Old 28th May 2012, 07:26   #1
Default Acceleration Issues in my 2005 Mercedes E200K
I have a 2005 mercedes benz E200K with about 60k miles. For about a week now, I have noticed the car sometimes has very sluggish acceleration and two times, while stopped at a red light, the car turned off. The sluggish acceleration happens around 65% of the time i drive.
Took it to the dealer who changed some air intake hoses and valves, charged me 15K, and no improvement. They now say change the crankshaft sensor which will cost 20K. I think he's just trying to fleece me.
Any ideas what this could be? I serviced the car last october and only drive 500 kms a month. Could it be the crankshaft sensor - if so can get it done outside for half the cost. Or is it just a case of cleaning fuel injectors, etc? By the way, whats the best fuel additive for cleaning?
Thx!
solcann is offline   Reply With Quote
Old 28th May 2012, 09:17   #2
motocamp's Avatar
Thanked: 99 Times
Default re: Acceleration Issues in my 2005 Mercedes E200K
Take it to a dealer who has diagnostic equipment for your car.
It dont think it would be a problem with the CPS.
Taking it to a specialist,somebody who has the knowledge and equipment to be able to diagnose the problem without trial and error(very expensive in your case)
motocamp is offline   Reply With Quote
Old 28th May 2012, 11:18   #3
Default Re: Acceleration Issues in my 2005 Mercedes E200K
Well, I already took it to the authorized dealer, and it did not get me anywhere, except a hole in my wallet!!!
Thats why I thought I might get some advice from my fellow BHP'ians! So, if there are some inexpensive things I might try first - like adding a cleaner to the petrol tank, etc. and seeing if that solves the problem, I would prefer to do that rather than take it back to the dealer.
Just wanted to know what normally causes slow acceleration like this in vehicles - i.e. is it usually transmission issues, unclean fuel injection system, etc.
Thx!
Old 28th May 2012, 11:22   #4
1self's Avatar
Thanked: 270 Times
While CPS could be a problem, i believe that first of all you get the entire intake manifold, supercharger & associated components decarbed, you will get your performance back. Get it done via a machine at a reputed place.
The reason i say this is that i've seen a couple of used C200k superchargers (Eaton), & they are FULL of carbon deposites.
I also think that the CPS is on it's way out. You do a fair bit of mileage on the odo.
1self is offline   (1) Thanks Reply With Quote
Old 28th May 2012, 16:06   #5
madnish30's Avatar
Thanked: 104 Times
Faced similar issues on my Camry it was a throttle body issue, a full cleaning of the throttle body might help - if not the next step is checking the throttle assembly. Happens a lot especially in heat - cool the car down and it will run fine till it gets heated again!
madnish30 is offline   Reply With Quote
Old 28th May 2012, 16:55   #6
Y@SH's Avatar
Thanked: 359 Times
My mercedes had a problem of not accelerating quickly when the accelerator was pressed completely. Sent it to autohanger and it turned out to be a crack in the turbo pipe. They replaced the turbo pipe and then it was as good as new. Cost around 1800.
Y@SH is offline   Reply With Quote
Old 28th May 2012, 17:23   #7
Thanked: 90 Times
You will be lucky if it is just a crack in the turbo pipe. But any authorised service centre will diagnose and the fault will clearly show. There is no hide and seek with the diagnostics. I suspect could be the CPS or even your turbo has packed up! Some of these Mercs come with an electronic actuated turbo unit, and they tend to fail. Only option is to replace the complete unit as mercedes Does not sell only the electronic box on the turbo unit. I have come across a turbo unit from a E220cdi which the driver of the unit is a plastic gear actuated electronically, this gear got worn out, and the complete unit had to be changed!! So much so for the German engineering.
scooby05 is offline   Reply With Quote
Old 28th May 2012, 18:27   #8
Thanked: 11,110 Times
Ideally get the diagnostics done to figure out problem. It could be the MAF sensor giving wrong readings also
ajmat is offline   (1) Thanks Reply With Quote
Old 28th May 2012, 18:57   #9
Mpower's Avatar
Thanked: 1,687 Times
If its a CPS, then you should get the check engine light and some codes will be activated. Get all your codes checked.
The E200K should be the supercharged engine.
Old 28th May 2012, 19:55   #10
Neil.Bhujbal's Avatar
Thanked: 59 Times
Originally Posted by solcann View Post
Thx!
Did they say crankshaft position sensor or the camshaft position sensor ?
Because when your camshaft position sensor fails the timing goes retard & hence the sluggishness.
If the crankshaft position sensor is faulty your vehicle shouldn't start at the first place.
Even if its either of them they should have been able to diagnose it in your first visit itself. The scanners clearly show when any sensors goes kaput.
It can be something else too .. best thing would be to get the car diagnosed - scanned in some other dealership (you can stand besides them while its happening) get a estimate for the part that needs to be replaced & then if you feel right get it replaced outside.
Personally i dont thing it would be any carbon in the intake problem because i have seen many high miles clocked 200Kompressors here in my dealership & they never had it.
Neil.Bhujbal is offline   Reply With Quote
Old 28th May 2012, 20:05   #11
EFF-EIGHT-BEE's Avatar
Thanked: 98 Times
Well the usual causes for sluggish accelaration as clogged air or fuel filters, have you checked them till now? Also if sluggishness is accompained with jerks then it could also be the ignition coil, but that should give you a check engine light. I would say that get the filters checked first.
EFF-EIGHT-BEE is offline   Reply With Quote
Mercedes W203 C220CDI or W211 E200K Mohnish Luxury, Imports & Niche 50 21st February 2015 14:12
2005 Model Mpfi Esteem - Acceleration Issues. ganesh_bbr Technical Stuff 19 4th March 2010 23:04
Short drive with the C220 and the E200K GTO The Indian Car Scene 21 1st August 2006 12:53
SPOTTED :2 mini motos , 1 Kawasaki Vulkan , 2005 CBR 1000RR n 2005 ZX10R varun_patra Super-Cars & Imports in India 1 31st October 2005 12:45
