Old 23rd June 2012, 16:50   #16
Catalyst_delhi's Avatar
Thanked: 149 Times
Default Re: Ford Ikon: Jammed Fuel Rail
Originally Posted by RM2488 View Post
I'm thinking of developing a reader on an AVR, so that is definitely gonna happen at some point. I don't think the engine is giving a code though. I might be wrong of course.
What is an AVR , I would like to know how to develop a reader
Catalyst_delhi is offline   Reply With Quote
Old 23rd June 2012, 17:09   #17
RM2488's Avatar
Thanked: 117 Times
An AVR is a microcontroller family from Atmel. Microcontrollers are basically integrated circuits that can be programmed to function as you want them to. Think about an IC that you know- eg, a 555- timer. Now imagine if you wanted it to perform a complicated timing sequence- for example, turn on blinkers for short bursts, then long bursts, and then short bursts again, but only while you're reversing. While doing this with discrete logic is possible, a microcontroller will enable you to simply WRITE the code to do this. A microcontroller, depending on it's features, will let you do this and a lot more. I once developed a module (prototype only) that gave one-touch up and down power windows to a Swift DZire VDi.
AVR and PIC are pretty popular families, and are easily available in India. And it is cost effective too- I used an ATTiny2313 for the power windows hack, which only cost 45/- at the time- not including the motor drivers, but you get the idea- discrete logic would have cost a lot more, and would not have been as easy to build or modify. An average car has at least a few microcontrollers in it, proprietory ones. The biggest one would, of course, be the ECU. They can be reprogrammed at will, by competent people.
I'm rethinking the build-an-OBDII-reader approach. An ELM 327 bluetooth reader is available for less than 2000/- bucks, might be cost effective to buy one. I do intend to build one, but I'm not in such a hurry anymore.
As far as the additive is concerned, I forget the name- I think it's from ELF. I'll have to check the name and get back to you.
RM2488 is offline   (2) Thanks Reply With Quote
Old 23rd June 2012, 18:46   #18
Thanked: 149 Times
Brilliant! Tiny hacks ! yes you can get ELM readers for $9.99 on deals extreme. ELF additive let me search.
Old 23rd June 2012, 18:56   #19
RM2488's Avatar
Thanked: 117 Times
Okay, it's by TOTAL which is apparently an Elf brand or something (it's on their site- TOTAL Additives and Special Fuels. TOTAL Additifs et Carburants Spéciaux). I use a product called P994 which is an additive, not strictly a pure injector cleaner. I used it in higher than recommended dosage to clear out the injectors sooner, for my engine is past 80K.
RM2488 is offline   Reply With Quote
Old 24th June 2012, 21:21   #20
RM2488's Avatar
Thanked: 117 Times
I decided to bite the bullet and buy an ELM 327. Will tell you how it goes.
The fuel additive is really working now. I went from a previous non-AC city mileage of 6 to a non-AC highway mileage of 11 in less than 50 kms run. I am using a 4X dosage though. Once the injectors are clean, I think it'll run fine. The car had been idle for a long time before I bought it. Now even the fuel pump has become quieter. The engine NEVER stalls with the clutch-brake-turn manuever now. It idles much smoother now, with way less vibrations. I think we'll be able to close this thread in a week if they get properly cleaned. Not the perfect solution though.
RM2488 is offline   (1) Thanks Reply With Quote
National Rail Museum - Matheran Rail Car ATUL SINGH Pre-War 44 23rd August 2017 17:03
Rear wheel jammed after car stationary for a couple of days ! Shakensoul Technical Stuff 58 23rd September 2016 16:39
Rail Budget 2016: Chennai to get India's first rail auto hub S2!!! Commercial Vehicles 3 22nd May 2016 23:54
Wheel JAMMED..... ~ H O N D A ~ Technical Stuff 8 16th July 2006 00:09
