Old 23rd October 2013, 11:01   #31
Thanked: 336 Times
Default re: HVAC dust filter missing in your car too?
My Swift didn't have it. I asked Maruti ASS about it and they mentioned Maruti introduced it a few months back (not sure how true it is). I have asked them to install it. The price quoted is 340 Rs. He mentioned it fits in most maruti vehicles except wagon R and alto. So i assume it is a part which is common to many models
Mohan Mathew A is offline   Reply With Quote
Old 23rd October 2013, 11:18   #32
vikram_d's Avatar
Thanked: 940 Times
Both my previous cars didn't have them too even though there was a provision for them. My first car was an Esteem and my second was the 2006 Swift petrol.
I'm guessing a lot of Indian car manufacturers are not installing these filters as a cost cutting measure.
Old 23rd October 2013, 12:16   #33
Swanand Inamdar's Avatar
Thanked: 573 Times
As Vikram has mentioned above, a lot of cars didn't have the filter, as a factory fitted accessory (if it can be called an accessory).
My Swift didn't have one either. Surprisingly, the A.S.S here in Pune (Sai Service) suggested I get one installed. Cost some ~2500 bucks, IIRC.
Swanand Inamdar is offline   Reply With Quote
Old 23rd October 2013, 12:21   #34
bharatbs's Avatar
Thanked: 109 Times
My 2011 honda city had an AC filter, just changed it during the routine service. It costed Rs 900.
bharatbs is offline   (1) Thanks Reply With Quote
Old 24th October 2013, 09:38   #35
sgiitk's Avatar
Thanked: 3,884 Times
Default Re: HVAC dust & pollen filter missing in your car too?
Originally Posted by bharatbs View Post
My 2011 Honda city had an AC filter, just changed it during the routine service. It costed Rs 900.
I am getting my Brio back from Honda at lunchtime. That too has the tray, so will check it out. Also, can you please measure and post the dimensions, for all we know they may be the same. Else, there is always the option of taking the smaller one and making an adapter for the bigger tray. I plan to post pictures and dimensions later. Considering I found about a dozen dried leaves, one wonders how much stuff goes through. This is when we use outside air settings very rarely, and the Civic has done under 15,000km.
Last edited by sgiitk : 24th October 2013 at 09:41. Reason: Last two sentences added
sgiitk is offline   (1) Thanks Reply With Quote
Old 24th October 2013, 10:37   #36
alexpaul's Avatar
Thanked: 17 Times
Hi Mohan,
Few years back MASS was pestering me to install AC filter in my diesel Ritz which they had quoted Rs 2500/- but I refused . Is this the same filter that which you have now quoted as Rs 340/-?
alexpaul is offline   Reply With Quote
Old 24th October 2013, 10:43   #37
Thanked: 336 Times
Originally Posted by alexpaul View Post
Hi Mohan,
Although i can't be sure i would guess it probably is. My SA also was referring to it as AC filter. It is a white coloured filter about the size of a 200 page paperback book. I got it installed yesterday and the exact price is Rs. 311. I didn't notice much reduction in the fan speed and when put in re circulation there was considerable reduction in outside smell coming into the cabin. This feedback is based on a short drive today from home to office
Mohan Mathew A is offline   (1) Thanks Reply With Quote
Old 24th October 2013, 11:37   #38
Sankar's Avatar
Thanked: 4,655 Times
Default Cabin filter for Swift/Dzire/Ritz/Ertiga
Swift cabin filter installation
Click on the link below. This is applicable for Swift/Dzire (old & new) Ertiga, Ritz. This is a failry easy DIY and on a scale of 1 - 10 where 10 being the hardest i would rate it at 1.
http://www.team-bhp.com/forum/modifi...tallation.html (Swift Cabin (AC) Filter Installation)
I don't remember exactly how much was charged for the MGA cabin filter but i remember it vaguely as around Rs350-400/- The equivalent Bosch filter which is of better quality is approximately Rs600/- (IIRC) and the Bosch activated carbon filter is around double that cost.
For Maruti vehicles with non open able AC filter compartment
And for Maruti vehicles with no open-able filter compartment (Astar and probably Alto/Wagon R too) its possible to install a cabin filter by cutting the cover and making a rectangular opening. The pictures below is of the AStar's blower assy with no open able filter slot
Non open-able AC filter compartment:
Cut the plate alongside the border and re-use the cut plate + insulation/masking/duct tape to seal it back once the filter is in. It will be hidden so cosmetics aint an issue, function is. I used Bosch's Swift cabin filter for my AStar and it was a near perfect fit.
Cut along the edges as marked:
I highly recommend installing a cabin/ac filter because it can considerably reduce the amount of dust/debris getting to the evaporator and resulting in a clogged evaporator. Its also a good idea to clean the evaporator every time the filter is changed using Gulf AC Neutralizer or similar product, make sure that the long plastic tube reaches down to the evaporator before foaming.
Sankar is offline   (3) Thanks Reply With Quote
Old 24th October 2013, 14:06   #39
sgiitk's Avatar
Since the Brio may not be back before late in the evening I am posting the pics from the Civic.
The first frame shows the tray detail. The tray has been cleaned a bit. Note the locating /spacer lugs.
The second frame shows the tray almost out of the holder. Note the dried leaf. This is after some leaves were removed earlier.
The air flow is from the top to the bottom. The size is 227mm x 235mm x 30mm.
Old 24th October 2013, 14:17   #40
akshay4587's Avatar
Thanked: 1,686 Times
Is that a filter?
I have it in the Scorpio and the Linea.
In fact in the Linea,i have a choice to use a paper type filter or a wire mesh one.The one in the scorpio is a wiremesh filter.
Old 24th October 2013, 15:44   #41
sgiitk's Avatar
Originally Posted by akshay4587 View Post
Is that a filter?
It is not the filter, but the tray which is supposed to hold it.
Also from the Civic maintenance forum
Originally Posted by ironager View Post
The cabin filter for the Honda Accord is a perfect fit in the civic.
Let us get the City dimensions, and maybe it is generic.
Old 24th October 2013, 17:17   #42
Thanked: 33 Times
Is that a filter?
My 2013 SLE doesnt have that in the cabin (behind the glove box). Would it be possible for you to post a pic of the filter please? ASC guys are ignorant about the same...
Puneet.S is offline   Reply With Quote
Old 24th October 2013, 17:23   #43
akshay4587's Avatar
My 2010 SLE has it.
I havent removed it as a DIY ever,but its a wire mesh filter.
Will check if i can click a picture of it.
Old 24th October 2013, 18:40   #44
kamal.sn's Avatar
Thanked: 81 Times
My Tucson had one already installed and i change the same myself every 5k-6k Kms. For those who are in Delhi, check out the shops on the ground floor of palika bhavan where cabin filters for various cars are available from a local company called zipfilter. I get the same from My tucson from here and the last time i got one it was for as little as Rs. 350 compared to the genuine filters sold by dealers which cost about Rs. 2500. The local make filters are of quality comparable to the original ones.
There is a catalog on the zip filter website with prices but the prices in palika bhavan are usually lower than the list prices.
http://www.zipfilter.com
kamal.sn is offline   Reply With Quote
Old 24th October 2013, 19:42   #45
Thanked: 14,610 Times
Why do you change the filter so frequently? Is the area that you live and drive so dusty that clogs the filter?
Anurag.
a4anurag is online now   (1) Thanks Reply With Quote
Foul Smell from Blower / Fan / HVAC filcord Technical Stuff 195 22nd June 2018 08:48
HVAC/Air Conditioner Pollen Filter - Where is it placed in Fiesta? sanjayc Technical Stuff 14 30th September 2015 14:30
Safari HVAC question elliven Technical Stuff 2 12th July 2010 08:43
AC to HVAC in Xeta? kreddy Technical Stuff 2 3rd November 2008 21:58
