Old 17th June 2012, 16:29   #1
k_nitin_r's Avatar
Thanked: 74 Times
Default Fluid leakage or condensation?
I noticed a leakage or condensation of some fluid from the section located after the air filter on my Esteem diesel. I looked under the hood a few hours after driving the car and there was a large amount of fluid that had leaked - the fluid got onto the cap of the brake fluid reservoir behind it and onto the hoses below. It wasn't dripping at the time I looked. Does anyone have a clue of what it might be?
The tape in the picture marks the air intake pipe that comes after the air filter. The small tube with two metal rings comes from the air intake pipe. Then, the black cycle-bell-shaped connector clips onto the engine cover and this is where the leakage appears to occur. The fluid didn't seem like water (perhaps after dissolving something it appears different?), but it isn't greasy like oil either.
k_nitin_r is offline   Reply With Quote
Old 17th June 2012, 17:09   #2
Thanked: 701 Times
Default Re: Fluid leakage or condensation?
If that black thing is the PCV valve, then it might need a replacement.
ramzsys is offline   Reply With Quote
Old 17th June 2012, 17:24   #3
infotech58's Avatar
Thanked: 217 Times
if it happens ONLY after you have used the AC and switched off while parking, then it might be condensation.
if the liquid looks/feels like coolant (or dissolved coolant), it may be PCV valve.
infotech58 is offline   Reply With Quote
Old 17th June 2012, 18:33   #4
Catalyst_delhi's Avatar
Thanked: 148 Times
Hope fully your oil is not overfilled. Might be the PCV valve or diesel..
Catalyst_delhi is offline   Reply With Quote
Brake fluid leakage- help required! santosh.s Technical Stuff 53 11th March 2009 23:16
ikon ac: water condensation & engine jerk silver_shadow Technical Stuff 2 5th May 2008 19:10
Windscreen condensation? adman77 Technical Stuff 22 14th August 2007 11:23
water condensation in oil tank? babe_on_wheels Technical Stuff 6 24th August 2006 19:18
Injector Cleaning Fluid n_aditya Modifications & Accessories 12 20th March 2006 16:40
