bit of the factory tour.
How I wish we could have seen that also. Unfortunately, as I mentioned in the report also, the engines are manufactured in a FORD factory somewhere else.
Agree. The manufacturing process of these wonderful machines was an eye opener for me.
We didn't see the paint shop hence don't have information about the process. The alloys used are different varieties of custom spec alloys. Most of the aluminum based alloys are sourced from Aditya Birla group. Actually, if you go through the attached presentation from Mark White, you can read up on the details of the alloys used.
Link to Presentation
khan_sultan is offline   (1) Thanks Reply With Quote
Old 21st May 2012, 20:38   #25
smartcat's Avatar
Thanked: 14,803 Times
Is the paint shop within the factory premises or are the cars painted elsewhere and brought back to the factory?
Originally Posted by khan_sultan View Post
Cut section of the XJ body. Notice how shiny the aluminium is. We asked if a customer can order this finish, but the answer was in the negative. If someone from the Middle East sees this, he'd have probably placed an order for a dozen right then and there:
That's because sunlight reflecting on the body will be hazardous to other road users.
smartcat is online now   Reply With Quote
Old 21st May 2012, 21:15   #26
Thanked: 7 Times
Attachment 926402
Absolutely captivating; thanks for an elaborate coverage !
What does the testing include ? I remember from Ferrari's Megafactory show coverage, that is a 20 mile test run of each vehicle at in-house test tracks, subsequent to a rigorous tests on a dyno. Is track testing a part of JLR's process ?
Secondly, did the discussion on lightweight structures touch upon composites, or was it restricted to alloys and aluminium ?
shobhit is offline   (1) Thanks Reply With Quote
Old 22nd May 2012, 00:06   #27
Blow Horn Ok's Avatar
Thanked: 455 Times
Thanks for posting the most detailed production story of a great Car. I was glued to this for an hour! Now I am sure that the Jaguar is one of the pioneers of light weight body construction. What about their efforts of reducing weight and emissions of the engine? Now after this post I know they use Ford's facility but please provide more details of the engine and transmission. Also please post details of the paint booth section if you have.
Blow Horn Ok is online now   (1) Thanks Reply With Quote
Old 22nd May 2012, 01:32   #28
getsurya's Avatar
Thanked: 967 Times
Hi Khan,
Great report there! Awesome!!
Truly enticing and glued was I, for reading it through. Thank you for sharing and the journey.
getsurya is offline   Reply With Quote
Old 22nd May 2012, 02:38   #29
Thanks a lot khan_sultan for the wonderful thread and team-bhp moderators and support for creating and maintaining this amazing site. The experience of its valuable members, unbiased, in-depth reviews and the diverse areas t-bhp covers has made it one of the most respected forums in the world which is evident from the number of invites it receives for various events. Hope to see more of these.
Concorde is offline   (1) Thanks Reply With Quote
Old 22nd May 2012, 03:14   #30
LP640's Avatar
Thanked: 41 Times
Finally an aluminium production facility! Never imagined that working with aluminium would be so different. No spot welding or seams, just rivets and glue!
It really is a brave step to move to aluminium from steel. And Jaguar seems to have mastered it!
LP640 is offline   (1) Thanks Reply With Quote
PICS: SF Sonic Battery Factory. Detailed report on the making of a Car Battery S2!!! Technical Stuff 29 16th April 2016 11:39
PICS: Hyundai's Chennai Factory. Detailed report on the making of Xcent & Grand i10 DerAlte The Indian Car Scene 31 16th November 2015 19:52
PICS: Tata Motors Factory! Detailed report on making of the Indica & Indigo eCS moralfibre The Indian Car Scene 53 15th March 2015 20:19
PICS: Apollo Tyres Chennai Factory. Detailed report on the making of a Tyre Vid6639 Tyre & Alloy wheel Section 31 16th February 2015 11:39
PICS : Ford's Chennai Factory. Detailed report on the making of Figos, Fiestas... GTO The Indian Car Scene 204 6th September 2012 23:52
