Old 7th June 2012, 19:16   #1
Archish's Avatar
Thanked: 88 Times
Default Something Broken in the Xylo's Engine bay
Hi mates,
There is something broken in my Xylo E8 Engine bay. I have attached a pic and have rounded the broken off area. It looks like a small glass tube like thing and looks like the top has blown off. My driver found it when he was cleaning the engine bay. There was small loose spring in it. There is a sticker on it that says something like 'LIMIT'
I can take it to the Mahindra Service station, but the issue is that I need to start to Bengaluru by 9 tomorrow morning and it cant be delayed. Is it safe to drive the car with something broken....
Pls advice
Archish is offline   Reply With Quote
Old 7th June 2012, 20:07   #2
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Default Re: Something Broken in Xylo Engine bay
It is the air intake service indicator, you can drive the car in its current condition to a nearest spare parts shop or M&M authorized service center. IIRC, it costs hardly a few hundred bucks. BTW, how did it break?
Spike
SPIKE ARRESTOR is offline   (3) Thanks Reply With Quote
Old 7th June 2012, 20:31   #3
Thanked: 245 Times
Yes, its your Air filter dust indicator, get it changed from you service center.
dadu is offline   (3) Thanks Reply With Quote
Old 7th June 2012, 20:37   #4
greenhorn's Avatar
Thanked: 1,519 Times
Would suggest that you change it asap, and not really recommended that you drive it to bangalore since you will end up sucking a lot of dirt into the engine (since your air filter is now effectively bypassed, and this may damage your turbo/engine walls. Can be driven for sure. I've driven my indica around for a week before i found a similar issue (and I gave my mech hell for it), but if you can avoid it in the first place, its the better option
greenhorn is offline   (1) Thanks Reply With Quote
Old 7th June 2012, 21:27   #5
Thanked: 2,410 Times
Just block it off and drive. Replace at your convenience.
Sutripta
Sutripta is offline   (2) Thanks Reply With Quote
Old 7th June 2012, 22:08   #6
greenhorn's Avatar
Just curious - wouldnt the low pressure from the intake side suck whatever is used to cover it in (unless its some strong material) in?
Old 7th June 2012, 22:22   #7
Only if the air filter is totally jammed will there be strong suction.
Whatever is used to block off the broken part does not have to be very strong. But engineering commonsense should be applied. (like not use thin plastic which softens/ melt in underbonnet heat!)
Best - unscrew and put in a bolt.
Sutripta
Old 8th June 2012, 02:38   #8
dhanushs's Avatar
Thanked: 4,507 Times
It is basically the same indicator seen in olden days vaccum cleaner. If flow through Air Filter in not restricted, or blocked, no air would be sucked through the indicator, and it shows 'green', 'fit' etc.. If Air Filter path is blocked, then more air is sucked through the indicator, and hence the pressure pushes against the spring, and moves the indicator to 'red' or 'change' etc...
In this case, if Air Filter is OK, then it should be fine.
Old 8th June 2012, 08:41   #9
Archish's Avatar
Thanked: 88 Times
Sutripta
Thanks guys. ^^^ This is what I am gonna do. I will come back from Bengaluru and take care of it.
---Archish
Something fast, Something naughty - The Volvo S60 T6 (304 BHP) kau_therock Test-Drives & Initial Ownership Reports 97 26th December 2014 17:27
Strange sound from Gearbox - Something broken inside? Leoshashi Motorbikes 12 29th October 2014 19:04
M&M launches Xylo variant - Xylo D2, with new Engine H3LIOS The Indian Car Scene 61 11th November 2010 22:34
