Old 26th December 2012, 17:39   #46
sportz_kruzer's Avatar
Default Re: My Mercedes W124 E220 - Head Issue
Can anyone help with this new issue of mine?
I am getting noise similar to sound of wind blowing through a vent (make it a little harsher)...from the rear side. I guess it comes from the differencial. This is dependent on the movement of the vehicle doesnt really increase with speed. It ONLY comes when decelerating, weather in gear or Neutral and goes away when stopping completely. THre sound is there even at walking speeds and goes only when the car completely stops. its independent of engine RPM and DOES NOT come up at acceleration, goes away the moment you hit the throttle. Its not the clutch bearing...clutching in-out makes no difference.
Issue pinpointed to movement of the vehicle during deceleration
Can anyone throw some light on axle/differencial maintenance for the W124 E220 Merc? Is there any propeller shaft or bearing i need to grease?
Correct me if I am wrong here...AFAIK and seen underneath, this car does not have U joints on either ends of the axle as the differencial is bolted to the chassis and had seperate axles for each side (like a typical front wheel drive) for each rear wheel. the axle is bolted directly to the diff via a rubber coupler kind of thing (i guess they call it flex discs) This is unlike a mahindra or a safari whose diff. jumps about with the wheels, hence needing u joints/flex yoke setup to transfer torque from the tranny.
would be grateful for any clues/suggestions!!
sportz_kruzer is offline   Reply With Quote
Old 27th December 2012, 19:59   #47
msaudf's Avatar
Thanked: 152 Times
the sound could be a simple differencial bearing noise. to be sure you could try and replace the diff oil with some fresh diff oil and it could stop the noise.
and the axles coming from the diff to the wheels are called CV joints, exactly the same as a FWD car.
msaudf is offline   Reply With Quote
Old 9th March 2013, 23:18   #48
yup diff bearing it is! thanks a ton!
My petrol E220 of late had started to shudder, cough, pop/misfire during cold starts. It is more so during early mornings. Eventually it settles down with occasion engine stake/stumble at idle...this happend after i cleaned the throttle body with choke/carb cleaner, performs much better when warmed up.
it seems temperature related as it used to take round 3 minutes for the symptoms to settle down when it was cold about a month ago..and now its about 15 seconds or so... scan codes point to MAF sensor reading too high. any idea what that means? I suspect a vacuum leak in the system.
Also today i found this wire hanging loose in the engine bay (see pic). This wire leads to the ECU. I couldn't find any place where it can fit..any ideas?
Old 10th March 2013, 20:28   #49
Tejas Ingle's Avatar
Thanked: 310 Times
MAF senor is the Mass Air Flow sensor mostly located on the air intake manifold. It senses the mass and temperature of air flowing into the engine. Based on this information, the ECU computes the injection timings for optimum performance. It is possible that the mixture is being left too lean by the ECU based on incorrect signals from the MAF sensor.
Tejas Ingle is offline   Reply With Quote
W124 - Mercedes E220 or E250D? Which would you buy? GTO The Indian Car Scene 119 6th June 2016 15:24
Mercedes E220 (W124 series) setup Raja In-Car Entertainment 38 21st June 2013 09:47
Mercedes E220 W124 Stalling and heating issue aquavelva Technical Stuff 11 9th October 2011 00:13
My "new" Mercedes E220 (w124 series) Raja Test-Drives & Initial Ownership Reports 44 19th February 2010 10:54
