Old 6th September 2012, 12:35   #16
Epic's Avatar
Thanked: 424 Times
Default Re: i10 Trip display resets from Tripmeter to Odometer on restart
Hi guys,
This could possibly be a feature but definitely a feature that is not working like it is supossed to. I have a Polo 1.6 and in this case also the trip meter resets.....but only if the car is left idle for 08 hours or more.
In the cases above, some trip meters are resetting randomly or after 05 minutes which doesn't seem normal.
Epic is offline   Reply With Quote
Old 6th September 2012, 12:38   #17
Thanked: 86 Times
I have an i10 Asta automatic Jan 2011 model.
I use tripmeter A to record KMs run between refueling, and B to record the monthly run. Whenever I switch off the engine and re-start, the odometer comes on. However, if I then switch to tripmeter A or B, it shows the KM run since the last time I re-set it to zero, i.e. the last fuel stop or the 1st day of the current month.
I find this perfectly normal. After all, I don't need to see the KM run on a daily basis between fuel stops or the middle of the month !
benu9714 is offline   Reply With Quote
Old 6th September 2012, 13:44   #18
jits_1998's Avatar
Let me try to explain with slightly exaggerated example. Imagine driving in Delhi and trying to use the directions from a google map. It will give directions in 0.1 kms unit, and in the traffic you are supposed to switch off car at every signal. Then you would keep pressing the button every 5-10 mins, or waste petrol by not switching off the car.
Similarly imagine driving long distance, once you forget to reset the meter to trip meter after a break, you might mistakenly drive all over wrong place.
Simply its stressful to keep in mind about setting the trip meter on, if one seriously uses it.
@Epic: My Alto and 2010 i10 never reset to odometer, you might want to get your car checked.
Thanks.
jits_1998 is offline   Reply With Quote
Old 6th September 2012, 14:18   #19
dar3dev|l's Avatar
Thanked: 88 Times
^^ Jjits: Your example completely beats the meaning of a 'Trip' doesnt it ? On a trip i would expect the trip meter to be reset just once when is start my trip and check it only once i end to understand the kms i drove. We also usually use the same for checking the FE or monthly, daily runs.
Also with Google maps the focus is mainly on your current location measured by GPS and not by the Kms mentioned. Atleast for India, i have found inaccuracies in most of the distances showed by google maps.
dar3dev|l is offline   Reply With Quote
Old 6th September 2012, 15:40   #20
jits_1998's Avatar
By reset i meant display reset to odometer/trip meter, not reading reset to 0.
I don't need trip meter for checking FE, a small app like aCar in my android will do the job. But, I am not okay pressing button 5 times or after every break, in 1 trip to Bangalore, to know how far I am, thats the purpose of trip meter.
Highest reading in the odometer! Surprise The Indian Car Scene 602 18th April 2018 19:39
New Ford Figo : Odometer reads 110 kms. Trip meter says 7,400 kms!! How? vij4all Technical Stuff 21 23rd January 2011 18:14
Alto Trip Meter Resets to 0 on Turning Off Ignition yikes6633 Technical Stuff 4 6th September 2010 12:52
Taxis - tripmeter tampering LLL Shifting gears 12 1st May 2008 16:21
Need help ICE GURUs :- HU forgets the settings with every restart simply_sunny001 In-Car Entertainment 13 23rd August 2007 12:13
