Old 4th October 2014, 20:32   #16
Thanked: 14,597 Times
Default Re: Hyundai Accent : AC not working with clutch depressed EDIT : Now resolved
Originally Posted by hrish90 View Post
Thanks for the reply Anurag.
But after i'd replaced the bottom of the radiator, the mechanic asked me to not put coolant for 2-3 days because if there was any leak, the coolant would get wasted. He advised me to use the car on water and check the coolant reservoir if it is becomes empty again then there would possibly be more leakage.
What about the whole plumbing of the A/C system? If you hearing a "sssshhhh" type of sound then it does indicate a opeining / leak in the system.
Anurag.
a4anurag is online now   Reply With Quote
Old 5th October 2014, 14:38   #17
Anurag.
He checked for leaks on the whole plumbing system. There was none.
The "ssshhh" type of sound was only once, after that the AC stopped working. After the servicing of the AC, there is a little bit of cooling but not much.
The AC mechanic told me this is the max to what it can go. But my car used to cool alot more before this problem started. He also charged me 1.5k for the servicing.
hrish90 is offline   Reply With Quote
Old 5th October 2014, 16:00   #18
CrAzY dRiVeR's Avatar
Thanked: 19,781 Times
Originally Posted by sameerg001 View Post
I got the issue, it was related with accelerator cable. Thanks everyone for helping me out on the issue
MODS: Please close this thread as issue has been sorted out.
Sameer
Strange indeed. Can you please explain more on the fix? I know its an old thread, but curious to know how it got fixed.
What exactly was done in this 'a/c service'? Was the a/c refrigerant refilled?
Old 6th October 2014, 15:40   #19
Yes, the A/C refrigerant was refilled which he says was empty. He also cleaned the cooling coil, etc.
RPM shoots up when clutch depressed rao_battula Technical Stuff 83 27th September 2016 15:28
Brakes not working as desired in my Accent Peter Technical Stuff 11 17th October 2008 23:31
A depressed customer; plz guide karthik1107 The Indian Car Scene 15 30th April 2006 19:53
