Old 27th May 2012, 08:07   #1
Default Condenser replaced = car starts jerking
I have a 1999 November Santro DX which has done close to 127000 kms. I have installed an LPG kit on the car, which I am not using due to various reasons. I had no issues with it in terms of mechanicals until recently when the condenser died on me. I took it to Trident Hyundai in Yeshwantpur, Bangalore, and was told that the bumper railing had been bent due to impact and was causing the radiator to press against the condenser which had damaged it. The SA said that the condenser had to be replaced, which I asked him to do.
Once I received the car from the service center, I started noticing that the car would jerk slightly when I tried to accelerate suddenly. Over a period of 48 hours, the slight jerking changed to an occasional violent shuddering. I took it back to the service center and asked them to check the car. I suspect that it was a case of a faulty fuel pump. However after keeping the car with them for a day, the service center returned it stating that there was no issue with the car and that I should probably get the LPG disconnected since it could be an issue with the LPG related wiring. I find this explanation a little strange since I never faced any such issues in the past. Could the experts on team-bhp throw some light on what they think could be wrong? I continue to face the occasional violent shuddering.
Thanks in advance
msetlur is offline   Reply With Quote
Old 27th May 2012, 11:29   #2
Catalyst_delhi's Avatar
Thanked: 149 Times
Default Re: Condenser replaced = car starts jerking
Probably the wires for the injectors,crank sensor or TPS is loose. Otherwise the fuel filter could be dirty as well. I do not see any other problem.
also check fuses for tight fitting
Catalyst_delhi is offline   (2) Thanks Reply With Quote
Old 27th May 2012, 13:51   #3
Thanked: 94 Times
How old are your engine mounts?
JustCause is offline   Reply With Quote
Old 28th May 2012, 09:12   #4
Mod Note : Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another!
Thanks Catalyst. Will get this checked.
I am the second owner and as far as I know, the mounts are the ones that came with the car.
Last edited by GTO : 28th May 2012 at 15:25. Reason: Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another!
Old 28th May 2012, 15:37   #5
Thanked: 94 Times
The mounts are way past their usable life. Usually, mounts are changed in the 60-70K mark. Do change the gearbox mounts also if you are changing the engine mounts.
The most probable cause of the shuddering you described are the engine mounts.
JustCause is offline   (1) Thanks Reply With Quote
Old 28th May 2012, 18:07   #6
Psycho's Avatar
Thanked: 95 Times
Get the pressure in your ac system checked also happens in case of excessive gas fillup.
Psycho is offline   (1) Thanks Reply With Quote
Old 31st May 2012, 22:10   #7
Thanks Psycho and Just Cause.
I will get both of these checked and see if that resolves the issue.
Skoda Laura L&K Compressor and Condenser question duke Technical Stuff 60 20th November 2017 23:28
car ac compressor and condenser problem honda3938 Technical Stuff 9 3rd December 2015 21:09
Lancer condenser leak? rajivanoj Technical Stuff 11 16th July 2009 16:47
Class Starts Early; Indigo CS launched; starts at 3.79lac jkdas The Indian Car Scene 208 28th May 2008 18:53
What is a condenser? v1p3r In-Car Entertainment 23 3rd June 2007 04:34
