| LinkBack | Thread Tools | Search this Thread |
| | #16 | |
| BHPian Join Date: Oct 2011 Location: bangalore
Thanked: 52 Times
| Quote:
. I love the outcome!!.You have used the masking tape very well. When you said you had to sand the surface, how much did you mean? Did you have to get the surface completely roughed up? | |
| | #17 |
| BHPian | Thanks Sumeshmani. I just rubbed it softly with fine grit sand paper. ![]() |
| | #18 |
| BHPian Join Date: Dec 2009 Location: Faridabad
Thanked: 30 Times
| My Fiesta comes with this from the factory (1.6S). :P |
| | #19 |
| Senior - BHPian Join Date: Jul 2007 Location: goa bangalore mumbai
Thanked: 129 Times
| Hey, nice job. Car looks mean. few queries.. Is taking the bumper off an easy job? You have 2 roots horns added, in addition to the OE ones. Did you use another relay? What air filter do you use, it is not OE. |
| | #20 | |
| BHPian | Quote:
Removing the bumper is an easy process, if you have the right tools. ![]() Those horns where added long back when I bought the car. Fitted that from the Maruti Suzuki Dealer at the time of purchase. There must be a separate relay. I use GC Wind Filter( with dynamisation kit). Cheers | |
| | #21 |
| BHPian | Thanks ACMohan, I've been dreaming of doing this on my car but never had the courage to. Your car looks "terrific"! Can you please elaborate how you opened the seal? It's the only thing bothering me. Thanks for the detailed pics. |
| | #22 |
| BHPian | Thanks Eminenttismo. Heat the gum till it becomes soft. You will be able to see the silicone gum melting. Temperature of about 300degrees is enough, I suppose. Care should be taken not to melt the headlamp (glass). Or we can use an oven. The back cover is removed using a flat tip screw driver and pulling the two parts apart. And the reflector will usually be screwed on to the glass (2 screws in my case). Cheers |
| | (1)
| | #23 | ||
| BHPian | Quote:
!! Guess you got this done from Bangalore itself, Please please guide me to this place. | ||
| | #24 |
| BHPian Join Date: Jun 2012 Location: Bangalore
Thanked: 323 Times
| How do you ensure that the lens of the headlamps do not get damaged using the hot-air gun? Also, while sealing it back, drying the housing and using an additional layer of silicon would help, to ensure there is no gap anywhere. Just my two cents. One thing I am curious about is, these acrylic based sprays take some time to harden up. I do clear coat finishes for mobile panels etc, but they dont dry so quickly. Offcourse they are touch dry within minutes but they take days to cure. I have found that keeping the parts in direct sunlight will help speed up the process. But as you have sealed them back early, I think they will start emitting chemicals, which may remain in the headlamp assembly. After sometime, please remove the bulb and indicator, blow hot air into the assembly to remove these vapours. |
| | (1)
| | #25 | |
| BHPian Join Date: Jan 2010 Location: Bangalore
Thanked: 253 Times
Infractions: 0/1 (5) | Quote:
You can reach him @ 9845004858, keep in mind he is closed on sunday .You can also check with sai colorium, bhpian RK Ramesh should be able to get it painted for you , but they don't open the lamps themselves, they usually get it done by someone else. Hope it helps . Cheers Last edited by Schoudhury : 29th June 2012 at 11:49. | |
| | (1)
| | #26 |
| BHPian | This gives me a great idea. My 10yr old santro has eroding corners on the headlight. This will be a great thing to do and give the car more character. Thanks for good DIY, will try and get it done when the car goes for a full paint job. Your car looks good. Can you post better photo with right amount of lighting and no reflection? The ritz looks mean. Nice tasty there. |
| | #27 | |||
| BHPian | Quote:
![]() Quote:
The headlamp is still water tight, I suppose. So if it leaks, then I would use another layer of silicone gum.I've dried the bezel by blowing hot air(at 50degree). ![]() I will remove the vapors after some time. Thanks for the valuable suggestion. Quote:
Eagerly waiting to see your Santro's headlamp painted. | |||
| | (1)
| | #28 |
| Senior - BHPian | Love it. Thanks for sharing ACMohan. The effect will be even more spectacular in the 2011 Swift as the lights are quite BIG. The Swift in the UK got black bezel from factory. They look special. |
| | (1)
| | #29 |
| BHPian | Painted the bezel's of my cousin's Indica on a lazy Sunday afternoon. ![]() Here are some pictures of it. All the steps are same. ![]() ![]() ![]() First Coat ![]() Final coat (3rd coat) ![]() ![]() The final outcome. Comments and suggestions are welcome. At Mods: I thought of posting this here,because there's no need for a new thread. Please change the name of thread or move it to appropriate thread, if needed. |
| | (1)
| | #30 |
| Senior - BHPian | |
Similar Threads | ||||
| DIY : HID (3000k) Installation in the Maruti Swift | ACMohan | Modifications & Accessories | 8 | 17th December 2012 17:44 |
| Maruti Swift : DIY Carputer And ICE'D! | ACMohan | Sound Off and Show Off | 10 | 14th August 2012 19:39 |
| DIY : Dismantling Fiesta headlamp & Painting the shrouds | mayankk | Technical Stuff | 20 | 9th May 2012 18:35 |
| DIY : Painting my Mondeo wheels black | zazer | Tyre & Alloy wheel Section | 4 | 30th October 2010 11:27 |
| DIY - Fiesta Centre Console painting | Wolffe | Modifications & Accessories | 27 | 15th October 2009 16:56 |
