Old 15th April 2006, 20:36   #16
revharder's Avatar
Thanked: 49 Times
Originally Posted by pramodkumar
most of the cars are tested with full tank of gas, All passengers and luggage in the boot to see the worst case sinario
no.
you are totally wrong here.
i never saw any car under testing to have more than a quarter or half tankful!
passengers and luggage in car while testing??
no way!
passengers are seated in cars just to check the comfort level while the car is stationary.
and luggage is put in just to judge the capabilities of boot!
and cars are not tested to judge the worst case scenario. rather they are tested for best case scenario!
so that buyers can get the best possible informationabout the car.
revharder is offline   Reply With Quote
Old 17th April 2006, 15:09   #17
2fast4u's Avatar
Originally Posted by Technocrat
You burn 75 litres in 2 to 2 days
Dude which car(I am sure in must be in Abu Dhabi hence asking) & is your work place that far ??
As for me:
Car: Alto LXi
Fuel: Full tank around 29-32 liters each fill
this practise seems good enough
ya ADhabi. Nissan Altima 1992 and doing approx 300 to 370 kms daily Adhabi to dubai thats a MUST cause wife workin in Abu D and me in Dub. so its better if i do the drive part and let the wife relax. btw my timings are cool 7 to 2.00
2fast4u is offline   Reply With Quote
Old 17th April 2006, 15:45   #18
tsk1979's Avatar
Thanked: 16,420 Times
I always do full tank. Infact more than full tank. Fill up the tank preferably on a surface where my car is slightly tilted towards right. Shake shake shake, and fill to the brim
Old 17th April 2006, 15:45   #19
WhiteKnight's Avatar
Thanked: 76 Times
Amazing.. i must say that you are at the right place..
WhiteKnight is offline   Reply With Quote
Old 17th April 2006, 16:09   #20
shuvc's Avatar
Thanked: 287 Times
Always top up till the auto cutoff .. around 40 - 43 litres
Stick to one particular fuel station.
Drive till the needle touches empty, which seems to be around 10litres of reserve for the Baleno.
Duration between top ups - 16-19 days, 450+ kms.
Will it help FE if I try doing the top-ups after 200kms, taking into consideration the losses due to evaporation ?
OT, the fuel needle hits half-way mark at 325ish kms .. then drops the other half in the next 125-150 kms !
Old 17th April 2006, 17:24   #21
rsjaurr's Avatar
Thanked: 27 Times
My car is Getz,GVS model and i fill it full,35-39L from reliance petrol pump always though 4-5 other pumps r nearer to me.
rsjaurr is offline   Reply With Quote
Old 17th April 2006, 18:28   #22
SLK
SLK's Avatar
Thanked: 190 Times
I always fillup full tank...
Originally Posted by revharder
- if someone always want to drag with other similar vehicles on red-lights(!) then to have some better p2w ratio, minimum filling is good!
- similarly, lesser weight means better fuel economy, better handling, etc.
wow... the drivers should join VLCC... it would really help!
SLK is offline   Reply With Quote
Old 17th April 2006, 18:33   #23
naveendhyani's Avatar
Thanked: 7 Times
Car: M800
Always fuel my tank till the auto cutoff is reached. i fill whenever the fuel gauge is at 1/4. i burn the fuel in around 10-12 days time since travel is not much plus the 800 returns a good 16-17 in city and 19+ on highway.
naveendhyani is offline   Reply With Quote
Old 18th April 2006, 12:56   #24
Beeman's Avatar
95% of the times i get it full up, can't go through the hassle of going to the pump after every short time..........
Beeman is offline   Reply With Quote
Old 18th April 2006, 14:20   #25
souravbasu's Avatar
Thanks for all your postings. Following are the facts which has come up in our discussion so far:
So far, from all your replies, it is for sure that filling up the tank to its fullness is the best practise.
1. It might add extra weight to the car but will also add in stability to the car.
2. This would prevent the metallic fuel tank from rusting due to water content in adulterated petrol we get now a days.
3. This would also help in reducing the fuel loss due to evaporation.
4. Also read somewhere that a full tank will keep the fuel injector pump cool, as it will have to work less.
5. Only risk with full tank is that the Car with full tank is more prone to damage by fire in case of accident.
Some other best practices:
1. Always refill when the climate is colder (early morning or late night).
2. Always opt for Auto Cut-off mechanism for refilling tank to FULL (good to measure the FE).
3. Always stick to the same Petrol Pump Station, once you are convinced.that they give better quality petrol.
4. When not using the car so much make sure that the fuel tank is atleast half tank and above (to prevent fuel loss due to evaporation and prevent rusting of metallic fuel tank).
Cheers!
SOURAV
souravbasu is offline   Reply With Quote
Old 18th April 2006, 15:28   #26
SLK
SLK's Avatar
Thanked: 190 Times
@saurabasu: You sure have come to some funny conclusions!
WATER ... now! who said that?
Really?... How does more fuel slow down evaporation?
yes, Its the fuel pump .. which is inside the tank itself.
Where did this come from?... we have discussed this on another thread. Didn't draw a conclusion there but the discussion was sure in favour of "fill to the brim".
Old 18th April 2006, 15:37   #27
revharder's Avatar
Thanked: 49 Times
no.
this auto cut off is not a reliable thing to be assumed as something to measure a thing!
quite often it gets stopped on itws own even when tank is more than half empty!
it can't be assumed as a measure point to measure anything!
to calculate the fuel economy it is better to rely on your car's 'low-fuel-indication-lamp'.
Old 18th April 2006, 15:49   #28
souravbasu's Avatar
Good to know that the post amuses you !!
Sorry for the confusion, now I rephrase it to moisture instead of water. Adulterated petrol is likely to have more moisture contents due to contamination.
More fuel in the tank means less the empty space, hence lesser evaporation (though this loss is very insignificant).
Please correct me if I am wrong.
Old 18th April 2006, 17:20   #29
shuvc's Avatar
Thanked: 287 Times
Since we are also discussing the time of refuelling, I thought it prudent to give a reference to posts 115 and 116 of this thread.
http://www.team-bhp.com/forum/indian...elievable.html (Baleno Mileage -- UNBELIEVABLE)
Old 18th April 2006, 19:21   #30
Surprise's Avatar
Thanked: 272 Times
I fill once in a week for Rs.1000/-. I really dont know that filling it during early morning and late in the nights has advantage. But mostly I fill during the late in the evenings while coming back from work. Sometime during the lunch break at 14.00 hrs. I normally dont go with such close calculations.
Surprise is online now   (1) Thanks Reply With Quote
DIY - Cheaper Car Perfume Refill! rajeev k DIY - Do it yourself 83 7th December 2016 13:43
Letting your Car's fuel tank run empty? Drop the habit! searchingheaven Technical Stuff 32 25th January 2013 23:17
Driver's Ed: Practice parking your car honeybee Gadgets, Computers & Software 0 3rd June 2010 13:09
How often one needs to refill gas in AC? sbasak Technical Stuff 23 31st July 2007 00:07
fuel tank 42lt.- fuel in-44lt. v.tec Technical Stuff 55 29th August 2006 20:50
