Thread Tools
Old 13th April 2006, 14:46   #1 (permalink)
netarchie's Avatar
Default Overdrive ? - Information required please
what does this mean "Overdrive on 4th and 5th gear"
Note from moderator - Please look at Rule # 10.
Thread renamed.
__________________
netarchie
netarchie is offline   Reply With Quote
Old 13th April 2006, 15:06   #2 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Overdrive - Definition
A transmission in which the highest gear ratio is less than a one-to-one ratio. This means the drive shaft turns faster than the engine crankshaft. The overdrive feature saves fuel and, because the engine runs slower, engine wear and noise are reduced.
A ratio of 1:1 means that your driveshaft is turning at the same speed as the crankshaft.
Overdrive means that the driveshaft(which goes to the wheels) is turning at a speed higher than the crankshaft(driven by the engine).
Most cars have overdrive in 5th gear and many in 4th gear too.
__________________
Reclaiming.....!
Old 13th April 2006, 15:08   #3 (permalink)
Revvhead's Avatar
well i guess that means the both 4th & 5th are geared lower than 1:1, for these models.
Overdrive is basically any gear witha ratio lower than 1:1.
i.e at 1:1 ration for one rotation of the crank the wheels(driveshaft actually) should turn once,
in overdrive they turn 1.x times
Of course this is not taking into account differetial ratios etc.
before people come eatin my head.
Hope that sorts it out
Of Course
__________________
The Swift DZire has a 6 Month waiting period to give you time to seriously reconsider buying something that Ugly
Revvhead is offline   Reply With Quote
Old 13th April 2006, 15:09   #4 (permalink)
v1p3r's Avatar
Erm, isn't overdrive when the output from the gearbox is spinning faster than the crankshaft? It can't be the final driveshaft, because those have a built in reduction ratio from the differential.
In most cars, 4th gear is normally 1:1 or very close.
__________________
Peace is a lie, there is only passion.
v1p3r is online now   Reply With Quote
Old 13th April 2006, 15:14   #5 (permalink)
Revvhead's Avatar
there there, i did say driveshaft actually.
and i meant like the driveshaft leading to the diff as would be found in a RWD.
was just givin the simplistic explanation
__________________
Old 13th April 2006, 21:04   #6 (permalink)
netarchie's Avatar
Default thanks guys
So , it means in short the term had nothing to do with Speed of the car and rather it is for saving fuel.
__________________
netarchie
Old 13th April 2006, 23:03   #7 (permalink)
DaPilot's Avatar
Overdrive should be used on the freeway/highway. Not in city driving. If you use OD in city driving, you will cause more wear to your transmission and also not gain any fuel efficiency.
Over drive essentially adds an extra gear to your drive ratio effectively lengthening your final drive ratio and causing your engine to maintain lower RPMs. In other words... an overdrive gear lets the engine run at a lower rpm to maintain the vehicle’s cruising speed. This is perfect for cruising on open roads but bad (over time) for stop and go or heavy traffic conditions (definately a NO NO for Bombay City traffic). So if your car has OD its best to switch it off while driving in the city
DaPilot is offline   Reply With Quote
Old 14th April 2006, 00:34   #8 (permalink)
Deeps's Avatar
Well, its hard to switch off overdrive on an M/T unlike the A/Ts that you are probably used to in the US.
__________________
Stupidity is not a handicap! Park somewhere else!
Deeps is offline   Reply With Quote
Old 14th April 2006, 01:35   #9 (permalink)
DaPilot's Avatar
You are right it is very easy in A/Ts but at the same time if you think about it.. it is quite simple for M/Ts also.... just dont use the gear that has OD when you are driving at a low speed (you will hear a knocking sound)
As pointed out earlier... any gear that has a ratio lower than 1:1 is called an overdrive gear. It's usually the fifth gear on standard transmissions, and fourth gear on automatics.
Old 14th April 2006, 01:39   #10 (permalink)
SLK
SLK's Avatar
Of course its everything to do with the speed of the car!
More speed less RPM thats why fuel saving.
__________________
Č╠╣€€Я$
$£Қ
SLK is offline   Reply With Quote
Thread Tools
Autocarindia vs Overdrive artofzen A Collection of the best threads 243 29th April 2008 17:06
Required---Information on Used Tata Sierra pkp SUVs, MUVs & 4x4s 5 27th April 2007 20:18
information required regarding Mahindra scorpio with 2.2l crde mash SUVs, MUVs & 4x4s 0 9th January 2007 13:34
Information on Statesman rally required Revvmaster Shifting gears 2 4th January 2005 11:36
Information about the Mahindra Classic required aggressive_anush SUVs, MUVs & 4x4s 3 1st October 2004 18:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
